Re: [Digital BW] Re: 2100 questions
2004-11-09 by Alan.Huntley@cox.net
F_P and Richard,
I have always heard that it's not good to simply leave any Epson printer on because the cartridges are not "parked"--that is, the pad lifted up against them--when the printer is on. I suppose it's possible that the ink would dry and clog the heads even faster is they're exposed to the air. Though I'm sure the parking pads don't create an airtight seal. I think it's really one of those "damned if you do...damned it ya don't" type things. I run my Epson 2200 almost every week and I still get minor clogs. YMMV, of course.
Alan Huntley
> From: "ferdinand_paris" <ferdinand_paris@...>
> Date: 2004/11/09 Tue PM 04:02:50 EST
> Subject: [Digital BW] Re: 2100 questions
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Richard
> Smallfield <r.smallfield@p...> wrote:
> > yesterday I installed a new Epson 2100.
> > I know that Epsons use ink for cleaning every time that you turn
> > them on.
> > Is it ok to leave it turned on for long periods of time?
> I too have wondered about how best to minimise the number of cleaning
> cycles my Epson 2100 does.  I decided to leave it on to try and
> minimise them.  But I don't think that this has worked.  If you
> haven't printed for a while, but left it on, it will do a cleaning
> cycle before it starts printing.
> I wondered about unplugging it, but that would probably just guarantee
> a cleaning cycle at each start-up, whereas is you turn it on and off,
> it only does a cleaning cycle at some power-ups.
> F_P
2004-11-10 by ferdinand_paris
That's where I started too - always turning it off.  I've tried both.
 There are sometimes gaps between print sessions.  I don't think there
is all that much of a difference in how often it cleans & clogs.  If
anything, I'd suggest that leaving it on results in less clogs, but
this would have to be a small difference, and I really couldn't be
sure.  Someone suggested that leaving it on, and therefore warmed up,
gave more consistent print output.
I know the engineers understand the pinter better than I, but it seems
to clean the heads rather often.  I assume that Epson would err on the
side of caution, especially if that promoted ink usage.
F_P
<Alan.Huntley@c...> wrote:
> F_P and Richard,
> Alan Huntley
> > From: "ferdinand_paris" <ferdinand_paris@y...>
> > > them on.
> > F_P
2004-11-10 by Bob Frost
Ferdinand,
The printers are more intelligent than you think! They have several
different levels of cleaning cycle and which they use and when is determined
by how long it is since the last cleaning cycle and how many prints you have
made since the last cycle. Epson usually recommend turning the printer off
if you are not using it, since the printhead is parked more firmly and is
less likely to dry out. They also recommend that if you are not using the
printer for a long while, that you turn it on and let it go through its
cleaning cycle at least once every three weeks.
Don't unplug the printer or switch it off at the socket. If you do that the
internal clocks won't count time and it won't know how long it is since the
last cleaning. Just switch it off using the off/on button on the printer.
Bob Frost.
