Epson driver and OS-X
2004-05-12 by Steve Kale
I am sorry to ask a question that I know has been answered here before but I have waded
through the archives and can't find the post I have seen before.  I just swapped the K chip
on my MIS CFS from Photo to Matt and am getting Jobs Stopped.  I deleted the printer but
when I tried to re-add it I noticed that when I select the printer all the drivers that appear
are for CUPs and Gimp Print.  I must admit I have never noticed this before.   How do I use
the Epson driver and not Gimp?  Isn't there some sort of patch...
Thanks
Steve
Re: Epson driver and OS-X
2004-05-12 by Scott Graham
In the Print Setup Utility if you select USB or Firewire, you may get the GIMPs.
You need to select Epson USB or Epson Firewire.  If these don't appear, the printer is not
connected, turned on, or something.
Also the Gimps/CUPS are known to cause disasterous conflicts with Espon drivers in some
cases.  So I would say good luck.
The G/C's can be uninstalled in SOME cases with a uninstaller downloaded from the web.
Or better by reinstalling the OS and NOT loading ANY printer drivers at all.
In extreme cases you need to reformat the HD, according to Apple whom I spent an hour
on the phone yesterday.  After a following hour with Epson, they just recommended the
resinstall and no drivers method.
I found another solution for my problem fortunately.
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steve Kale" <stevekale@b...>
waded
chip
but
appear
use
> Thanks
> Steve
Re: [Digital BW] Re: Epson driver and OS-X
Thanks.  I think I just missed the Epson USB vs USB.  I am sure that I have
had the Epson drivers up and running with no problems before (alongside QTR
etc).
Reply-To: DigitalBlackandWhiteThePrint@yahoogroups.com
Date: Wed, 12 May 2004 14:00:06 -0000
Subject: [Digital BW] Re: Epson driver and OS-X
GIMPs.
printer is not
