Basics of Converting from Digital to B&W for quality results
2004-08-30 by Mike
I am new to the group and forgive me if I am doing this incorrectly,
and, if I am being lazy in just asking what you all probably know
quite well...or, maybe you all are looking for the better solution -
which is what this group is all about.
I have a Canon 10D and I typically shoot in jpeg, but I am about to
switch over to RAW (memory backup concerns). Anyhow, I have been
converting the image under mode from RGB to grayscale in photoshop
and then usually back to RGB for adjusting the color of a nice black
and white. When I print them, the images seem horribly soft and the
gradation is not satisfactory.
Can someone point me to some articles or instructions on how to get
great results from a digital file?
Best,
Mike Shampanier
http://www.MikeThePhotographer.com
Mike@...
Re: Basics of Converting from Digital to B&W for quality results
2004-08-30 by Johnny Eades
Hello Mike,
This is the procedure I use for conversion to BW:
1. Open it and convert it to Adobe RGB 1998 and at that point
create a duplicate image to show on the screen at the same time.
Move them around so you can see both images at the same time. Do all
of your final work on the copy image and rename it according to your
whim at the time. Convert the copy now to grayscale.
2. Using the original image, on the palette bar at the top right
select channels which will show 4 channels---Red Green Blue and the
composite RGB. If you left-click on the right panel of each color an
eye will appear on the left of the panel for that color and will
show how the image would look if only that color was used. This will
show up on the actual image as BW on the original image.
3. You may find that only one channel will give you the effect that
you desire or you may have to combine two channels or even all three
in different opacities and fills.
4. On the original image as you choose a channel to use, place the
pointer on the original image and Shift-A which will give a dotted
line around the entire image. Then Shift-C which will copy that
image channel into the clipboard. Left click on the copy image and
Shift-V, which will transfer the channel from the clipboard to the
copy image. Do this with the other channels as needed.
5. When the channels you want have been copied, close the original
image without saving any changes to it. That image is still a virgin
image in case you goof up on this and other attempts to work it up
in BW.
6. Now all work is done on the copy image and it is the one that
will be saved with a different name than the original. Left-click on
the layers tab on the palette bar and you will have layers for each
channel you copied plus one called background. At this point I
usually rename them with the name of the channel I copied (Red or
Green or Blue). In the case of the Rust In Peace truck, I used the
Green and Blue channels. I copy channels from the top down so my
Layer 1 is renamed Green and Layer 2 is renamed Blue. To rename them
Double-Left-click on the words Layer 1 for the first layer and type
in the name of the channel copied from the original image. In my
case it was Green and the other one was Blue. Now you have three
layers ---Green Blue Background. Eyes should be on the left side of
all the channels.
7. Now comes the magic!!!!! You notice the channels are stacked on
top of each other Blue over Green over Background. and up on the
upper portion of the channel window you have two sections
called "Opacity" and Fill" in percentages starting with 100%. Left-
click and hold on the layer that is the lightest (Green) and slide
it up to the same level as the darkest (Blue) and release. You now
have layers names of Green Blue and Background. I do this so the
lightest layer is on top so the darker portions can start showing
through as I lower the opacity of the top layer a little at a time.
8. It suited my aye at 61% for the Green opacity. You can do the
same for the Blue layer, but if you do; left click on the eye on the
Green layer so you can see the effect of Blue on Background; then
click on Green eye again to see the combined effect on all three
layers. Experiment till it suits your eye and desired effect.
9. Then click on Layer>Flatten image and now you have used channels
mixed to your liking.
10. Now set up your Proof. View>Proof Setup>whatever your choice for
proofing is that gets equality between the monitor and printed
image. A good way to determine your proof is to take an image you
have already worked up and make a straight print from it without any
further manipulation and compare it to the monitor. If the print is
darker or lighter than the monitor image the same process applies
for correction and proof profiling. With dried image in hand and
well lit compare it carefully to the monitor image.
11. This is the process to determine the correct proof setup for you
final printing of any image you work up. This will change if you
change inks or paper.
12. View>Proof Setup>Single left click on whatever is showing in the
Profile selection. This will bring up a menu of all proof profiles
on your computer that Photoshop uses. Start at the top and carefully
compare each one with the printed image making sure the
box "Preserve Color Numbers is Checked" if it is available.
Sometimes it won't be. When you select one from the list the list
goes away but the selection is highlighted in the profile selection.
Simply arrow-down on the keyboard till one of the examples does
match the finished and dried print you made for this image. Take
your time and preferably do this in a darkened room so ambient light
won't sway your decision. That way when you print in a lighted room
you won't be swayed by the brighter light and think something is
wrong. Save your choice with any name you can easily associate with
the paper choice and inks used so you can simply use it for all
images you print on that paper and with that inkset.
