Laquer on matte prints?
2004-06-07 by Tom OConnell
I just started using a new framer who seems to really be high quality oriented (at least with the frame/mat supplies). He is offering a laquer spray at a cost of $1 for 8x10 and $3 for 16x20...reasonable enough...but I have never heard of laquer as the spray. Is this a good idea? Anyone know? Tom O'Connell
2004-06-09 by nick_h_nugent
Hi Tom, --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tom OConnell" <tomoc@y...> wrote: > I just started using a new framer who seems to really be high > quality oriented (at least with the frame/mat supplies). > He is offering a laquer spray at a cost of $1 for 8x10 and $3 for > 16x20...reasonable enough...but I have never heard of laquer as the > spray. Is this a good idea? I'm sure this lacquer is solvent based. What this means is the solvent will soak right through the surface and your print will look like it's got blotches of kerosene. On matte print you need at least a coat of water based acrylic, then the lacquer or varnish can go on top without interacting with the substrate. --nick
2004-06-09 by Tom OConnell
> > I'm sure this lacquer is solvent based. What this means is the > solvent will soak right through the surface and your print will look > like it's got blotches of kerosene. On matte print you need at least > a coat of water based acrylic, then the lacquer or varnish can go on > top without interacting with the substrate. > > --nick Thanks, Nick. I think I'll get a couple tested...but not with important prints <g>. Tom O'Connell
2004-06-09 by J Vee
I use ClearJet, a solvent based UV product on several kinds of matte media and have never seen ³blotches². This after three coats, each 90 degrees off axis from the previous. If fact, I believe the company suggests that only solvent based sprays be used on waterbased ink prints. J Vee On 6/9/04 12:32 AM, "nick_h_nugent" <nick_h_nugent@...> wrote: > > > I'm sure this lacquer is solvent based. What this means is the > solvent will soak right through the surface and your print will look > like it's got blotches of kerosene. On matte print you need at least > a coat of water based acrylic, then the lacquer or varnish can go on > top without interacting with the substrate. > > --nick [Non-text portions of this message have been removed]
2004-06-10 by Bob Michaels
Premier Art PrintShield says it's lacquer based. I've never used it personally though considering it. Anyone using it on matte prints? I though I remembered some people referring to it on matte. Bob Michaels --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tom OConnell" <tomoc@y...> wrote:
> > > > I'm sure this lacquer is solvent based. What this means is the > > solvent will soak right through the surface and your print will > look > > like it's got blotches of kerosene. On matte print you need at > least > > a coat of water based acrylic, then the lacquer or varnish can go > on > > top without interacting with the substrate. > > > > --nick > > > Thanks, Nick. I think I'll get a couple tested...but not with > important prints <g>. > > Tom O'Connell
The Pemier Art PrintShield data sheet lists a lot of Wilhem ratings for popular matte papers sprayed with this lacquer based product. In general the ratings of the sprayed matte prints are about the same as those framed with non UV glass. Of course that's only one aspect of how long a print lasts in the real world. See: http://www.premierimagingproducts.com/pdf/PremierArtPrintShieldFactSheetVer2.1.pdf It's available from MIS for $15 a can or in bulk. Bob Michaels --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Michaels" <bob@b...> wrote:
> Premier Art PrintShield says it's lacquer based. I've never used it > personally though considering it. Anyone using it on matte prints? I > though I remembered some people referring to it on matte. > > Bob Michaels > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tom OConnell" > <tomoc@y...> wrote: > > > > > > I'm sure this lacquer is solvent based. What this means is the > > > solvent will soak right through the surface and your print will > > look > > > like it's got blotches of kerosene. On matte print you need at > > least > > > a coat of water based acrylic, then the lacquer or varnish can go > > on > > > top without interacting with the substrate. > > > > > > --nick > > > > > > Thanks, Nick. I think I'll get a couple tested...but not with > > important prints <g>. > > > > Tom O'Connell
2004-06-10 by Tom Baker
I use it on every print I offer for sale. And, I am only using matt papers. Can't really see any difference in the image once it has dried, which is pretty quick. Tom Baker Bob Michaels <bob@...> wrote: Premier Art PrintShield says it's lacquer based. I've never used it personally though considering it. Anyone using it on matte prints? I though I remembered some people referring to it on matte. Bob Michaels --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tom OConnell" wrote: > > > > I'm sure this lacquer is solvent based. What this means is the > > solvent will soak right through the surface and your print will > look > > like it's got blotches of kerosene. On matte print you need at > least > > a coat of water based acrylic, then the lacquer or varnish can go > on > > top without interacting with the substrate. > > > > --nick > > > Thanks, Nick. I think I'll get a couple tested...but not with > important prints . > > Tom O'Connell Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See �Group Topic, Rules and Guidelines� in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. Yahoo! Groups Links [Non-text portions of this message have been removed]
2004-06-10 by Steve Kale
I have been using Lyson Print Guard (same product) on my HPR prints for framing without glazing. It looks fine but a measured step wedge will show a significant shift in density post spraying, including a large drop in dMax.
