Epson 2100 (UT7): Nozzle question
2004-12-09 by Bernie Ess
Hello,
since a while I have one single nozzle blocked, nothing has helped so
far. On the nozzle print pattern it is the second color from the left,
so on the right side of the black cartridge.
As the order of the printed colors is not the same as the carts in the
printer, which is that color? Is it cyan?
Thanks for a hint,
Bernie
Re: Epson 2100 (UT7): Nozzle question
2004-12-10 by Bernie Ess
Hello, anyone?
My question was serious, no joke - I am rather sure someone knows: As
I have UT7 installed, I don't see which one is the color (and
cartridge) with the single blocked nozzle. And even if I installed
Ultrachromes, I am partly color blind, I am very bad at colors...
Thank you for a hint,
Bernhard
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bernie Ess"
<albatros-@g...> wrote:
> Hello,
so
left,
> Thanks for a hint,
> Bernie
2004-12-10 by Roy Harrington
Hi Bernie,
I don't have a nozzle check in front of me but I'm pretty sure
the order is    K,C,M,Y,c,m,k
So if its the second you are right it is the cyan ink slot.
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bernie Ess" <albatros-
@g...> wrote:
> Hello, anyone?
> Bernhard
> > Hello,
> so
> left,
> the
> > Thanks for a hint,
> > Bernie
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy Harrington"
<roy@h...> wrote:
> Hi Bernie,
Thank you very much.
Bernie
