QTR Curves
QTR Curves
2004-09-06 by john dean
Does anyone have any QTR curves for Piezzotones for an Epson 7000 that I could buy
from you. I know Roy can linearize printers but I think he is way to busy to worry about
doing that and I don't have a densitometer.
john dean
How to linearize inks/printers; Was: QTR Curves
2004-09-09 by donbga
John,
that I could buy
I sort of have the opposite problem. That is I have a densitometr but
don't understand how to linearize a specific inkset-printer
combination. Where does one look for that information.
Don Bryant
Re: How to linearize inks/printers; Was: QTR Curves
2004-09-09 by John Vitollo
> I have a densitometer but
> Don Bryant
In the QTR folder open the CurveDesign folder. There's a folder called Eye-One that will
explain how to linerize with the Eye-One but the info could be used with densitometers
too.
QTR Curves
2006-03-18 by Vincent Orlando
Just wondering if anyone mighht have a set of QRT curves for the 7600
and MIS UT7 inks and HPR and or Entrada BW they might like to share as
I don't have a way of building my own.
Thanks in Advance
Vinny
www.wulfsden.com
QTR Curves
2007-09-11 by alistair_owens
Hi All,
[I posted this on the QTR Group as well but I am not sure how active
it is so am cross posting it here. I trust that is OK but if not
please feel free to delete this post Mr/s Moderator]
I am currently attempting for the first time to build some curves in
QTR for some new papers I am trying. I am using a ColorVision
measuring device. I am using Epson Ultrachrome inks. I am working
through Tom Moore's very comprehensive instructions.
I have some questions about the Characterizing the Ink Paper
Combination process:
1. I assume we are only concerned about the black strip on the
printout to assess ink limit. Is that correct?
2. My black strip looks very blocked up at the darker end. This is
confirmed by measurements as follows:
55%	1.87
60%	2.00
65%	2.05
70%	2.07
75%	2.13
80%	2.16
85%	2.20
90%	2.22
95%	2.23
100%	2.23
Based on this data, I am tempted to use a limit of 75%. Is this a
prudent interpretation or would 85% be better?
3. I tried 70% just to experiment and the darkest swatch measures
2.1 - does mean that if I use a 70% ink limit that my dmax becomes
2.1 on that particular paper?
4. Assuming the answer to (3) above is yes, is the whole
characterization process about optimising the compromise between dmax
and blocked up shadows?
Any and all responses very much appreciated.
Thanks and regards
Alistair Owens
owens@...
