Jules,
> How do we end up?
>Mixing toxic chemicals that stink to high heaven.
>... and where can I get some glycerol?
It's readily available. Even Photographer's Formulary has it. See
http://www.photoformulary.com/DesktopModules/StoreSearchResult.aspx?Search=g
lycerol&tabindex=2&tabid=9&mid=37&langId=0
And don't worry, it doesn't smell bad.
________________
<paul.roark@v...> wrote:
> Ernst,
> If you look at the material safety data sheets, the UC inks often
have
> mostly water and glycerol in them. Some have glycols and probably
all have
> "proprietary organic materials" in addition to the "proprietary
dyes and
> pigments." My goal was to make a bare-bones supplemental base that
would at
> least not be incompatible with the existing Epson base (which they
will not
> provide to us hackers).
> The main things that are missing in the simple glycerol water base
appear to
> be wetting agents and binders. With the Epson pigs, however, the
acrylic
> coating is the main binder, so that is not missing. (That would
not be the
> case with an Eboni diluting, for example.) For a cleaning fluid, a
binder
> is also not helpful.
> I experimented with wetting agents and even some de-foamers that
are said to
> be better than glycol (like isopropyl alcohol), and I could not
tell that
> there was any difference in the Epson ink dilutions (except the
alcohol in
> some of the mixes smelled bad). I used to prefer Kodak Photo Flo --
a
> glycol & alcohol mix similar to what is often used in the inksets --
and it
> looks like whatever Epson is using also works just fine at half the
strength
> they use.
> From my perspective, the benefit of not putting anything more in
the mix is
> that the risk of incompatibility is virtually eliminated. All I'm
adding is
> a chemical that is already a major part of the mix.
> If you are interested in a cleaning solution, a bit of Photo Flo
(try 0.2%)
> could be added to give the base the wetting agent characteristics.
> I'll be curious how the fade test of my UC-based mixes looks. If
one is
> close to competitive, I'll refine it and publish the formula. That
way
> there will be an Epson-based inkset out there that would always be
available
> to everyone. Some who think that third party pigs are somehow
inferior
> might prefer an Epson-based formula.
> Paul
> www.PaulRoark.com
> ______________________________
> From: Ernst Dinkla [mailto:E.Dinkla@c...]
> Sent: Saturday, July 03, 2004 1:08 PM
> Subject: Re: [Digital BW] Blackless printing
> Paul Roark wrote:
> > I'm not sure that is the case. The Eboni is the one that is much
more
> > neutral than the MIS version. I have a test inkset made with UC
inks and
> > that inkset's "warm-carbon" curve seems to be more neutral than
the MIS
> > version. (Perhaps it's my new base -- real complex: distilled
water and
> > glycerol.)
> Paul,
> Is that all, distilled water and glycerol ? I have a 10000CF
> now and it will be converted to MIS 7600 but I think a cleaning
> has to be done in between. If that base would do the trick then
> I'm less worried.
> John Nollendorfs mentioned glycerol as a component of the Ilford
> Archiva inks ages ago. It has the thixotropy and the retarder
> qualities to keep pigments suspended and nozzles open.
> Ernst
they are often being updated.
page.
them short.
membership without notice.
the membership.
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND
Yahoo! Groups Links
