Setting up the Swap drive for PS in Windows
2004-11-23 by Steven Karafyllakis
Ever since PSCS became available and I started working in 16-bit,
I've had this annoying problem with Win XP when editing large files:
I have been getting frequent "you are running out of space on swap
drive D" notices, this in spite of the fact that at one point I had
a total of 16 GB of swap drives in various configurarions allocated
to PS. Checking into it I found that only the first two were being
used, the maximumum file size in either one was 3.99 GB, and the
notices started as soon as the first partition got to that file
size.
I'm sure the more experienced list members recognize the problem,
but for the sake of Windows newbies, now that I've finally found the
answer, I'd like to pass it on.
It turns out that the Windows FAT 32 file system won't allow files
of over 3.99GB, in spite of the fact that it does support really
large drives. The Windows help utility describes how to use the
Command Prompt interface to change the swap drive file structure to
NTFS, which does not have that limitation.
I haven't seen that pesky notice once since I did the change-over
yesterday. Yay!
RE: [Digital BW] Setting up the Swap drive for PS in Windows
2004-11-23 by Paul D. DeRocco
> From: Steven Karafyllakis [mailto:steve@...]
> size.
Good tip. Many PS geeks prefer FAT32 because it's somewhat faster. But I
don't find the speed difference particularly noticeable, although I haven't
benchmarked it. If I have to run a benchmark to detect it, then I don't care
about the difference. And now that I do big panos, and have three gigs of
RAM, a 4GB swap file isn't of much use.
Re: [Digital BW] Setting up the Swap drive for PS in Windows
2004-11-23 by bobphoto
How do you use the third gig of RAM since PS will only use two?  Does PS get the whole two gigs and system and other applications go to the third or do you have it configured as the first swap drive?
Bob
  Sent: Tuesday, November 23, 2004 1:36 AM
  Subject: RE: [Digital BW] Setting up the Swap drive for PS in Windows
  > size.
  - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
  BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
        Yahoo! Groups Sponsor
              ADVERTISEMENT
  Yahoo! Groups Links
> From: bobphoto [mailto:bobphoto@...]
The remaining gig gets used by the OS, probably mostly for a huge disk
cache, as well as for any other apps that may be open. It means that PS
really really has a full two gigs to run in.
2004-11-24 by Nunan, Mike
Hi (again!) Paul,
And also, if you have 4GB of RAM it is possible to set up XP Pro (not Home) to
give 3GB to PS and leave the remaining gig for the OS. You need a utility from
the Windows 2000 Server resource kit in order to patch the Photoshop
executable file so it will make use of the available memory, and you also need
to edit the c:\boot.ini file. The following articles tell you what you need to
know:
http://www.microsoft.com/whdc/system/platform/server/PAE/PAEmem.mspx
http://support.microsoft.com/kb/297812/EN-US/
HTH
-= mike =-
Sent: 23 November 2004 21:18
> From: bobphoto
The remaining gig gets used by the OS, probably mostly for a huge disk cache,
as well as for any other apps that may be open. It means that PS really really
This message is for the sole use of the intended recipient. If you received
this message in error please delete it and notify us. If this message was
misdirected, CSFB does not waive any confidentiality or privilege. CSFB
retains and monitors electronic communications sent through its network.
Instructions transmitted over this system are not binding on CSFB until they
are confirmed by us. Message transmission is not guaranteed to be secure.
2004-11-24 by Paul D. DeRocco
> From: Nunan, Mike [mailto:mike.nunan@...]
> (not Home) to
> utility from
> you also need
> what you need to
> know:
Thanks. I have XP Pro, and Win2K Server on another machine, so I'll look
into that.
