Banding using BO on the 2200
2004-08-16 by awsimages
I'm not sure what kind of banding this is but it is very subtle and consists of
graduated large bands 1-2 inches apart across the printed page.  I only noticed
it after awhile under bright light and then only on this one 13" print with a lot
of plain area like sky and sand.. I use Claytons BO setup on the Epson 2200 and
have made a dozen or so prints with no apparent banding. I'm normally very
pleased with the process.  Any ideas?
Art Schaefer
Re: Banding using BO on the 2200
2004-08-16 by Clayton Jones
Hello Art,
>consists of graduated large bands 1-2 inches apart across the
printed page.  I only noticed it after awhile under bright light
I had something similar happen once with a downloaded sample digicam
image from dpreview.com.  It had alternating light/dark bands about
1/4" wide across the sky area.  It only happened on that one image and
never again on anything else.  I never figured out what was causing it
(couldn't see anything on screen) and just figured it was something in
the image, not the printer.
Does it happen with a different size print?
Clayton
Re: [Digital BW] Re: Banding using BO on the 2200
2004-08-16 by Steve Kale
Art
What paper are you using?  The reason I ask is because I have had the effect
you are talking about when using Epson Archival Matt.  It looks as though
the paper was overly saturated and it dried in wide uneven bands.  It is
particularly bad in the heavy black areas of a print.  I have not seen it
using thicker paper like HPR.  So I wonder if you should try lightening the
ink load a little.
Cheers
Steve
> From: Clayton Jones <cj@...>
> Date: Mon, 16 Aug 2004 17:16:10 -0000
> Subject: [Digital BW] Re: Banding using BO on the 2200
> Hello Art,
> Regards,
> Clayton
