QTR help needed- problem with networking
2004-08-13 by nnmmaa123
I am trying to install QTR on a PC running win2K. Win2K seems NOT to
be the problem. The problem is that I do not have an ethernet card or
a network. Files submited to the RIP produce an error message to the
effect that the network location cannot be found. Has anyone found a
workaround. BTW running the QTR while connected via dial-up does not
work for me. In fact, the network connection is disrupted by
submitting a file to the RIP!
W-QTR "Unable to write raster data to driver" error
2004-08-16 by Ernst Dinkla
After removing an older W-QTR beta + Quad2200 and installing the
latest W-QTR beta + Quad9600 + QTRgui 0.4 a problem appears that
I can't fix.  "Unable to write raster data to driver" error from
I guess ImagetoRaster appears. Probably related to the size of
the print I think.
Ernst
Re: W-QTR "Unable to write raster data to driver" error
2004-08-16 by gphilpott2003
Ernst,
I downloaded the Windows QTR beta 3 for the 9600 and there was a
small typo in the print-9600.bat.
The line:
set CURVE1=UC-EEnhMatte-warm-1set CURVE2=UC-EEnhMatte-coolSe-1
needs to be...
Once I separated these two lines, I had no further problems except
for some vertical banding that I am trying to get rid of.
Hope this helps.
Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
> the print I think.
> Ernst
Re: [Digital BW] Re: W-QTR "Unable to write raster data to driver" error
gphilpott2003 wrote:
> Ernst,
> The line:
> needs to be...
> Hope this helps.
> Greg
Greg,
I had seen that one and changed it but that didn't take out the
error I'm writing about.
W-QTR beta3, 9600, QTRgui, XP pro.
A friend with the same setup is printing after I advised him how
to set it up :-)  Wonder whether the 2200 setup with QTRgui that
I had installed before left something in registry or whereever.
Ernst
>>Ernst,
>>The line:
>>needs to be...
>>Hope this helps.
>>Greg
> Greg,
> Ernst
Well it is the "sharing" on the Epson driver that has to be
renewed to get the path known to QTR etc. I had changed the name
from Quad2200 to Quad9600 and the system has been restarted in
between but that probably doesn't do it. Now I changed the name
to something odd, apply button and then changed it back again to
Quad9600, apply button and now it works again. Can't believe it
that it was just that.
Ernst
Ernst,
I am curious to know if you get banding with your 9600.  Mine shows
up in clear skies.  (Not so much in detailed areas)  I suspect it
has to do with the settings informing the printer to print
bidirectional instead of unidirectional.  I am waiting to hear a
reply from Roy on that.  I was just curious to see if you had a
similar problem.
Greg
RE: [Digital BW] W-QTR "Unable to write raster data to driver" error
2004-08-16 by Stephen Billard
This error also occurs if the printer share name is not correct. With
version 0.4 of QTRgui, the name could not have a space in it. This is fixed,
download a newer version from www.sbillard.org\Shareware\QTRgui.htm.
-Stephen
 www.sbillard.org/Stephen
> From: Ernst Dinkla [mailto:E.Dinkla@...]
> Sent: Monday, August 16, 2004 4:08 AM
> Subject: [Digital BW] W-QTR "Unable to write raster data to
> driver" error
> the print I think.
> Ernst
> Make a clean sweep of pop-up ads. Yahoo! Companion Toolbar.
> Now with Pop-Up Blocker. Get it for free!
> http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/ucIolB/TM
> If you wish to receive no emails or just a daily digest, or
> you wish to unsubscribe, please edit your Membership
> preferences by visiting this same page.
> - As threads develop, trim off excess portions of earlier
> messages to keep them short.
> - Good manners are required at all time. No personal attacks
> or flames. Hostile, aggressive or argumentative users may be
> removed from the membership without notice.
> - Keep your posts and threads related to the group topic of
> digital B&W printing. Users who persistently make off-topic
> posts may be removed from the membership.
> - By posting on this forum you agree to abide by the group
> rules and guidelines, and to abide by the actions and
> decisions of the group Owner and Moderators. See "Group
> Topic, Rules and Guidelines" in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL
> BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE
> THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
> YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT,
> INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN
> IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE
> THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED
> ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW,
> THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO
> THE DIGITAL BW, THE PRINT YAHOO GROUP.
RE: [Digital BW] Re: W-QTR "Unable to write raster data to driver" error
None of these programs put things in the registry. QTRgui uses an INI file,
delete it and things will start from scratch.
-Stephen
> Ernst
> Ernst,
> similar problem.
> Greg
Greg,
I have to disappoint you, all my QTR setups are "dry" ones till I
can use 9000/9500 curves to drive the UT VM 9000 that I have.
Today I actually linearised the custom Wasatch SoftRip / 9000 UT
VM combination again so I can continue B&W printing  that way.
The friend who got it running today is very satisfied with the
9600 QTR driver. Finer detail than with his 9000 UT VM and Paul's
curves. Qimage preprocessing too. He will compare the 9600
results with the 9000 driven by QTR later on but my guess is that
the 9000 will be sold. Will ask about any banding. His fee is on
its way to Roy.
Ernst
2004-08-17 by Kemal Delic
Ernst,
Would you sell your Epson 9000 just because of sharpness
difference? I compared the tests on:
 http://harrington.com/dotscans/dotsdots.html
and I couldn't se the difference between Epson 7500/9000 and
Epson 7600.
This week I am going  to pick up a very little used Epson 9000.
It shall cost me 7500 swedish kronas ( $1000 ),  including my
petrol costs. I want to use it for quadtone printing. I am worrying
now, am I doing something wrong?
Kemal
Ernst Dinkla wrote:
>Greg,
>its way to Roy.
>Ernst
2004-08-17 by Ernst Dinkla
Kemal Delic wrote:
> Ernst,
> Epson 7600.
> Regards,
> Kemal
Kemal,
Nothing to worry about.  But be careful with the ink change that
no dye/UT contamination happens.
First of all it isn't my 9000 and my 9600.  I am happy with my
9000 loaded with UT VM and the way I can drive it now with the
Wasatch SoftRIP and I'm expecting even better results with Qimage
+ QTR.  My customers love the results so far. I have no 9600
either and do not intend to buy one, instead I have bought a
secondhand 10000 for color.
My friend has far more work and used to print with three 9000's.
He now has two 9600's + one 9000 converted to UT VM.
The last was only used with Paul's curves from PhotoShop and not
yet with QTR + Qimage so he hasn't compared output of the 9600
with the same driver as he used on the 9600. It could well be
that the 9000 performs as good or better with QTR but then he has
two printers for that kind of work while the need for B&W doesn't
require more than one. It isn't clear yet what he will do but he
still has the two other 9000's with color inks that aren't used
often either. More of a luxury problem.
So a completely different situation to mine or yours and not yet
based on a checked quality difference either.
The price you're paying is nice if I compare it to a 9000 sold
here not long ago. 2000 Euro, but that one had one of my CIS
systems on it.
Ernst
Ernst,
Thank you very much for your help, I am not worrying
anymore. My neighbors are forewarned and some of them,
who are strong enough, shall help me to haul this thing
into my basement.
To be continued.
Kemal
Ernst Dinkla wrote:
>Kemal Delic wrote:
>>Ernst,
>>Epson 7600.
>>Regards,
>>Kemal
>Kemal,
>systems on it.
>Ernst
