Carl,
I am sure. I've worked with this paper for years and know it well. Did
the tongue test, printed to another printer with Piezo and got expected
densities etc.
You are right, it always pays to check the obvious things first.
James
On Jul 21, 2004, at 8:45 AM, Carl Schofield wrote:
> One other possibility.� I assume you are making these test prints on
> HPR and if so have you checked to make sure that you are printing on
> the correct (coated) side of the paper?
> On Wednesday, July 21, 2004, at 08:04� AM, James Haney wrote:
> > There are 7 wedges
> > The inks match their descriptions
> > the LK wedge is identical to the K wedge - both are the darkest.
> Both
> > 100% patches read 1.37
> > The cart says
> > ARC-T0347-QUT
> > MIS Ultratone Lt. Black
> > www.missupply.com (A0604)
> > On Jul 20, 2004, at 11:16 PM, Roy Harrington wrote:
> >>� Hi James,
> >>� This profile looks good.� (note that the K determines the text
> >> areas).
> >>� You should have a page with 7 step wedges and labels.� Right?
> >>� What do all the ink look like?� Do they match visually with the
> ink
> >>� description for UT inks?�� LK (light black, the last line) should
> be
> >>� Eboni and it should be the darkest.� It sounds like you have
> actually
> >>� an Epson light-black ink.�� Is it warm tone?� similar to the other
> >> grays?
> >>� Does it say "Eboni" on the cartridge?
> >>� Roy
> >>� --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jhaneyzz"
> >> <jhaney@m...>
> >>� wrote:
> >>> Below is the ink descriptor I am using to print the ink pattern
> >> test page.
> >>> I am following the directions and advice of posters to the letter.
> >>> I am still getting black densities of 1.37 in the Light Black
> >> (Eboni) position.
> >>> I am starting to think I have a improperly marked or filled batch
> >> of ink from MIS
> >>� (This
> >>> would not be the first time) But I hold out hope that I am just
> >> missing something.
> >>> I am sure the inks are in the proper slots.
> >>> James Haney
> >>> #� quadtone curve descriptor file
> >>> # the printer name
> >>> # the curve name
> >>> #�� no spaces or special characters, except - or _� (dash or
> >> underscore)
> >>> PRINTER=QUAD2200
> >>> CURVE_NAME=2200-UT_test
> >>> CALIBRATION=YES
> >>> GRAPH_CURVE=YES
> >>> # number of inks must be 4, 6, or 7
> >>> # the ink limits are percentages
> >>> #�� usually they are all the same but they can be individually set
> >>> N_OF_INKS=7
> >>> DEFAULT_INK_LIMIT=80
> >>> LIMIT_K=
> >>> LIMIT_C=
> >>> LIMIT_M=
> >>> LIMIT_Y=
> >>> LIMIT_LC=
> >>> LIMIT_LM=
> >>> LIMIT_LK=
> >>> #� Describe Usage of each Ink: K,C,M,Y,LC,LM,LK
> >>> #��� All Inks of Printer must be listed
> >>> # Gray Partitioning Information
> >>> N_OF_GRAY_PARTS=5
> >>> GRAY_INK_1=K
> >>> GRAY_VAL_1=100
> >>> GRAY_INK_2=LK
> >>> GRAY_VAL_2=80
> >>> GRAY_INK_3=C
> >>> GRAY_VAL_3=44
> >>> GRAY_INK_4=LC
> >>> GRAY_VAL_4=22
> >>> GRAY_INK_5=Y
> >>> GRAY_VAL_5=8
> >>> GRAY_INK_6=
> >>> GRAY_VAL_6=
> >>> GRAY_INK_7=
> >>> GRAY_VAL_7=
> >>> GRAY_HIGHLIGHT=0.01
> >>> GRAY_SHADOW=0.01
> >>> GRAY_GAMMA=1
> >>> GRAY_CURVE=
> >>> # Toner Partition Information
> >>> N_OF_TONER_PARTS=2
> >>> TONER_INK_1=M
> >>> TONER_VAL_1=100
> >>> TONER_INK_2=LM
> >>> TONER_VAL_2=100
> >>> TONER_HIGHLIGHT=
> >>> TONER_SHADOW=
> >>> TONER_GAMMA=
> >>> TONER_CURVE=
> >>> # Unused Inks
> >>> N_OF_UNUSED=0
> >>> UNUSED_INK_1=
> >>> UNUSED_INK_2=
> >>> UNUSED_INK_3=
> >>> UNUSED_INK_4=
> >>> # the following is a special UltraChrome ink flag
> >>> # it copies the light-black curves to the light-cyan and
> >> light-magenta inks.
> >>> # this insures that the LC and LM inks are used to directly
> >> neutralize
> >>> # the color of the light-black.
> >>> # the color balance of inks is controlled by the LIMIT_... values
> >> above.
> >>> UC_NEUTRALIZER=NO
> >> Please visit the Group Homepage to check the Files, and other
> >> resources as they are often being updated.
> >> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> >>� If you wish to receive no emails or just a daily digest, or you
> wish
> >> to unsubscribe, please edit your Membership preferences by visiting
> >> this same page.
> >>� Please follow these basic guidelines:
> >>� - As threads develop, trim off excess portions of earlier
> messages to
> >> keep them short.
> >>� - Good manners are required at all time. No personal attacks or
> >> flames. Hostile, aggressive or argumentative users may be removed
> from
> >> the membership without notice.
> >>� - Keep your posts and threads related to the group topic of
> digital
> >> B&W printing. Users who persistently make off-topic posts may be
> >> removed from the membership.
> >>� - By posting on this forum you agree to abide by the group rules
> and
> >> guidelines, and to abide by the actions and decisions of the group
> >> Owner and Moderators. See �Group Topic, Rules and Guidelines� in
> the
> >> Files section:
> >> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
> >>� BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> >> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE
> �OWNER�
> >> AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> >> LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> >> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> >> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER
> INTANGIBLE
> >> LOSSES (EVEN IF THE� �OWNER� AND �MODERATORS� OF DIGITAL BW, THE
> PRINT
> >> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
> >> RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> >> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
> >> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY
> THIRD
> >> PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> >> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> >> Yahoo! Groups Sponsor
> >> ADVERTISEMENT
> >> <lrec_companion_043004.gif>
> >> <l.gif>
> >> Yahoo! Groups Links
> >> ����� � ����� To visit your group on the web, go to:
> >> ����� � ����� To unsubscribe from this group, send an email to:
> >> DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
> >> ����� � ����� Your use of Yahoo! Groups is subject to the Yahoo!
> Terms of
> >> Service.
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages to
> keep them short.
> flames. Hostile, aggressive or argumentative users may be removed from
> - Keep your posts and threads related to the group topic of digital
> Owner and Moderators. See �Group Topic, Rules and Guidelines� in the
> Files section:
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER�
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE� �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT
> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> ADVERTISEMENT
> <l.gif>
> � Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
