UT7/7600 (WAS Re: in a fog about UT7/2200 : Paul)
2005-01-05 by sandersm@aol.com
Paul, thanks for this post. I am not the original poster, but I am thinking again of converting my 7600 from UC to UT& inks. Your post, and my efforts to understand the MIS site, lead to a couple more questions: 1. I've noted your earlier remarks, repeated here, that the UC MK provides deeper blacks when used on the 4000 and 7600. And I note, here, that you suggest that the UC MK might be substituted for Eboni in a UT7 set. Does one leave the UC MK cartridge in the K slot? Are there any problems raised by sticking with the UC MK in a UT7 set? 2. The MIS page description for the 7600/UT7 workflow suggests that the "slider" adjustments are an alternative to the curves, for adjusting the tones printed. Is this correct? Or do the sliders work with the curves? This leads to my third question: 3. I use Photoshop Elements 3.0 as my image editor. Is the MIS workflow for the 7600/UT7 compatible with Elements to the extent it relies on curves? 4. I was intrigued by your remark that one ought not install the UT Sepia toner ink if not planning to print in sepia. I've used the C84 UT EZ warm inkset, and cannot imagine ever wanting a print warmer than what that inkset provides, so no, I have no need of Sepia printing capability. Question: Can the Sepia slot be converted to take a PK cartridge? Or a GLOP cartridge? and if so, how would one control it? 5. Last question (I promise) (at least for now): How does one print glossy media with the Epson driver on the 7600 when the MK ink is installed? I know that you have come up with a solution that does not rely on K ink to get good deep blacks. How is this set up and controlled? I know these are subjects that have been touched upon over the past months -- I apologize if I am asking you to cover old ground again. Best wishes, Sanders McNew. [Non-text portions of this message have been removed]
