hi there, mike. i have a 9000 rather than an 8000, but the
principle is the same. i sometimes use no multi-sampling, 4x
and, rarely, 16x. i often use the superfine setting because early
on i began to believe that doing so gave a result with less
haloing. (i may be wrong there... :-) at any rate, with digital ice
on fine, superfine scan mode and 16x multi-sampling, on a 6x6
negative at 16bit grayscale, i don't recall a scan ever taking more
than 40 minutes. however, i do no adjustments, grain reduction,
or any other kind of processing during the scanning process.
ed
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mkitei"
<mkitei@b...> wrote:
> I just got an 8000, and wanting to see just how fine a superfine
scan could be,
> I tried a 16x. I watched the progress window for a while then
packed a bunch
> of equipment for a location shoot, watched a little longer then
went home and
> had lunch, came back and watched some more, sent a few
faxes and did
> some housekeeping. Then I watched some more. The scan
was excellent. So
> was the one I got from 4x in a fraction of the time. What settings
do you use for
> optimum ( a time vs. quality equasion) results. End use is best
print I can
