When you downloaded the file (I'm guessing the latest 2.1b file), it
should be saved as a executable file, right? (The extension
is .exe.)
If you just double-click on this file, then everything should
install correctly.
If you are trying to install by running the "InstallQuadTone.bat"
file after everything has been extracted, then you will have to move
it from the "QuadTonePC2_1b" directory up one level to the parent
directory. It should work from there. (Either that, or modify the
paths in the .bat file...)
Hope this helps...
Eric
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mtn778"
<tlewis@b...> wrote:
> I downloded the file, it read my files fine except that at the
bottom
> it tries 3 times to install and fails but then reads "Installation
> Complete, Press any key to continue...". I press a key and it
> disappears. Then I downloaded the GUI and it tells me to install
> RIP first. XP Home.
> What gives?
> Thanks,
> Tim
