Switching off 2100 with CFS every day?
2004-10-03 by Bernie Ess
Hi, as with each switch-off/-on the cartridge chips on the cfs are reset to "full" the printer will do a complete purging cycle which probably wasted a lot of ink. So is it ok therefore to leave the printer on permanently? Power consumption seems low to me compared to lets say my PC (which I never leave on 24h a day), but how about the printer electronices, are they made for it? Thanks, Bernhard
2004-10-03 by Daniel Staver
I've pretty much had my 2100 on continously for the entire two years that I've owned it. I haven't had any problems which I believe are related to leaving it on. -- Daniel Staver http://daniel.staver.no
> Hi, as with each switch-off/-on the cartridge chips on the cfs are > reset to "full" the printer will do a complete purging cycle which > probably wasted a lot of ink. > > So is it ok therefore to leave the printer on permanently? Power > consumption seems low to me compared to lets say my PC (which I never > leave on 24h a day), but how about the printer electronices, are they > made for it?
2004-10-03 by Paul D. DeRocco
> From: Daniel Staver [mailto:daniel@...] > > I've pretty much had my 2100 on continously for the entire two years > that I've owned it. I haven't had any problems which I believe are > related to leaving it on. I haven't either (2200). Epson suggests that you turn it off when not in use, because allegedly the print head isn't capped unless you do so, which may lead to dry-out. I suspect this only happens in very dry climates, because it's never taken more than one or two cleaning cycles to get the printer going after a long idle period, and usually none at all. That's near the beach in L.A., which is moderately humid. -- Ciao, Paul D. DeRocco Paul mailto:pderocco@...
2004-10-04 by ferdinand_paris
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul D. DeRocco" <pderocco@i...> wrote: > > I've pretty much had my 2100 on continously for the entire two > > years > > that I've owned it. I haven't had any problems which I believe are > > related to leaving it on. > > I haven't either (2200). Epson suggests that you turn it off when > not in use, because allegedly the print head isn't capped unless > you do so, which may lead to dry-out. I suspect this only happens > in very dry climates, because it's never taken more than one or two > cleaning cycles to get the printer going after a long idle period, > and usually none at all. That's near the beach in L.A., which is > moderately humid. I was wondering about this issue myself. I did a bit of research before buying the printer which suggested that one should turn it off when not using it in order to prevent blockages due to heads drying out. This I have done, although I still need to print with it reasonably regularly to prevent a blockage. More recently I have read that it is better to leave it turned on, as this minimises the number of unnecessary head cleans that the printer does each time it is turned on. I am not entirely convinced by this, but even so, I'd be interested in a sampling of people's current enperiences. Which do you do, and why? F_P
2004-10-04 by Paul D. DeRocco
> From: ferdinand_paris [mailto:ferdinand_paris@...] > > I was wondering about this issue myself. I did a bit of research > before buying the printer which suggested that one should turn it off > when not using it in order to prevent blockages due to heads drying > out. This I have done, although I still need to print with it > reasonably regularly to prevent a blockage. > > More recently I have read that it is better to leave it turned on, as > this minimises the number of unnecessary head cleans that the printer > does each time it is turned on. I'm not sure turning it off and on wastes any ink, because I think the printer also does a cleaning cycle if you leave it on and don't use it for quite a while. However, I leave it on because I'm lazy. I suggest you try leaving it on. Generally, if you get a clog after a period of disuse, it won't be fatal, so if you find you get a lot of clogs this way, you can then try the policy of switching it off. -- Ciao, Paul D. DeRocco Paul mailto:pderocco@...
2004-10-06 by bwbonkers
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ferdinand_paris" <ferdinand_paris@y...> wrote: > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul D. DeRocco" > <pderocco@i...> wrote: > > > I've pretty much had my 2100 on continously for the entire two > > > years > > > that I've owned it. I haven't had any problems which I believe are > > > related to leaving it on. > > > > I haven't either (2200). Epson suggests that you turn it off when > > not in use, because allegedly the print head isn't capped unless > > you do so, which may lead to dry-out. I suspect this only happens > > in very dry climates, because it's never taken more than one or two > > cleaning cycles to get the printer going after a long idle period, > > and usually none at all. That's near the beach in L.A., which is > > moderately humid. > > I was wondering about this issue myself. I did a bit of research > before buying the printer which suggested that one should turn it off > when not using it in order to prevent blockages due to heads drying > out. This I have done, although I still need to print with it > reasonably regularly to prevent a blockage. > > More recently I have read that it is better to leave it turned on, as > this minimises the number of unnecessary head cleans that the printer > does each time it is turned on. > > I am not entirely convinced by this, but even so, I'd be interested in > a sampling of people's current enperiences. Which do you do, and why? > > F_P I do a half way house on this. If I'm going to print then I leave the printer on all day until the last print. This prevents unneccessary cleaning cycles when the printer is turned on. Then when I'm finished I turn the printer off, so printhead is capped. I also always do a nozzle check before turning off/on to check all is well. I have had my 2100 for a month now, use it regularly and so far have not had a single clog. I have'nt even had to initiate a cleaning cycle. Epson printers do need to be used regularly. Best to print something at least once a week. This works for me. Peter.
2004-10-07 by Clayton Jones
I've had a 2200 for just over a year now and after the first couple of months it has almost never been off. Keeping it on definitely reduces cleaning cycles. I use carts. It has sat unused for as long as three weeks and had perfect nozzle checks (UC+Eboni). Great printer. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
