Economical to fix clogged C84?
2004-12-13 by kcongdon
Hi - I have a C84 that I purchased this past spring, that I've been using for MIS UT-EZ inks. I didn't use the printer for a little over a month, and I've got clogged nozzles now. I've been trying to clear them with MIS's Cleaning solution, but I've not had any luck. I'm curious, how much does it run for Epson to clean the printer head? Is it even worth it with a C84? Should I just replace the printer with a C86, or even upgrade to an 890? Has anyone had Epson repair their C84?
