Richard,
Thank you very much for your assistance. At present the main benefit
is to learn to walk before I can run - as you say the learning curve
seems pretty steep. I'll work along the lines of your instructions
and see where it leads - at least I'm beginning to understand the
relationship of the curves.
My apologies in advance for when I get back to you:)
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Richard
Wolfson" <rw@r...> wrote:
> hi John -
> Joe's "canned" curves are a good starting point, but you may need to
> make significant changes. Here is a curve-editing procedure you may
find
> helpful.
> 1. Prepare a 26 step grayscale step wedge suitable for your
> spectrophotometer. The Photoshop gray values of the patches should
be
> 0%, 4%, 8%, and so on, up to 100% of black.
> 2. Print the step wedge through OPM using your starting "profile."
> 3. Measure the luminance (L*) of the patches, import the data into
> Excel, graph the points, and compare the resulting curve to a
luminance
> target straight line from your maximum L* (paper white, at 0% K) to
your
> minimum L* (Dmax, at 100% K).
> 4. Adjust ink levels using "free edit" in IJC. Add ink where the L*
plot
> is above your luminance target line; remove ink where the L* plot is
> below target. You'll need to study your curves to decide which ink
to
> vary in each part of your gray scale. Also, to get the best possible
> Dmax (i.e., lowest minimum luminance), adjust the ink mixture at
100%
> carefully. Save the adjusted ink curves as a new "profile."
> 5. Repeat steps 2 through 4 until you get the best result you can.
When
> you're very close, you can try using IJC's "Linearize" function to
see
> if it does any better than you can by hand.
> I use an X-Rite DTP-41 strip-reading spectrophotometer for this
kind of
> work, and I have found working toward a linear gray ramp in L* space
> works very well.
> If you don't have a spectro, you can work with a densitometer and
> convert density readings to L*, or you can work with densities
instead
> of luminance, but in this case you should work toward a gamma curve
> target, not a straight line. If you don't have a densitometer
either,
> you may be able to get decent results working with a scanner, but
you'll
> be at a disadvantage, I think.
> I realize this may seem a bit sketchy. Expect a fairly steep
learning
> curve if this all seems new to you.
> Richard Wolfson
> Fine Art Photographer & Digital Imaging Consultant
