Rendering intent when converting to RGB?
2004-08-08 by peterzakos
I am still on the steep slope of the digital learning curve having
spent quite a few years in the traditional darkroom.  I would
greatly appreciate if someone could help me out by answering a
newbie question: Which rendering intent should I select in PS when
converting a grayscale file to Adobe RGB prior to printing using
Paul Roark's workflow?  Also, should I select black point
compensation?  Many thanks in advance for your help. Peter.
RE: [Digital BW] Rendering intent when converting to RGB?
2004-08-09 by Paul D. DeRocco
> From: peterzakos [mailto:peterzakos@...]
Rendering intent affects primarily the most saturated colors, so if you're
starting with a grayscale image, it doesn't matter. There's one obscure
exception: if your B&W image is already in RGB mode, and you use Absolute
Colorimetric to convert to a different RGB color space with a different
white point, it will give you unequal R, G and B values in an effort to
preserve the white point. But for photos, you normally only deal with
Relative Colorimetric or Perceptual anyway.
Black Point Compensation only matters if the conversion involves a device
color space where the value 0,0,0 doesn't represent a theoretical perfect
black. When converting between two abstract color spaces, this setting has
no effect.
