genuine fractals
genuine fractals
2004-11-05 by darryll48
Has anyone tried Genuine Fractals vs. Extenses TrueScale(?) and do you
think these work better than upsampling? Thanks!
genuine fractals
Sorry, make that Genuine Fractals vs. Smart Scale
Re: genuine fractals
2004-11-05 by Andre
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "darryll48"
With Photoshop CS bicubic smoother resampling, the need for third
party software is less evident.
Re: [Digital BW] Re: genuine fractals
2004-11-05 by James Haney
I would second that!
James
2004-11-05 by scott@lanes.com
Andre writes:
So is CS equivilent to something like Genuine Fractals or is there still
some advantage? I havent used it but i've been shooting with a Canon 300D
recently and would need to figure soemthing out if i want to print 16x20s
 -scott
www.Lanes.com
www.ScottLanes.com
2004-11-05 by Colin & Linda McKie
To get larger files from a DSLR, shoot RAW and upres in the Adobe RAW
Converter to 16 bits/pixel. That will give you a good starting point to
work from.
Colin
scott@... wrote:
> Andre writes:
>  -scott
> www.Lanes.com
> www.ScottLanes.com
Just to clarify, I meant increase the pixel dimensions AND output as
16bits/pixel.
Colin
> work from.
> Colin
> scott@... wrote:
>>Andre writes:
RE: [Digital BW] Re: genuine fractals
2004-11-05 by Paul D. DeRocco
> From: scott@... [mailto:scott@...]
GF does a somewhat better job of preserving edge sharpness if you upsize by
a large ratio, but only if you have sharp edges to begin with. If you zoom
way in on it, the result looks slightly artificial--because it is--but under
normal viewing conditions it works quite well. I think it's useful for some
images, but not for all or even most.
2004-11-06 by Steven Karafyllakis
Scott;
If your concern is printing only, you might test-drive Qimage; It
has some very sophisticated upsampling and sharpenning options, and
does a great job of printing both color and B&W. It has its quirks
but well worth getting used to, and quite reasonably priced. It co-
incidentally gives you a good way (actually it was designed for this)
to print multiple images on one piece of paper.
www.ddisoftware.com/qimage
Steve Karafyllakis
still
Canon 300D
16x20s
>  -scott
> www.Lanes.com
> www.ScottLanes.com
