Something stopped the first print job on the list and the rest just
backed up behind it.
I suggest that you keep the printer dialog box for the 2200 open when
you are sending files to be printed, so you can see what's going on.
QTR, in the Windows version anyway, is very sensitive to the condition
of the file, although most of the errors have printed garbage rather
than stopped on my machine. Make sure that the file size (canvas in
Photoshop) is a bit smaller all around than the paper size: I reduce
by 1/2 inch; make sure there are no alpha channels (masks) in you
"flattened" image file and that it is an uncompressed TIFF. QTR should
open a black on white dialog box saying something like "your file is
being processed....." and, depending on file size, can be a bit slow
to start printing.
Have you got a network installed correctly or the Loopback adaptor?
The printer dialog box should tell you that the job is "spooling" and
run up some numbers in one of the columns as it does so.
Frank
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jymbo4600"
<jymbo46@b...> wrote:
> Hi....I have had a terrible time trying to get QTR to print on my
> 2200. I have updated to v.13 of the GUI and when I drag to the
> target it seems to send the file but nothing happens. So I went
back
> to make an important print on IP and it wouldn't print.
> I went into the IP spooler and there were all of my attempts to
> print with QTR, lined up and ready. Has anyone else had this
happen?
> Is there some crossover between the two RIPs? Or is it just my
total
> lack of programming skills?
> Jim Weekes
