C84 Mini-FAQ
2004-06-10 by dmcluckie
sl91911 wrote:
Don,
Can you please tell us precisely how you run the C82 to get these
results.
1. What inks do you put in each position
2. The precise names of the non-Epson papers you use
3. What you do to get your screen to match the print using, I
presume,
Photoshop CS
4. What if any settings you change when you change papers
In all the commotion you missed one thing, I don't have the printer
yet. I posted what someone who uses it had said. But I have saved
a few topical posts over the past few months. Here is what I
saved. [I will see if I can put this post in the files section of
this group, then it will be easy to steer someone to it.]
EZ Black & White by Paul Roark.
Just follow this link. Its about simple b&w printing. Nothing
complicated. Plain and simple. And cheap too!
http://www.inksupply.com/index.cfm?source=html/utez.html
Andre
[Hint: Follow the other links from that page for more info]
>I have an Espon C82 ... I was
>thinking of trying it for B&W prints using the EZ inks throug MIS.
>Is there someplace that describes or shows the differance in the
prints
>you can achieve by using various Nuetral and Warm combinations?
See the "Tones-Preview" page and file I have for the UT7 inkset.
It's at
http://home1.gte.net/res09aij/Tones-Preview.htm
The above URL has a downloadable .psd file that has layers on it
that you
can drag to an RGB version of a B&W file to preview the tones. The
C82 EZ
inks are "neutral/selenium" (may be just a bit cooler than dead
neutral on
EEM) and carbon tones. They are the same tones that the UT7 inkset
prints
with curves that are similarly labeled. So, the preview file at the
above
URL will give you an idea of what you'll be able to print with the
C82.
> Is there a way to achieve prints more on the cool side as well?
Moab Entrada Bright White paper or others that print cool will be
quite cold
with the "neutral" inks.
(I have not tried any canvas type papers in the printer.)
>I believe I've read that the c84 produces slighly better
results, ...
These machines under print the black ink with color position inks --
at
least with most paper type settings in the driver. This lowers the
dmax
somewhat. The C84 does not underprint the black ink with "Plain
paper"
selected. I just don't know if that is also true for the C82.
Other than
this, I don't think the C84 is better.
[disclaimer from Paul]
That file is really aimed at the UT7 inkset. I think if you have 2
neutral
carts installed and a warm one in the Y spot, you'll have tones that
are a
bit less warm than the the medium warm tone on the Preview file. A
warm
cart in the M spot is, I believe, slightly warmer than the medium
warm
preview. If all the spots are warm ink, you'll have the carbon tone.
You have a lot of flexibility with the ink positions. Also,
different
papers produce slightly different degrees of warmth or coolness. The
Preview file was matched to scans of Epson Enhanced Matte ("EEM").
The Epson C84 ink appears to be compatible with the EZ B&W inks.
I've
swapped carts with no flushing and had no significant clogs.
I just put tape over the outlets of half used carts.
K2,
You are correct. The EZ inks are the same in all the color positions
(unless you choose to warm it up a bit by putting a warm cart in Y
for some
warmth, M or C for more warmth). The chips are different for the C,
M, & Y
positions. That is the only difference.
[by now you should be getting an idea of who is the expert on this
combo]
Randy,
>So it sounds like can have a set of both carts and progressively
warm
>your image by how many warm carts you put in the color positions;
>black being always the same.
Correct.
> Since I am considering a purchase of
>the C-84, does it matter which order your progress through for more
>warmth, i.e. Y,C,M; or do all of the ink positions put the same
>amount of ink in the same places and therefore wouldn't matter
which
>order?
Yellow puts less ink in the midtones and highlights than. So, if
you find
"neutral" just a bit too cool, a warm ink in the yellow spot would
be the
first level (least dramatic) step in warming the image. Many people
like a
print that is just a hair warmer than the straight "neutral." As
such, I
felt that many would like the color of the print if a warm cart was
used in
this way.
>Is there some place that discribes this procedure in detail?
Doesn't
>sound like it is much more complicated than knowing which positions
>to progress through and some experimentation.
I'm not sure if MIS has it on their pages or not.
>Finally, is there a way to go colder than the neutral positions
other
>than using a "colder" paper, i.e. is there a colder ink we could
>progress through to get varying levels of cold, as with the warm
>carts? Maybe an ink from one of the other printers or create your
>own?
The paper (like Moab Entrada Bright White or Hawk Mountain Condor)
is the
easiest way to go colder. I have not mixed a specific ink for
colder. I'll
have to give it more thought to see if there is an easy way to mix a
new ink
-- but probably not. With a cold toner from another inkset you
could do it
with curves, but most don't want to mess with making such.
Thanks to the comments of several people in this group
I purchased an Epson C84 and the MIS EZ BW inkset (the
neutral set with the ebony black) and am pretty impressed
with the results.
