for Paul Roark: UT7 and Smeary Grays
2004-12-08 by matthewrabin
Paul (or anybody else who can field this),
after being really impressed w/ your UT7 inks and curves, I took the
plunge and bought the CIS for the 2200.  I'm currently using the CIS
system on inkjet art's duo matte paper w/ the EEM Neutral curve and
following all your "printing w/ curves" instructions (16-bit layers,
ADOBE RGB color space, etc.).  unfortunately, w/ the curve applied,
the midtones print---to use a technical word---"smeary."  when I
print the image w/o the curve, there's no midtone problem, but the
image is too dark.
any idea what's causing the smeary grays?
I'm wondering if the grays are a result of applying your paper
curves to overmanipulated and degraded images: I'm using pixel
picasso's photokit to sharpen and apply other effects and photoshop
CS's shadow/highlight tool.
the inks are great; I just want to be able to use them correctly.
thanks.
RE: [Digital BW] for Paul Roark: UT7 and Smeary Grays
2004-12-09 by Paul Roark
>image is too dark.
I can't tell what might be causing the problem.  The addition of a CIS
should not have had any effect.  So, if the inks and printer looked good
before, but the problem showed up with the CIS, the first thing I'd do is
re-check that the inks are in the right positions.
I'm not familiar with the paper you're using.  So, the curve may not be a
good fit for the paper.  You might try some of the other curves.
In general, printing without curves is a more failsafe procedure.  If the
print is too dark then, even with appropriate slider controls, that might be
a sign that it's not just a bad curve.
Of course, be sure that the file has no residual color information in it
before curves are applied and that there is no embedded profile.
That is possible.  Printing a 21-step test file on a paper for which there
are slider control recommendations and curves is a better way to check out
the system than using a file that may be the source of the problem.  I have
test files posted on my web Information page.  You might also want to check
out the Readme file there for UT7.  See the index at
http://home1.gte.net/res09aij/index.htm.
I think getting good results with the sliders from a grayscale file is the
first step.  After you're comfortable with that and the images look good,
curves would be the next and more complicated step.  Frankly, I use the
sliders approach a lot -- easy works for me.
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
2004-12-16 by Matthew Rabin
Paul,
sorry for the delay in responding; wasn't checking my email.
thanks for the advice.  it looks like I was able to figure the problem out.  my guess is it had a lot to do w/ photoshop CS's shadow/highlight tool: If you tweak it too much, you end up w/ splotchy looking grays.
thanks again.  the inks are great!
FYI: the EEM Neutral curve tends to print a little warm on inkjet art's duo brite matte.  not displeasing at all, though.  photorag neutral curve on the same paper tends to print closer to neutral, but a little dark.
>image is too dark.
page.
them short.
the membership.
Yahoo! Groups Links
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See �Group Topic, Rules and Guidelines� in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
   To visit your group on the web, go to:
Do you Yahoo!?
 Send a seasonal email greeting and help others. Do good.