13. Print and enjoy the fruits of your labor, or discard and start
all over again. That's part of the learning process. It isn't cut
and dry--it's creative---it's fun---it's disheartening--it's
whatever it is--but it's photography at it's most challenging and
rewarding when it all comes together with the photographer.
Your friend in Photography,
Johnny
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mike"
incorrectly,
solution -
to
black
get
> Best,
> Mike Shampanier
> Mike@M...
2004-08-30 by Josh Freeman
Mike,
You can convert to b/w the way Johnny Eades described by extracting
the channels into layers and use opacity to blend them,
you can also use the channel mixer adjustment and click the monochrome
checkbox.
Or you can use the hue/saturation to desaturate, maybe click colorize
to get a tone.
Or you can use a gradient mask.
Or you can use Image/Calculations and mix 2 channels using blending
modes and opacity.
Or you can convert to grayscale in mode.
Or you can use the channels pallet and select one that looks good and
delete the other 2.
Probably more ways too.
Basically there are a ton of ways to make a grayscale image. It's just
a metter of finding the one that works best for you and for the image.
Alot of these techniques can be done in layer adjustments as well so
you still have the original layer, and also can be combined even. Some
methods work better for different images, some show more noise than
others.
As for the two problems you mention, gradients and softness, it's hard
to tell, are the images sharp before the conversion and soft on screen
after? Are they soft on screen at all before you print? What
resolution, printer/settings and paper/settings are you using to
print? One thing I wonder about converting to gray from an 8 bit jpg
file, is how much info is being discarded along with the color. Is it
enough to posterize a gradient?  Would converting to gray from a
higher bit depth RAW file result in a better image with better grads?
Are you sharpening your images before printing with the unsharp mask
filter? Alot of variables to consider I know, alot of times it may
just take expierimenting with different methods of striving for the
same result to get something that works better.
As for links, there are some techniques here:
http://www.outbackphoto.com/content/technique.html
Josh Freeman
> Best,
> Mike Shampanier
> Mike@M...
RE: [Digital BW] Basics of Converting from Digital to B&W for quality results
2004-08-30 by Stan Shire
Mike:
Conversion from RGB to Grayscale mode is probably the least effective
(qualitywise) way to do this.
A number of methods are much better and give significantly better
control over tonal values.
Many folks like the channel mixer. I've been using Convert To BW Pro
from the Imaging Factory
http://www.theimagingfactory.com/
Russell Brown also has a very nice procedure on his website
www.russellbrown.com
and Fred Miranda has a nice converter.
Hope this helps
Sent: Monday, August 30, 2004 12:55 PM
Subject: [Digital BW] Basics of Converting from Digital to B&W for
quality results
Best,
Mike Shampanier
Mike@...
Please visit the Group Homepage to check the Files, and other resources
as they are often being updated.
unsubscribe, please edit your Membership preferences by visiting this
same page.
- As threads develop, trim off excess portions of earlier messages to
keep them short.
membership without notice.
printing. Users who persistently make off-topic posts may be removed
from the membership.
guidelines, and to abide by the actions and decisions of the group Owner
and Moderators. See "Group Topic, Rules and Guidelines" in the Files
section:
"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
"OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA;
(iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE
PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW,
THE PRINT YAHOO GROUP.
Yahoo! Groups Links
2004-08-30 by Paul D. DeRocco
> From: Stan Shire [mailto:stan@...]
The real point is that, whatever tool you use, there is no fixed setting
that works for all pictures. Different pictures need different conversions,
depending upon the colors of things, and what needs to be contrasted.
Sometimes, I even layer two different versions, and then hand-combine them.
For instance in:
http://www.pbase.com/image/28559264
I used a different conversion for the Joshua tree itself, to make its
"leaves" stand out.
2004-08-31 by sandersm@aol.com
In a message dated 8/31/04 1:38:53 PM,
DigitalBlackandWhiteThePrint@yahoogroups.com writes:
> in BW.
> all the channels.
Or you could just shoot Tri-X.   Isn't this an awful lot of work to make
one's way back to what film has been doing for generations?   I don't mean to
reignite the old film/digital debate; there's no sense in arguing which is better;
they each have their strengths; they are different tools.   But it does seem
perverse that people embrace a new technology to mimic the appearance of an
old one.
Sanders McNew
2004-09-01 by dpullem
Sanders,
While this wan't my question, I wanted to thank you for such a
detailed-thorough explanation, it was very helpful to me.  Thanks for
taking the time to share your knowledge.
Don
<snip>
all
your
<snip>