Using the "stepwedge" images provided by Daniel Staver
(thanks) and the "Migrant Mother" image referenced by
someone else I printed images using the Epson cartridges
in both the color and black only modes and compared them
to the images printed using the MIS EZ inkset.
My opinion is that as far as smoothness of tones, the EZ
inkset places between the Epson BO and the
the Epson color print. With the BO print you can see
the dots in the mid tones where you can't with the
color print. With the EZ inkset you can just barely
see the dots in some places when looking very closely.
Colorwise, the EZ neutral inkset is quite consistent
and seems pretty neutral. The Epson BO print is somewhat
warmer whereas the Epson color ink print is a bit cooler
but inconsistent with the darker tones having a magenta
cast and the lighter tones having a green cast.
Overall, I am pleased with the prints using the
EZ inkset especially considering the price ($120 for the
printer and ink) and that you don't have to do anything
but print the image, no curves no nothing. You can't make
it much easier.
So far I have only printed on Epson matte paper, so I don't
know how it looks on glossy paper, but they suggest a
different black for the glossy paper.
[by Derry Bryson]
The C84/EZ prints well on glossy or semi-gloss using
the supplied Epson black, but the inks do bronze; so
you must spray or fix the image unless you like the
bronze look.
Don [Don Hill]
The most archival paper with this ink is the Epson PremierArt Matte
Scrapbook paper.
You might want to practice and test print on Epson Heavyweight Matte.
EEM= Epson Enhanced Matte, which I believe is "in-between" the other
two.
[Don M's notes]
[Paul says use "Plain Paper" settings in the driver:]
The C84 seems to print at a higher contrast than the C82. The C82
output
matches my CRT better, but the C84, with the driver contrast slider
pulled
down a bit to open up the shadows matches the LCD displays I have
better.
The C82 under-prints the black with color ink. So does the C84 most
of the
time. This lowers dmax. On EEM and PhotoRag it's still OK, but on
some
other papers it's marginal. The C84 on Plain Paper setting does not
under-print the blacks. As such, the C84 with Plain Paper setting
gets as
good a dmax as the more expensive printers. I have not been able to
test a
C82 to see if that is also the case with that printer. If someone
out there
can just print and compare some 100% black patches with EEM and then
Plain
Paper settings on EEM, we might be able to tell.
(I don't know about ink usage, I'd assume it is the same.)
[a testimonial by Matthew Born]
I picked up a C82 when Paul first made the EZ ink set. My plan then
was to
use it for the occasional glossy print using the photo K ink. I'd
been using
UT in my 1280 for matte prints, my primary need, for a while. Paul
then
reported he'd gotten nice prints in the C82 using the EZ color inks
along
with the original Epson 'durabrite' black ink. These prints would be
less
archival, of course (vs. the full EZ set), but I had no intention of
selling
prints off this machine, so I was intrigued. (And in truth the
durabrite
inks should be a big step up from regular dyes anyway -- I'd expect
these
prints to last a while under proper circumstances.) I figured it
wouldn't
cost anything to try this combo and -- if it worked -- I'd have a
nifty
little printer that could print on both glossy and matte. (Of
course, this
has all been superceded by UT2 and Paul's curves which permit
printing on
both surfaces with the Eboni black anyway...thus, my C82 is almost
never
used anymore). However, I gotta say -- that combination in the C82
produces
mind-bogglingly good prints. To think Epson claimed the 2200 would
make B&W
prints out of the box...the C82 with that ink combination kicks it
to the
curb, calls it names, and pours hot coffee over its head. In fact, I
can
only just barely see the difference between it and the 1280, at
least with
the durabrite K in there. All for about $125, including the EZ ink
purchase.
And with zero experimentation on my part.
I've thought about trying the media setting changes to see if I can
detect
any dmax difference on the C82 (re: under printing w/color) but have
not
done so. I'll try it today. Of course, I am still using the
durabrite K in
there, so I dunno how my results are skewed anyway. If I recall the
conversations back then correctly, I'm getting a little better dmax
from the
durabrite black as it is.
As for other papers, the only things I've run through it are EEM,
photo rag,
Epson Premium semigloss, and Ilford pearl. All have fed and printed
perfectly. And even though it sits literally for two or three weeks
without
use it never clogs.
IMHO, this should absolutely be the break-in way to digital B&W for
almost
everyone. For lots and lots of people they'll never need anything
more. It's
painfully easy and the results are amazing -- no qualifications,
either --
just plain first-rate.
And I must once again thank Paul Roark for his tireless work and
astonishing
generosity. The joy of photography has returned for me because the
digital
workflow actually works now...I shoot film, process it, scan it, and
print
using UT inks. Step four had been the obstacle for a long time. No
longer is
A&I siphoning off my son's college fund...
Matthew Born
Any more questions, let's hear 'em! I'll put this together as a
good starting point FAQ.
Assembled by Don M, "I know nothing about the C84" :)
