Epson 1280 w/ UT2...or Epson 2200 w/UT7...or...?
2004-12-08 by Mike Roma
I'm ready to buy a printer. I have only an Epson R200 right now, but
for 100 bucks, I'm impressed.
Is the 1280 with UT2 as good as the 2200 with UT7?
I am trying to decide between the 2200 and the 1280. I plan to do
mostly B&W, but would like to print color occasionally.
If I were  only going to use 'standard' inks, or only do color work,
I would definitely get the 2200. I would prefer to use a continuous
ink system for B&W to save money on ink.
It would be nice if I could swap inks with the 2200, and occasionally
do some color work. I'm afraid that the factory carts would 'dry out'
if unused for some time. Will they?
I could buy two printers, but desk space is very limited. I know I
MIGHT be satisfied with B&W prints from the Ultrachrome ink, but I
don't want to limit myself to that option. I guess what I want to
know is which printer/inkset will give me the best B&W print? "Best"
meaning no metamerism, unwanted color casts, or bronzing (if that's
possible) and excellent archival quality.
I do want a variable tone inkset. I'm just beginning with digital
printing, but I want to learn how to adjust curves to give different
tones to different parts of the print. I have downloaded some curves
that others have created, and used them with my R200. Are the UT2/UT7
inks the best choice for this? I'm using the factory color inks in
the R200 now.
I don't want to say that price is 'not a factor', but I am willing to
pay what I need to to achieve what I want. I may even end up with two
printers, if that's what it takes.
Since the 1280 is a dye printer, will it have problems using pigment
inks? I can buy a 1280 for a pretty good price right now. Later I
could get a 2200 for color, but there's the desk space issue...
I'll just deal with that if I have to.
Should I be looking at some other printer and inkset?
Sorry this got so long, and complicated...
 I know that's a lot of questions, but my brain is getting overloaded
with all the information I have been getting!
Anyway, if it's easy to swap inks in the 2200, and they won't 'dry
out' when stored, that may be my best solution.
So... what do you folks think?
Re: Epson 1280 w/ UT2...or Epson 2200 w/UT7...or...?
2004-12-09 by Michael Hung
I don't think you want to swap carts.. you will waste lots of
expensive ink. It is hard to do with one printer.. I have a R800 for
color and my 1270 (for b/w) is broken. I decided to get a C86 instead
to replace for b/w (it's 1/4 the cost).
I think your best choice is to get a 2200 now, and try QTR with the UC
ink and see if it is good enough for you. If not, get the UT7 ink or a
C86 cheap.
If I didn't get the R800 recently I would have gone for a 2200.
Good luck
Michael
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mike Roma"
> the R200 now.
2004-12-09 by Clayton Jones
Hello Mike,
One advantage of the 2200 is an ability to control the % ink level
applied to the print.  I have found this to be an important control in
getting results I want with UT7.  I don't think the 1280 has that
(someone correct me if I'm wrong).
The 2200 also has a rear paper feeder, very handy for real thick
stock.
pigment
> inks?
I haven't kept score, but I have a definite impression that there are
many more 1280 clogging complaints here in this forum than for the
2200.
If you can afford the 2200 I'd recommend that one.  MIS now has the
new transparent top-fill carts for it.  It's a great printer.
Clayton