> From: Tom Baker <tbaker1328@...> > Reply-To: DigitalBlackandWhiteThePrint@yahoogroups.com > Date: Wed, 9 Jun 2004 19:29:58 -0700 (PDT) > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: Re: [Digital BW] Re: Laquer on matte prints? > > I use it on every print I offer for sale. And, I am only using matt papers. > Can't really see any difference in the image once it has dried, which is > pretty quick. > > Tom Baker > > Bob Michaels <bob@...> wrote: > Premier Art PrintShield says it's lacquer based. I've never used it > personally though considering it. Anyone using it on matte prints? I > though I remembered some people referring to it on matte. > > Bob Michaels > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tom OConnell" > wrote: >>> >>> I'm sure this lacquer is solvent based. What this means is the >>> solvent will soak right through the surface and your print will >> look >>> like it's got blotches of kerosene. On matte print you need at >> least >>> a coat of water based acrylic, then the lacquer or varnish can go >> on >>> top without interacting with the substrate. >>> >>> --nick >>
While I have no way to measure it, I have not seen this on the Ultrasmooth and Somerset Velvet that I use. I have tried the spray half the print trick to visually compare, and see no negative effect. On the Somerset it seems to slightly increase saturation. But, I might just be making that up in my head. I don't see it on the Ultrasmooth, however. I'll try a step wedge to take another visual look at it. Tom Baker Steve Kale <stevekale@...> wrote: I have been using Lyson Print Guard (same product) on my HPR prints for framing without glazing. It looks fine but a measured step wedge will show a significant shift in density post spraying, including a large drop in dMax. [Non-text portions of this message have been removed]
I agree that it is hard to see the difference but have measured drops in density of the 100% step, for example, from 1.66 to 1.58. The nice thing about spraying the prints is that there is no longer a risk of flaking and the prints can be directly (gently) brushed to remove dust etc. The downside is this density shift (others have commented in the past that the dark areas lighten and the light areas darken). I am in two minds as to whether to spray and then linearise the spray steps or not spray at all. The agreed Best Practise is to apply polyurethane via a mayer rod but this seems too much of a mess for me.
From: Tom Baker <tbaker1328@...> While I have no way to measure it, I have not seen this on the Ultrasmooth and Somerset Velvet that I use. I have tried the spray half the print trick to visually compare, and see no negative effect. On the Somerset it seems to slightly increase saturation. But, I might just be making that up in my head. I don't see it on the Ultrasmooth, however. I'll try a step wedge to take another visual look at it. Tom Baker [Non-text portions of this message have been removed]
BTW I am surprised you use Somerset Velvet. I tried this paper and stopped immediately due to its very low dMax capability and mottled blacks. However I am talking about the original Somerset made in England. Perhaps you are referring to the Epson version which I understand uses the same paper base but Epson applies there own coating.
Yep. The Somerset Velvet for Epson. Like any paper, it's not for every image. Now that I can get it as needed, I am using more Ultrasmooth. But, a 44" roll costs almost as much as a tank of gas these days. Tom Baker [Non-text portions of this message have been removed]
Yes but in the US gas is still extremely cheap....
