Using MIS UT inks, Roark curves - request help
2004-07-02 by adolphamster
I have been trying to use the Roark UT2 curves with my Epson 1280
printer and MIS UT2 inks, with mixed results. I am using Picture
Window inasmuch as this program seems to handle the *.acv files well.
(Or is this an unwarranted assumption?)
	The following is the "workflow" I am using:
Open PW (Picture Window)
Import a black and white image in 16 bit B&W format
Perform:
	Transformation ->Convert to 24 bit color
	Transformation -> Color -> Curves
	Option : Reset
	Option : Load
		select  Photoshop Curve files
		Select: UT2*.acv file (here I select from among the 4 options: dark
sepia, light sepia, carbon, neutral)
	Apply (with RGB color space)
	I then print using: Photo Enhance
		Tone: vivid
		Effect: sharpness
	I seem to get "reasonable" results with the carbon and neutral files
(i.e., the carbon is slightly warmer than the neutral). But the light
and dark sepia results are very disappointing: the detail in the image
is severely compromised, the prints are muddy and both sepias seem to
have about the same value - rather light).
	I'd appreciate suggestions? Or am I asking too much of the Roark
curves with this system?
	Thank you.
RE: [Digital BW] Using MIS UT inks, Roark curves - request help
2004-07-02 by Paul Roark
With curves, you must use "No Color Adjustment."
For UT2 & UT7 information, curves, and settings see:
http://home1.gte.net/res09aij/
______________________________
Sent: Thursday, July 01, 2004 7:43 PM
Subject: [Digital BW] Using MIS UT inks, Roark curves - request help
Perform:
	Option : Reset
	Option : Load
options: dark
		Tone: vivid
		Effect: sharpness
	Thank you.
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
Re: [Digital BW] Using MIS UT inks, Roark curves - request help
2004-07-02 by islandbuck2
Hi Paul, yep got it set to "No Color Adjustment" in the driver.  I
think OS, Photoshop version and all the other mind bending variables
with particular installations is coming into play here.  The lack of
coherent permanent standards in this industry I believe is puts this
industry on very shaky ground with people that depend on this for a
living.  With traditional processes I had a well laid out, finite set
of variables in my mind.
- The Particular films curve
- Exposure at time of capture
- Paper Curve
- Exposure of Paper
A little simplistic but no so really.  The whole process could be
easily abstracted in my mind because semi-permanent standards by the
industry were adhered to.  What will become of my RAW files in twenty
years.  I personally believe this "lack of standards" is in fact
the "milk cow" of this industry.  Knowing this makes me appreciate
your efforts all the more.  Thanks Paul.
I don't think I should worry about this any more.  My prints are
coming out superb printing from Picture Window with the Epson drivers
sliders.  Thanks again.
> Paul
> www.PaulRoark.com
> From: adolphamster [mailto:dolph@m...]
well.
> Perform:
> 	Option : Reset
> 	Option : Load
> options: dark
> 		Tone: vivid
> 		Effect: sharpness
neutral files
light
to
Roark
> 	Thank you.
resources as
wish to
this same
> page.
to keep
> them short.
flames.
B&W
removed from
> the membership.
Owner and
section:
PRINT
LIABLE TO YOU
EXEMPLARY
THE  "OWNER" AND
OF THE
INABILITY
ACCESS TO OR
CONDUCT OF ANY
OTHER
When you said, "I then print using:
		Photo Enhance
 		Tone: vivid
 		Effect: sharpness"
I assumed "No Color Adjustment" was not checked.  In my Windows XP &
Photoshop setup the "No Color Adjustment" does not appear when those things
are checked.
>I think OS, Photoshop version and all the other mind bending
>variables with particular installations is coming into play here. ...
>Perhaps so.
>sliders.
Time to declare victory and withdraw.
2004-07-03 by islandbuck2
I think you have me confused with another post I never used Photo
Enhance.
> 		Photo Enhance
>  		Tone: vivid
>  		Effect: sharpness"
those things
> are checked.
here. ...
> >Perhaps so.
drivers
> >sliders.
> Paul
> www.PaulRoark.com
