Re: [Digital BW] New digital inerneg material
2005-01-06 by sdmey4@aol.com
In a message dated 1/5/2005 5:12:49 PM Pacific Standard Time,
steve@... writes:
> Anyone out there still working on digital internegatives? A few
> weeks back I got a few sheets of a film called Super Clear/IJ from
> Michael Pach and Adveturecam Photo. I've tried it a couple times at
> this point, and I'm pleased enough with it to ressurect that
> particular project.
,SNIP>
Sounds interesting, does this guy have a web site or some contact info?
Steve M
Re: [Digital BW] New digital interneg material
2005-01-06 by Steven Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, sdmey4@a...
> steve@s... writes:
from
at
> > particular project.
> ,SNIP>
info?
> Steve M
Hi Steve;
His website URL is http://www.adventurecamphoto.com
In a message dated 1/5/2005 8:19:48 PM Pacific Standard Time,
steve@... writes:
> Hi Steve;
Great ,Thankyou. What kind of inks where you using with it?
I'm doing some early experiments with Platinum. And its looking toooo dull.
But i'm spoiled by near perfect Piezotone Ink Prints.
Steve M.
2005-01-06 by steve_bye
I have used Pictorico Hi-Gloss White Film, as Dan Buckholder suggests, to
create 8x10 negatives and have been quite successful printing them. The
problem is, of course, that you might look at the prints that I think are
good and you may think they suck. The is a huge range in what people think
are good prints. Other people thought my prints looked good, so I'm not
completely wrong.
The printing times are long - a couple minutes at F2.8 for about 11x14
coverage. I think the contrast is very good, though. The trick was making
sure that the printing time was long enough for the print to have a really
black Dmax, but no longer.
I used some of Dan Burkholder's process from his Inkjet Negative Companion
download
(http://www.danburkholder.com/Pages/main_pages/book_info_main_page1.htm) but
added a detail from D. Krehbiel
(http://kcbx.net/~mhd/2photo/outneg/outneg1.htm) to establish my exposure
time. The trick is to use the interneg step wedge that Dan Burkholder
provides, but modify it with an absolute Dmin patch (for the negative) by
adding cutting a hole in the negative, and then also creating an absolute
Dmax patch (for the negative) by adding black tape to the interneg. Then you
slowly increase the exposure time until the clear patch of the step wedge
prints just as black is the Dmin patch from the hole in the film. This is as
black as the paper will print. As a final check, the negative's Dmax patch
with the tape should print as white as the black patch of the step wedge,
which should be paper-white. I was able to get sufficient density with the
UC inks to do this with Ilford Multigrade IV RC paper with a #2 filter.. I
was amazed to be able to see the difference between 0% and 2% patch of the
step wedge, and also the 100% and 99% patch in the print. The only remaining
tweak, which I did not perform, would be to see if the 50% patch was really
50%.
The real question is "is all this effort worth it?" I have decided that I
will only use interneg's if I need the absolute blackest blacks, or need
glossies without bronzing. The QTR prints look awfully good, and are
painless.
Steve Bye
Sent: Wednesday, January 05, 2005 5:10 PM
Subject: [Digital BW] New digital inerneg material
particular project. I had been trying Pictorico products, but
remained unsatisfied: I hate printing through the almost opaque
white plastic paper, and the OTC showed printer artifacts: the
printer dots where very clearly delineated, it showed microbanding
when normal paper wouldn't and the film itself was milky, lowering
the effective contrast, and has a lot of microscopic flaws. Also,
and probably most important, the Pictorico won't build much density
or color saturation. It seemed no matter how I went about it, I
could get enough density, spectral or otherwise to get good
contrast. Not a problem if you're using variable contrast paper, but
I need the internegs for printing the hand coated emulsion, which is
a grade two at best.
OTOH the Super Clear is, as its name implies, much more clear, at
least in part because it is thinner, so carefull handling is a must.
On the plus side, it is capable of producing much better color
saturation, especially in the yellow range where the Pictorico was
very weak. That makes it easy to produce an orange negative of
enough spectral density to make a snappy print on VC fiber paper at
a grade 2-2.5
Also, it shows printer dots less, and doesn't seem prone to showing
microbanding either. I think this is becuase there is a bit more dot
gain, which softens the edges of the printer dots a bit. Obviously
this also means slightly lower max sharpness is possible, but the
difference is not visible to the naked eye, and you have to look
carefully even with a lupe to pick it up. The lower grittiness is
definitely visible to the naked eye, and quite pleasing.
There is one catch: the material is available in 100 sheet boxes,
and while the price per sheet is much lower than Pictorico, that's
still a good chunk of change. Michael has agreed to split the
packages into 50s that's a lot easier to handle, and puts the cash
outlay close to what you'spend getting into Pictorico.
Hope this is of some use & interest
Steve Karafyllakis
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
Hi Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "steve_bye"
suggests, to
them.
