QTR versus Imageprint
2004-08-16 by yaakovsinclair
How much better is QTR than using the black only option on the 2100? The results I have had seem pretty good to me. How much cheaper is QTR than Imageprint? Is Imageprint better - or just more expensive than QTR? thanks! Yaakov Asher Sinclair
2004-08-16 by Richard Sintchak
Someone on this list recently predicted the demise of BO printing now that QTR for windows is here. I'm a big BO fan but also missed the ability to do more intense shading like sepia, and some images might indeed be better with smoother highlights and mid-tones. BO is definitely not a perfect end-all for B&W printing on a 2200. I just happen to really like the look it gives. However, that said, I anxiously downloaded QTR for windows when it came available. After a few dozen or so prints I have to say it's a wonderful program and I may use it from time to time. It does give smoother tones in certain ranges but by virtue of that for the most part the QTR images do lack a bit of the BO "pop", which is one main reason I like BO so much. But for the images that do not work so well for BO I'll be considering QTR prints as an alternative. And of course the sepia ability of QTR is nice. As for how it compares to IP I've downloaded and used the demo version (with BIG watermarks across the prints) and do not have the extensive experience of IP to compare it well with QTR. My limited experience tells me that although IP might have more profiles and a bit more functionality the $500 or so for IP vs. the $50 for shareware QTR speaks for itself. Richard
----- Original Message ----- From: yaakovsinclair <sinclair@...> Date: Mon, 16 Aug 2004 16:37:55 -0000 Subject: [Digital BW] QTR versus Imageprint To: digitalblackandwhitetheprint@yahoogroups.com How much better is QTR than using the black only option on the 2100? The results I have had seem pretty good to me. How much cheaper is QTR than Imageprint? Is Imageprint better - or just more expensive than QTR? thanks! Yaakov Asher Sinclair
2004-08-16 by Tyler Boley
YOu have to compare apples and apples. The only relevant test would be to compare an ink setup and linearization in QTR similar to IP's. You can set up QTR so many ways, including BO and variations on it, IP like B&W setups, quads, any number of things. So saying it kills BO or IP methods is a non-starter. Assuming all else is equal, I'd give the nod to QTR for being so versatile, linearizable, and reasonably priced. BO users might be well advised to try it as well, assuming the normal Gimp otions are available, there are dither settings etc. that could impact your results and be worth comparing to Epson driver BO results. Tyler --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Richard Sintchak <rich815@g...> wrote:
> Someone on this list recently predicted the demise of BO printing now > that QTR for windows is here. I'm a big BO fan but also missed the > ability to do more intense shading like sepia, and some images might > indeed be better with smoother highlights and mid-tones. BO is > definitely not a perfect end-all for B&W printing on a 2200. I just > happen to really like the look it gives. However, that said, I > anxiously downloaded QTR for windows when it came available. After a > few dozen or so prints I have to say it's a wonderful program and I > may use it from time to time. It does give smoother tones in certain > ranges but by virtue of that for the most part the QTR images do lack > a bit of the BO "pop", which is one main reason I like BO so much. > But for the images that do not work so well for BO I'll be considering > QTR prints as an alternative. And of course the sepia ability of QTR > is nice. > > As for how it compares to IP I've downloaded and used the demo version > (with BIG watermarks across the prints) and do not have the extensive > experience of IP to compare it well with QTR. My limited experience > tells me that although IP might have more profiles and a bit more > functionality the $500 or so for IP vs. the $50 for shareware QTR > speaks for itself. > > Richard > > > ----- Original Message ----- > From: yaakovsinclair <sinclair@a...> > Date: Mon, 16 Aug 2004 16:37:55 -0000 > Subject: [Digital BW] QTR versus Imageprint > To: digitalblackandwhitetheprint@yahoogroups.com > > How much better is QTR than using the black only option on the 2100? > The results I have had seem pretty good to me. > How much cheaper is QTR than Imageprint? > Is Imageprint better - or just more expensive than QTR? > thanks! > Yaakov Asher Sinclair
