Tips on applying Print Shield
2004-12-17 by Chris Hargens
I just applied some Print Shield to a glossy print (Inkjetart's Micro
Ceramic Glossy Plus -- btw, they have very good profile for color
work for this paper), and I noticed that paper surface, after the
second coat, has a somewhat mottled look, even in areas of blank
paper. It looks almost like a window that has ice on it. Anyway, I
figure I must be doing something wrong because the print looks worse
than with no spray at all. Does this happen when you apply to much
spray? I ask this because the print looked like it was completely
covered with spray/liquid after the first application -- perhaps the
second coat was spread unevenly. Any advice would be appreciated.
Chris Hargens
Re: Tips on applying Print Shield
2004-12-17 by lulalake_1999
Yeah Chris,
I did the same thing when first using Print shield.
Try this spray very lightly, that is about 6" away from the print, no
closer and NO farther. (Too close makes rows and too far away and
some of the spray actually semi-dries before it hits the print.
WAIT till that is fairly dry 10 to 15 minutes, then turn the print 90
degrees and repeat.
I find that makes a "flat" non-mottled surface.(I just sprayed 36
prints last night using that method with no mottling.)
Jules
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Chris Hargens"
Micro
worse
> Chris Hargens
Thanks for the suggestions.  I'm hoping that this isn't a problem
more likely to occur with this paper (Micro
Ceramic Glossy Plus) because I just bought a pack of 50 11x17 sheets
and am very happy, otherwise, with the results.
Chris
  -- --- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "lulalake_1999"
<lulalake_1999@y...> wrote:
> Yeah Chris,
no
90
> degrees and repeat.
> Jules
Re: [Digital BW] Tips on applying Print Shield
2004-12-17 by Steve Schaefer
> I had that problem the first time I used Print Shield also. I think I was
> trying to lay down to much spray at one time.  I just finished up spraying 20,
> 16x24 color prints, printed on Premium Luster and they looked good.  I think
> the trick is to keep the can at least a foot away from the print, trying to
> just mist it between each coats. I applied 3 and some times 4 coats varying
> the direction of the spray each time. Also you have to wait at least 24 hours
> after printing to apply the spray.
> Hope this helps
> Steve
> Chris Hargens
