Printer repair for OSX
2004-10-14 by Roger Smith
James, Thanks so much for this link! I sure have needed it as I have been doing all my printing in 9.2 since installing OSX 10.3 a few months ago. I could never get the printer utilities to open, never clean nozzles or check alignment. I also can't figure out how to set the dpi on the printer. Perhaps this software will fix my problem - I just got sick of trying to figure it out (nothing should be this convoluted for the consumer) and no one I talked to had any of the answers - sure didn't expect to see one on this list. Hope this fix works would like to print out of 10.3 and quite having to restart in 9.2. Sorry to all you PC people for having to put up with all of this! Thanks again. Roger Smith - E. Lansing, MI 48823 On Oct 14, 2004, at 2:50 PM, DigitalBlackandWhiteThePrint@yahoogroups.com wrote:
> Message: 25 > Date: Thu, 14 Oct 2004 13:50:33 -0500 > From: James Haney <jhaney@...> > Subject: Re: please help - 2200 completely hosed with QTR and Epson > > John, > > I had the same problem, or at least very similar. > > In the end I deleted every printer, re-installed the drivers from > Panther install disk 2, set up Epson printers in the printer setup > utility, and ONLY THEN installed QTR. > > In my instance installing QTR before installing Epson drivers disabled > the ability of the Printer Setup Utility from seeing USB attached > printers using "Epson USB." > > Incidentally, I used the Printer Setup Utility Repair application: > > http://www.versiontracker.com/dyn/moreinfo/macosx/14641 > > to actually do the driver deletion and permissions repair. I don't know > if this is essential, but doing a permissions repair is absolutely > essential to getting things working again. > > James Haney
