2004-05-27 by Peter A. Klein
I've had exactly the same problem with my 1280, using first the VM
and then the original UT inks.
After I was away from home for a week, my yellow head clogged. On
the bottom jagged line of the test pattern, the first seven nozzles
print, the next four don't, and the last one sometimes prints and
sometimes doesn't. I've tried everything--Windex, Fantastik, warm
water flush, and MIS's cleaning fluid and cleaning carts.
Fortunately, there is an authorized Epson repair facility in the
Seattle area (Computronics in Kirkland, WA). They say that when it
gets this bad, they have a 30% chance of success cleaning the print
head. Otherwise, it's a new print head for about $144 (both parts
and labor). This includes a general checkout of the entire printer.
--Peter
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "george_w_barr"
<george.barr@s...> wrote:
> John:
> I am currently battling the same problem except that my problem is
so severe that the
> yellow never functions - currently about 10% of the yellow nozzles
work and the pattern is
> consistent suggesting it isn't bubbles. I have already tried the
windex on the pad trick and
> next up is windex in the input stem (after removing the yellow UT
cartridge), all this on a
> 2200.
> Odd that the most dilute ink would be the one to clog -
unfortunately I clearly don't have a
> solution for you but if either of us does, hopefully he will
contact the other.
> George
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mr_Misty_44"
<jharvey@i...>
> wrote:
> > Has anyone had problems with the "Yellow" or lightest gray in the
UT
> > set clogging. I've been having quite a problem with this one ink.
I
> > get good nozzle checks and then, half way through a print I can
see
> > the light gray fail somewhat. When I do another check the yellow
has
> > broken lines. I do a cleaning or two and then I might have a good
> > check again. I can have a few prints and then again, the yellow
clogs.
> > Is it the head or the ink? I'm using QTR with a 7500. I've seen
some
> > posts lately about the possible settling of pigment
> > John H
