QTR 2200 with UT profile advice
2004-07-23 by jhaneyzz
I have finally achieved some good success with QTR on my 2200 usint MIS UT inks. The profile below gives me results that are very close to what I used to get with Piezotones on my 1160. before it went kaput. The only thing is, the prints are pretty warm. I need some advice from experienced users on how to increase the presence of cool toner. The thing is, I am already using very high defalut densities and can't really increase the ink limit of M (the cool toner) that much. I noticed that profies from other users have much lower ink limits than I seem to need to get a very dense black. I just pulled a print with the M density set to 100 and it was a bit cooler. Is my next step to use toner curves? James Haney # # quadtone curve descriptor file # # # the printer name # the curve name # no spaces or special characters, except - or _ (dash or underscore) # PRINTER=QUAD2200 CURVE_NAME=2200-UT-PR-neutral CALIBRATION=NO GRAPH_CURVE=NO # # number of inks must be 4, 6, or 7 # the ink limits are percentages # usually they are all the same but they can be individually set # N_OF_INKS=7 DEFAULT_INK_LIMIT=90 LIMIT_K=0 LIMIT_C= LIMIT_M= LIMIT_Y= LIMIT_LC= LIMIT_LM=0 LIMIT_LK= # # Describe Usage of each Ink: K,C,M,Y,LC,LM,LK # All Inks of Printer must be listed # # # Gray Partition Information # use ink names: K,C,M,Y,LC,LM,LK # N_OF_GRAY_PARTS=4 GRAY_INK_1=LK GRAY_VAL_1=100 GRAY_INK_2=C GRAY_VAL_2=49 GRAY_INK_3=LC GRAY_VAL_3=27 GRAY_INK_4=Y GRAY_VAL_4=6.75 GRAY_INK_5= GRAY_VAL_5= GRAY_INK_6= GRAY_VAL_6= GRAY_INK_7= GRAY_VAL_7= GRAY_HIGHLIGHT=6 GRAY_SHADOW=6 GRAY_OVERLAP= GRAY_GAMMA=1 GRAY_CURVE= # # Toner Partition Information # N_OF_TONER_PARTS=1 TONER_INK_1=M TONER_VAL_1=100 TONER_INK_2= TONER_VAL_2= TONER_HIGHLIGHT=1 TONER_SHADOW=0.01 TONER_GAMMA=1 # # Unused Inks # #N_OF_UNUSED=02 UNUSED_INK_1=LM UNUSED_INK_2=K UNUSED_INK_3= UNUSED_INK_4= # # the following is a special UltraChrome ink flag # it copies the light-black curves to the light-cyan and light-magenta inks. # this insures that the LC and LM inks are used to directly neutralize # the color of the light-black. # the color balance of inks is controlled by the LIMIT_... values above. # UC_NEUTRALIZER=NO LINEARIZE="0.04 0.11 0.19 0.29 0.37 0.46 0.56 0.63 0.71 0.79 0.87 0.95 1.01 1.07 1.12 1.17 1.24 1.33 1.43 1.50 1.58"