From: Tom Baker <tbaker1328@...> Yep. The Somerset Velvet for Epson. Like any paper, it's not for every image. Now that I can get it as needed, I am using more Ultrasmooth. But, a 44" roll costs almost as much as a tank of gas these days. Tom Baker [Non-text portions of this message have been removed]
2004-06-11 by Paul Roark
Steve wrote: >I have been using Lyson Print Guard (same product) on my HPR prints for >framing without glazing. It looks fine but a measured step wedge will show >a significant shift in density post spraying, including a large drop in >dMax. I've seen and measured this with UltraSmooth and PremierArt Print Shield, which, as you note, appears to be the same as Lyson Print Guard (though the Premier Imaging people deny they are the same). Perhaps related to this is the observation by another forum member that the surface of smooth prints can feel a bit gritty after spraying with PremierArt Print Shield, at least when used in hot, dry conditions. After looking into it, this person concluded that the solvents in the PremierArt Print Shield were so quick to dry that the coating was starting to solidify before hitting the print. Lascaux Fixativ, however, uses solvents that are less volatile and, thus, may keep its acrylic in liquid form long enough to more effectively surround the pigment particles and lock them to the surface. Today I did a comparison of the two sprays on UltraSmooth. I sprayed two test strips of UltraSmooth with 3 coats of the 2 products. The dmax started at 1.61. The test strip sprayed with PremierArt Print Shield had a dmax drop to 1.52 and 1.51. The test strip sprayed with Lascaux Fixativ had the dmax drop to 1.59 and 1.57. Perhaps related to this is my finding that PremierArt Print Shield is more effective at reducing the bronzing on glossy papers than is the Lascaux. With Lascaux I'll have to find a different procedure than my usual 3-4 quick, light sprays. It appears to me that the PremierArt Print Shield tends to stay on the surface of the print more, whereas the Lascaux appears to soak in more. The Lascaux solvents are, apparently, less volatile -- they evaporate slower. In addition to the chemist's conclusions in this regard, I simply can smell the Lascaux on the print longer. I might add that the drop in dmax does not happen with all matte papers. UltraSmooth is the paper that I like and use frequently that definitely does have a tendency to have this happen. From now on, I might be using Lascaux on it instead of PremierArt Print Shield. (The Lascaux is also the Rohm & Haas B72 formula that is most highly thought of by the conservation industry.) Paul www.PaulRoark.com
2004-06-11 by Mr_Misty_44
Paul,
Do you notice any difference in apearance between the print
sprayed with Lascaux and Print Guard. I've been using Priemier Art
Print Shield and have not been able to detect its presence after
spraying. Can you "See" either of the other products, any gloss, Etc..
Also, do you know what the Laquer formula is for either the Print
Guard or Print Shield.
John H
<paul.roark@v...> wrote:
prints for
will show
drop in
> >dMax.
Shield,
(though the
that the
conditions. After
PremierArt
solidify
that are
enough to
> surface.
sprayed two
dmax started
dmax
had the
is more
Lascaux.
3-4
more. The
slower.
can smell
papers.
definitely does
Lascaux
Rohm &> Haas B72 formula that is most highly thought of by the conservation > industry.) > > Paul > www.PaulRoark.com
John, >Do you notice any difference in apearance between the print >sprayed with Lascaux and Print Guard. I do see the dmax advantage of Lascaux in side-by-side test strips. Other than that they look the same to me. > I've been using Priemier Art >Print Shield and have not been able to detect its presence after >spraying. Can you "See" either of the other products, any gloss, Etc. To me, when I just do 3 light coats, the images look the same as the unsprayed prints. The paper white, for example, is unchanged. On many matte papers the dmax is also unchanged with light spraying. >Also, do you know what the Laquer formula is for either the Print >Guard or Print Shield. No, I don't know what they are made of. The Premier Imaging people call it a "lacquer" instead of an acrylic, but I often think of the term "lacquer" as just generic. Many of the traditional lacquers, such as nitrocellulose lacquer, yellowed. Acrylic, on the other hand, has about the best reputation for not yellowing. So, when a company tells me the product is a "lacquer" and not acrylic, this is not really a positive statement. On the other hand, the Wilhelm, de facto, stamp of approval for PremierArt Print Shield does carry some weight with me. It and Lascaux (B72 formula) are at the top of my list (PremierArt to reduce bronzing on glossy paper, and Lascaux for the matte papers). Grumbacher Tuffilm is just down a notch, having a nozzle that is not as good, especially for glossy prints; for matte papers the nozzle is fine. (The Grumbacher fixative is cheap and readily available, but I have not tested it for dmax decrease on UltraSmooth or Scrapbook.) There may be other great clear coats, but if they are unknown proprietary formulas, they are, I believe, going to need some age testing to be accepted in the fine art field. Paul www.PaulRoark.com ____________________________ --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...