2004-12-10 by Paul D. DeRocco
> From: Len Salem [mailto:len-salem@...]
> Sorry if this is a bit off topic but I could do with some reliable advice.
> I want to supplement my LaCie CRT monitor with a small LCD second monitor
> off the same Nvidia GeForce 2 card on my PC. The idea is to use the LCD
> monitor for palettes etc in Photoshop to declutter the main CRT screen. I
> don't have room for another CRT.
> 1. Can you combine the two technologies successfully off the same card?
> 2. If so, any particular attributes I should look out for in the
> LCD specs?
> Thanks for any help.
You can certainly do that. Windows doesn't provide an interface for
calibrating two monitors--that is, the "display", regardless of how many
monitors it has, only has one profile to describe it. This means you need to
calibrate and profile the CRT, which you'll use for viewing images, and then
settle for however that looks on the LCD. Since you won't be profiling the
LCD, and will be using it primarily for non-photos, you can use any old
piece of trash. However, even without calibration, having lots of pixels
(i.e., 1600x1200) is still nice.
Ciao, Paul D. DeRocco
Paul mailto:pderocco@...
