> From: koloshor <wiz@...>
> Date: Sat, 27 Nov 2004 19:20:54 -0000
> Subject: Re: [Digital BW] Bronzing - A Crazy Idea
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steve Kale"
> <stevekale@b...> wrote:
>> Then here is an issue. QTR can only treat gloss as an ink, laying it down
>> lightly in the highlights and heavily in the shadows. It cant do the inverse
>> (in present form).
> Sure, it can. Have a look at one of the .quad files, and you'll see.
> For an
> Epson 2200 file, there are seven curves in the file. Each one controls a
> particular "channel". Each has 256 values, ranging from pure white to pure
> black. Typically, all seven curves start at 0, some might stay at zero, and
> others increase or decrease.
> I'm uploading a version of EEM_2200-warm.quad where I've added a dash (4.3%,
> to be exact) of yellow in the no-ink areas. This is not for serious use, just
> an experiment in "filling in" GLOP. It will print ourtageously ugly (yellow is
> yellow, after all) on glossy paper with PK (not MK) ink, but it will show you
> a reasonably "bronzing free" print. 4.3% isn't the proper value, I suspect
> ssomething closer to 8% would be better. But it's a taste.
>> I suspect the lay down of gloss is a lot more complex. For example the R800
>> has the option to lay down gloss outside the image area suggesting that it
>> likely does need to be laid down where there is no ink.
> In QTR, that option is always turned on. QTR will lay down whatever the curves
> tell it is zero density in the entire paper area. So you're going to use a lot
> of GLOP.
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the membership
> without notice.
> printing. Users who persistently make off-topic posts may be removed from the
> membership.
> guidelines, and to abide by the actions and decisions of the group Owner and
> Moderators. See ³Group Topic, Rules and Guidelines² in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE ³OWNER² AND
> ³MODERATORS² OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL,
> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE ³OWNER² AND ³MODERATORS² OF
> DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR
> TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE
> DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE
> DIGITAL BW, THE PRINT YAHOO GROUP.
