New to UT 7 -- mixed results, need help
2004-05-30 by markjamesfisher
I managed to get everything I could out of my Ultrachrome inks and
finally decided to move to a set of grayscale inks.  I spent this
evening learning how to use the UT7 inks in my 2200.  After lots of
cleaning cycles, I finally got a good head check.... I then used the
curves method with Paul's neutral EAM curve: fantastic, selenium-
looking results.
I then tried the other curves with pretty poor results.  They had
poor contrast and looked somewhat posterized.  I then tried the
slider method as Paul listed and had great results for both warm and
neutral.  I even managed to get a slightly cool image out that way.
The question is what might I be doing wrong with the curves?  I'd
sure like to have the flexibility of the curves method as I'd like to
have a bit moe control and eventually try to split tone.  My process
is to open the grayscale in 16 bit, convert to RGB, apply the curves
and print in Adobe space (also tried colormatch space) and no color
adjustment.  Any thoughts?
Re: New to UT 7 -- mixed results, need help
2004-05-30 by John Vitollo
<markjamesfisher@y...> wrote:
> My process
> adjustment.
In the "Print with Prieview" window: Source Space:  Document: Adobe RGB
Print Space: Profile: Same as Source
That should do it!
