Coating prints
Coating prints
2004-12-17 by Steve Kale
I, like many others, have had all sorts of difficulties spraying RC paper prints. (I have tried
Lyson Print Guard which people tend to believe is the same thing as Print Shield.)  I really
don't think it works very well and is horrible on images with great expanses of deep black
- read mottled blacks and trapped dust.  But the recent glop dicussion begs the following:
Could someone like MIS develop a Print Shield like coating and instead of putting it in an
aerosol can put it in a refillable ink cartridge?  Our printers are already capable of precise
spraying of ink, how about a protective coating?  Any RIP/driver could be used to "spray"
an already printed image.
Thoughts?
Re: Coating prints-why not?
2004-12-17 by Steven Karafyllakis
Hard to believe only two weeks have gone by and no remembers I just
reported on this issue;  The MIS R800 gloss optimizer works quite
well in a cartridge, and does an excellent job of eliminating
bronzing and increasing Dmax, without the mess and noxious fumes of
the canned products and lacquers. It does not provide quite the
physical protection of Printshield, but is nonetheless quite
worthwhile for the benefits it does provide. Keeping some in a cart
and switching for batch coating would be fairly easy, though it
would require flushing the K head with Windex or something similar
before the coating so no K ink mixes into the coating. Even if that
doesn't work for you, using a $20.00 model-making airbrush and
spraying it on is very easy, the coating is easy to get on evenly,
in one or two light coats. One big caveat: This stuff works well on
semi-matte, lustre, and glossy RC PAPERS, but not on matte, and not
with Eboni ink. It does fine with UC inks and the PK or even
MIS 'Universal K'.  If anyone was to see a sample of it, email me
off-line. I'll send out a few for the price of postage.
Steve Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steve Kale"
> Thoughts?
Re: [Digital BW] Re: Coating prints-why not?
Steve
Read my original post again.
Steve
> From: Steven Karafyllakis <steve@...>
> Date: Fri, 17 Dec 2004 23:38:20 -0000
> Subject: [Digital BW] Re: Coating prints-why not?
> Steve Karafyllakis
>> Thoughts?
2004-12-18 by Chris Hargens
The confusion here is my fault. I've been thinking about Print Shield
mostly in terms of its ability to reduce/eliminate bronzing rather
than what it does in protecting prints. For me, any protective
coating for RC papers is probably not worth using if the bronzing
problem is not addressed either through that coating or by some other
means. For that reason I've been thinking about what might be the
best way to apply glop -- if a spray application doesn't have
problems with mottling, blotches, etc., then it may be the best route
for someone, like me, who only owns a 2200 and doesn't want to go
through the hazzle of filling and switching carts to coat. Again, as
you point out Steve, this doesn't address the issue of protection. In
this regard I suspect that carts loaded with nonwaterbased products
with chemical properties similar to Printshield might damage the
print head...just a feeling. That's why I'd be interested in hearing
reviews of some of the other water-based inkjet coatings that are
being used.
Chris Hargens
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
> Steve
> Steve
> > From: Steven Karafyllakis <steve@s...>
just
of
cart
that
on
not
> > Steve Karafyllakis
> >> Thoughts?
2004-12-18 by Steve Kale
No confusion.  Some are already using glop to get rid of bronzing.  Carl
Schofield, for example, already has a full set of glop curves for use with
his FSN/UT2 setup including a workaround for an OS-X issue.  But this is not
the same thing as protecting a print so that it doesn't need to sit behind
glass.  Print shield's primary use is for this.  But its application is a
hazardous affair with mixed results.  Hence my suggestion as to whether it
is possible to design a protective coating that can be laid down by a
printer rather than a spray.
If you want to use glop - just use the printer to put it down, pure and
simply. But you then still face the task of protecting the print.
> From: Chris Hargens <chargens@...>
> Date: Sat, 18 Dec 2004 00:34:49 -0000
> being used.
> Chris Hargens
I just ordered a 4 oz bottle of glop and 2 pk virgin empties from
MIS. You mention that Carl Schofield is using curves for his
application of glop. Are such curves necessary or is printing a 100%
black image adequate? As for Print Shield, I think I've solved the
problem I was having with mottling and blotches. I wasn't letting the
print dry completely before applying the spray and I wasn't spraying
lightly enough. Even so, I strongly agree that at best it's just a
step towards a real solution to print protection.
Chris
Carl
use with
this is not
behind
application is a
whether it
a
and
Carl's curves lay down the glop at the same time as the image is printed.
It puts down a flat percentage of glop which would suggest an overcoat could
also work fine.  By using QTR to control the inks/glop, though, you can
control accurately how much is put down.  I think Carl found that an ink
limit of 20% was about right.  If you are using the Epson driver you might
want to experiment a little with the colour density slider starting with a
significantly reduced density.  Also just to ensure the Epson driver doesn't
fire any of the other inks select Black only.
> Date: Sat, 18 Dec 2004 18:12:55 -0000
> Chris