> wrote: > Steve wrote: > > >I have been using Lyson Print Guard (same product) on my HPR prints for > >framing without glazing. It looks fine but a measured step wedge will show > >a significant shift in density post spraying, including a large drop in > >dMax. > > > I've seen and measured this with UltraSmooth and PremierArt Print Shield, > which, as you note, appears to be the same as Lyson Print Guard (though the > Premier Imaging people deny they are the same). > > Perhaps related to this is the observation by another forum member that the > surface of smooth prints can feel a bit gritty after spraying with > PremierArt Print Shield, at least when used in hot, dry conditions. After > looking into it, this person concluded that the solvents in the PremierArt > Print Shield were so quick to dry that the coating was starting to solidify > before hitting the print. Lascaux Fixativ, however, uses solvents that are > less volatile and, thus, may keep its acrylic in liquid form long enough to > more effectively surround the pigment particles and lock them to the > surface. > > Today I did a comparison of the two sprays on UltraSmooth. I sprayed two > test strips of UltraSmooth with 3 coats of the 2 products. The dmax started > at 1.61. The test strip sprayed with PremierArt Print Shield had a dmax > drop to 1.52 and 1.51. The test strip sprayed with Lascaux Fixativ had the > dmax drop to 1.59 and 1.57. > > Perhaps related to this is my finding that PremierArt Print Shield is more > effective at reducing the bronzing on glossy papers than is the Lascaux. > With Lascaux I'll have to find a different procedure than my usual 3-4 > quick, light sprays. > > It appears to me that the PremierArt Print Shield tends to stay on the > surface of the print more, whereas the Lascaux appears to soak in more. The > Lascaux solvents are, apparently, less volatile -- they evaporate slower. > In addition to the chemist's conclusions in this regard, I simply can smell > the Lascaux on the print longer. > > I might add that the drop in dmax does not happen with all matte papers. > UltraSmooth is the paper that I like and use frequently that definitely does > have a tendency to have this happen. From now on, I might be using Lascaux > on it instead of PremierArt Print Shield. (The Lascaux is also the Rohm &
2004-06-16 by Steve Kale
Paul Thanks for this. I have ordered some Lascaux. Did you find much shift across the other steps? Wondering if it is necessary to linearise a strip post spraying... Regards Steve
From: "Paul Roark" <paul.roark@verizon.net> Reply-To: DigitalBlackandWhiteThePrint@yahoogroups.com Date: Thu, 10 Jun 2004 21:46:15 -0700 To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Subject: RE: [Digital BW] Re: Laquer on matte prints? Steve wrote: >I have been using Lyson Print Guard (same product) on my HPR prints for >framing without glazing. It looks fine but a measured step wedge will show >a significant shift in density post spraying, including a large drop in >dMax. I've seen and measured this with UltraSmooth and PremierArt Print Shield, which, as you note, appears to be the same as Lyson Print Guard (though the Premier Imaging people deny they are the same). Perhaps related to this is the observation by another forum member that the surface of smooth prints can feel a bit gritty after spraying with PremierArt Print Shield, at least when used in hot, dry conditions. After looking into it, this person concluded that the solvents in the PremierArt Print Shield were so quick to dry that the coating was starting to solidify before hitting the print. Lascaux Fixativ, however, uses solvents that are less volatile and, thus, may keep its acrylic in liquid form long enough to more effectively surround the pigment particles and lock them to the surface. Today I did a comparison of the two sprays on UltraSmooth. I sprayed two test strips of UltraSmooth with 3 coats of the 2 products. The dmax started at 1.61. The test strip sprayed with PremierArt Print Shield had a dmax drop to 1.52 and 1.51. The test strip sprayed with Lascaux Fixativ had the dmax drop to 1.59 and 1.57. Perhaps related to this is my finding that PremierArt Print Shield is more effective at reducing the bronzing on glossy papers than is the Lascaux. With Lascaux I'll have to find a different procedure than my usual 3-4 quick, light sprays. It appears to me that the PremierArt Print Shield tends to stay on the surface of the print more, whereas the Lascaux appears to soak in more. The Lascaux solvents are, apparently, less volatile -- they evaporate slower. In addition to the chemist's conclusions in this regard, I simply can smell the Lascaux on the print longer. I might add that the drop in dmax does not happen with all matte papers. UltraSmooth is the paper that I like and use frequently that definitely does have a tendency to have this happen. From now on, I might be using Lascaux on it instead of PremierArt Print Shield. (The Lascaux is also the Rohm & Haas B72 formula that is most highly thought of by the conservation industry.) Paul www.PaulRoark.com Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See Group Topic, Rules and Guidelines in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. Yahoo! Groups Sponsor ADVERTISEMENT <http://rd.yahoo.com/SIG=1298urb97/M=285832.5035993.6164948.1793556/D=group s/S=1705019182:HM/EXP=1087015623/A=2178650/R=0/SIG=14drisgb3/*http://www.hou seholdfinance.com/ln/TrackingServlet?cmd_MediaCode=&fc=APS&mkt=000&mc=01PSYA YA004001B220000U0300L00300000> Yahoo! Groups Links * To visit your group on the web, go to: * http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/ * * To unsubscribe from this group, send an email to: * DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Uns ubscribe> * * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> . [Non-text portions of this message have been removed]
