UltraChrome-based variable-tone inkset
2004-07-20 by Paul Roark
This is my 6-14 formula for the UC-VT (for the 2200) I recently tested.  It
is very similar in its behavior to UT7, but the formulas are different.
With sliders set to 0, the 50% patch of an EEM print had C,M,Y = .60, .61,
.60.
The base:  4 parts distilled water and 3 parts glycerol.  (I used Kic
technical grade.)
(In the past, I've had trouble finding a base that worked well with the UC
inks.  The simple base I used for this inkset does the job and anyone can
make it.)
Blue used in mixing:  50% UC M, 50% UC C.
K position:  I prefer Eboni.  Epson UC matte black would also work.
LK position:  UC LK, no changes.
C position:  70% UC PK, 30% UC LK.
LC position:  52% UC LK, 48% base.
M position:  30% blue, 40% LK, 30% PK.
LM position:  30% LK, 10% blue, 60% base.
Y position:  88% LC, 7% Y, 5% M.
This is not necessarily a final formula, but it's close and works.  I had no
clogging or other problems with these experimental inksets.  (Nor do I have
clogging problems with MIS inksets.)
Re: [Digital BW] UltraChrome-based variable-tone inkset
2004-07-20 by Ernst Dinkla
> technical grade.)
Paul,
What is the risk of technical grade glycerols bringing
fungi/bacteria in the ink mix ?
A friend had that kind of trouble with MIS 7600 inks in two
9600's at some point and we solved it by filtering with 9000
damper sieves and adding some drops of fungicide.  I don't know
whether that base was glycerol but it is likely to be similar.
Ernst
RE: [Digital BW] UltraChrome-based variable-tone inkset
Ernst,
>>(I used Kic technical grade.)
>fungi/bacteria in the ink mix?
I don't know.  I used it because for small volumes it was cheaper.  See
http://kicchemicals.com/995tech.htm for the description of their "technical
grade" glycerin.  They also have very high grade versions.
That is disappointing to hear.  I think most of these inks include some
agent to suppress fungus, etc.  I'm assuming that the amount of original
Epson ink in the mix will still have enough to do the job in most
circumstances.  After all, they must design the inks for the worst possible
storage and use situations.
I made a batch with some isopropyl alcohol, which, among other things, is
supposed to help.  I found no differences in printing, except I didn't like
or want the smell.  If fungus is a problem, that might be one way to deal
with it, however.
I'm curious about the filtering.  The IB-FS mix is going to need better
high-shear mixing and filtering before it'll be acceptable for large format
printing.  (The desk-top printer carts are easy.  It's the large,
un-agitated carts where the problems are showing up.)  I'm hoping to try to
design ways of doing this that will open the total pigment market to
darkroom hackers like me (and artists who want to design their own color
palettes).  The commercially-available products I've found so far are not in
that category, in my view.  So, affordable 1 or 0.5 micron filters that
don't soak up lots of (costly in low volume batches) ink are on the list of
things to find.  The damper filters and MIS's large format CFS filters could
be possible solutions to this issue.  As a practical matter, I might just
recommend that every large format printer use a CFS for filtering and
agitation reasons.
Any thoughts on these issues are most welcomed.
2004-07-20 by Carl Schofield
I thought about using a syringe filter when drawing up bulk ink for
re-filling carts (particularly bottom filling).  Something like these,
which come in different filter areas and pore size:
http://www.hcl-intl.com/mall/more.asp?fmmore=12549
What would be the best pore size to use?
> list of
> could
> just
> agitation reasons.
> Paul
> www.PaulRoark.com
> agitation reasons.
Strange enough you will find more about filters at the Schleicher
und Schuell site, the company that owns Hahnemuhle.
http://www.schleicher-schuell.com
(they are now even in microarray technics I see)
The differences between the filters are size, particle size and
their (non)hygroscopic behaviour. I only ordered some samples and
they didn't work alright with inkjet inks. Can't tell you what
you actually should use but there's an American S&S subsidiary
that could. The Epson dampers were not that expensive and the
inks were already filtered but contaminated later on (fungi,
bacteria) so flow was not that difficult. That's stainless steel
mesh, very tightly woven.
You probably need several filters after another with the
possibility of backflush to get any results. We used a vacuumpump
with an extra empty (wine) bottle in between to pull the liquid
through. If you keep the feeding jar low and switch the pump off
from time to time then there's some backflush. As a last step it
may be better to use one of the Epson damper sieves as that's the
final size you will encounter in practice.  Air has to be taken
out as well, the vacuum can do this, additional nitrogen bubbles
can take out the rest, don't know how serious this is but it has
been mentioned before in inkjet ink manufacturing.  John
Nollendorfs might help you with better information, he made the
Wide Spectrum inks based on Ilford's Archiva dye. And he
mentioned glycerol then.
CFS systems like the one I have made for the 9000 and the 5000
(direct to the internal inklines) do not solve the pigment
settling.  It can be better controlled if the tube in the bottles
is 2 cm above the bottom but that's still no guarantee that it
will work without problems. If gallons a year are used on one
printer then it becomes different.  The big carts and especially
the 9600 carts are better in practice with lower throughput, you
can shake them regularly and the 9600 have seals that will not
wear as fast from taking them out.  Micro organisms get into the
CFS systems easier than in carts.  I wouldn't recommend an extra
filter other than the original damper in any ink supply system.
It could be different for the desktop printers where the
filtering function in the cart is based on the content of one
cart only and the larger sieves of the wide formats could act as
a first filter in the CFS.  For that reason I once send a 9000
damper to Eddie Matejowsky (Eddie's Chip Hack) for his 2200 CIS
system. But the actual filtering should be done before printing
time and not at printing time.
Ernst
Carl,
These could be perfect.  I think I'll order 0.4 and 1.2 micron sizes and see
what happens.
I'm told the Epson head and damper filters are "1 micron."  I'm not sure how
accurate these statements are.  I don't want to clog these filters.  So, if
the Epson filter size truly is 1 micron, then I'm favoring 0.4.
It appears to me that 0.1 is a typical "disclosed" (query accuracy) target
size for many pigments.  Smaller particles are said to have higher gamut and
are easier to keep in suspension.  Larger particles are said to have higher
longevity, but they will descend faster.  I assume a bell-shaped curve with
a peak at about 0.1 micron.
In addition to the filtering, high-shear mixing might be needed first to
separate agglomerations.  (But I'm also wondering if filters can do this.  I
sometimes use my darkroom filter funnel to catch and then grind the large
"clunker" crystals in dry-packaged photo chemicals.)
For a high-shear mixer, a modified, cheap blender might actually be better
than most of the commercial units I've seen.  Foaming, mixing, and
dissolving air into the inks is a problem.  So, I might see if I can fashion
a floating lid for a cheap, small-volume blender.  This lid plus the use of
the standard one might also make mixing in a nitrogen atmosphere easier.
(Nitrogen is cheap, safe, and does not dissolve in water.  My chemist
brother says processing in a nitrogen atmosphere is rather common in the
larger chemical industry.  De-gassing and keeping air out of the ink in the
first place are issues.)
_____________________
> list of
> could
> just
> agitation reasons.
> Paul
> www.PaulRoark.com
they are often being updated.
page.
them short.
membership without notice.
the membership.
Moderators. See Group Topic, Rules and Guidelines in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND
MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  OWNER AND
MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
Yahoo! Groups Links
