RE: [Digital BW] Color management - Photoshop cs
2005-01-04 by Richard Wolfson
Can you print a perfect nozzle check pattern?
Richard Wolfson
Fine Art Photographer & Digital Imaging Consultant
> From: michaelwtz [mailto:michaelwtz@...]
> Sent: Monday, January 03, 2005 11:58 PM
> Subject: [Digital BW] Color management - Photoshop cs
> I need help - when I print (using generations enhanced ink
> with profiles on an epson 1270), my monochrome and tinted
> prints ( RGB or Grayscale files), are previewing and printing
> with a very strong cyan (purple!) cast - should say color, as
> it is so strong. The monitor is calibrated - print looks good
> - then disaster! I have checked my driver settings
> - seem to correct; color management off etc.
> Anyone had similar issues - found any solutions?
Re: [Digital BW] Color management - Photoshop cs
2005-01-04 by michaelwtz
Yes, I have cleared previuosly blocked nozzles - what I find interesting, is that I do not
need to print the image to know that photograph will print 'purple'. The photo previews on
the monitor with the purple cast - and then prints as per the preview.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Richard Wolfson" <rw@r...>
> Richard Wolfson
> > From: michaelwtz [mailto:michaelwtz@y...]
> I do not need to print the image to know
> the preview.
Ok; it sounds like it's not a printer problem.
If you preview a fully-desaturated RGB image (i.e., r = g = b
everywhere) through an RGB profile and see a strong color cast,
something is wrong.
If your fully desaturated image looks neutral on your calibrated monitor
in RGB view but turns purple when you select "Proof Colors" then seems
like monitor calibration is not the issue.
If preview through a different profile (from another source) looks ok,
the first profile could be corrupted. If all profiles generate purple
previews, then the profile is not the issue.
If none of those tests isolates the problem, and you are confident all
color settings are correct, you might try uninstalling and reinstalling
Photoshop. Conceivably your software installation is corrupted.
Richard Wolfson
