Re: [Digital BW] Digest Number 2365
2004-07-17 by sandersm@aol.com
Eric, I had exactly the same thing happen in reverse. Mine worked with rolls. When I tried to select sheet feed, I had all the same things happen -- print spools, printer says printing, nothing happens. I'm getting this result with the Epson driver as well. I'm wondering whether installing the GIMP software somehow goofs up the process. I'm running OS X 10.2.8 with my 7600, if it matters. Sanders McNew In a message dated 7/17/04 8:24:05 AM, Eric writes: > I am getting absolutely beautiful results using Roy's great QTR, but so > far only on sheet paper with existing page sizes... > > Has anyone figured out a way to get roll paper working on the 7600 > using Panther 10.3.4 and Gimp 4.2.5? When the printer is loaded with > roll paper, set to either roll-auto-cut or roll-no-cut, and saying > "ready" I send a job to the printer, and the whole job spools and says > "printing" but the printer just sits idle and "ready" and never does > anything. I am choosing the roll option in the Gimp driver. Everything > seems in order, but nothing happens. In sheet mode everything is fine. > I have also tried all the other combinations: roll paper set at the > printer but sheet set in the driver and the other way around as well... > all with no success. I'd send a really nice bottle of wine to anyone > who can help me fix this problem! > > > > [Non-text portions of this message have been removed]