11x14
making
a really
I realized fairly quickly that I could get a decent print out of the
white film, but the exposure times were so long with VC paper that
trying to print Liquid Light that way was going to test my patience.
And right now putting out a new batch of the LL prints is the only
thing that could get me back into the chemistry. Tomorrow I'll coat
a batch of paper and see if I really can get the contrast I need out
of an 8x10 digital neg on Liquid Light. Should be interesting.
that I
or need
are
> painless.
> Steve Bye
The best way to get blackest blacks and glossies without bronzing is
to find the right way to apply (a hopefully soon improved version
of) the MIS gloss optimizer. You won't find yourself missing a good
Dmax if we can get that working properly.
Re: New digital interneg material
So far I've done most testing with the dyes, but I ran a strip
through the 7600 w/ MIS UC inks early on. The material holds the ink
well but I haven't yet really explored that combination yet. Also,
I'm printing on an R300 at max dither.
Steve K.
> steve@s... writes:
> > Hi Steve;
toooo dull.
> Steve M.
2005-01-07 by sdmey4@aol.com
In a message dated 1/6/2005 4:10:11 PM Pacific Standard Time,
kcarney1@... writes:
> Steve, is your hand-coated emulsion platinum or palladium or a combination?
> As you know these require a neg with a DR greater than a neg for silver
> paper.  If this film will work for pt/pd or Ziatype that is good news
> indeed.  Also, are you using dye or pigment inks?
> Regards,
>  --Ken Carney
>   www.kencarney.com
Ken, The emulsion was a mix pt/pd mostly palladium on Arches palintine paper?
 A friend with about a years experience with digital negs and platinum made
them for me using a 1280 and dye
inks. I do know he puts a color mask over the entire file in photoshop prior
to making platinum negs. He is using a Ziatype POP. I will get him some of
this film and let him lead the way
before I commit to making my own negs. He needs to make me a believer first.
So far they make the Quad Piezotones look incredible.
They where smooth enough and sharp enough just rather dull looking like an
inkjet on uncoated paper. Thats sort of what Platinum is, but we both think it
can be better.
Steve Meyers
www.xray-art.com
2005-01-07 by steve_bye
I realize that I forgot to mention that the good results I was getting with
intenegs printed on a 2200 was for the silver/gelatin process. I know Ken
Burkholder uses the process for platinum prints.
Steve Bye
Sent: Thursday, January 06, 2005 4:10 PM
Subject: RE: [Digital BW] New digital inerneg material
  --Ken Carney
    www.kencarney.com
> From: Steven Karafyllakis [mailto:steve@...]
> Sent: Wednesday, January 05, 2005 7:11 PM
> few weeks back I got a few sheets of a film called Super
> Clear/IJ from Michael Pach and Adveturecam Photo. I've tried
> it a couple times at this point, and I'm pleased enough with
> it to ressurect that particular project. I had been trying
> Pictorico products, but remained unsatisfied: I hate printing
> through the almost opaque white plastic paper, and the OTC
> showed printer artifacts: the printer dots where very clearly
> delineated, it showed microbanding when normal paper wouldn't
> and the film itself was milky, lowering the effective
> contrast, and has a lot of microscopic flaws. Also, and
> density or color saturation. It seemed no matter how I went
> about it, I could get enough density, spectral or otherwise
> to get good contrast. Not a problem if you're using variable
> contrast paper, but I need the internegs for printing the
> hand coated emulsion, which is a grade two at best.
> clear, at least in part because it is thinner, so carefull
> handling is a must.
> color saturation, especially in the yellow range where the
> Pictorico was very weak. That makes it easy to produce an
> orange negative of enough spectral density to make a snappy
> print on VC fiber paper at a grade 2-2.5
> showing microbanding either. I think this is becuase there is
> a bit more dot gain, which softens the edges of the printer
> dots a bit. Obviously this also means slightly lower max
> sharpness is possible, but the difference is not visible to
> the naked eye, and you have to look carefully even with a
> lupe to pick it up. The lower grittiness is definitely
> boxes, and while the price per sheet is much lower than
> Pictorico, that's still a good chunk of change. Michael has
> agreed to split the packages into 50s that's a lot easier to
> handle, and puts the cash outlay close to what you'spend
> Steve Karafyllakis
page.
them short.
the membership.
Yahoo! Groups Links
2005-01-07 by Mark Savoia
I think you mean Dan.
Mark
On Jan 7, 2005, at 2:00 PM, steve_bye wrote:
> I know Ken
2005-01-08 by Steven Karafyllakis
Hi Ken;
Sorry I dropped out there, I pikced up bug & have been horizontal
for a couple days.
combination?
silver
news
Actually, my hand coated emulsion is silver- Liquid Light to be
exact. I discovered a few years ago that it actually is possible to
get a decent print out of the stuff, given enough coats on the paper
and a snappy negative. I have no idea how the DR compares to
platinum, my guess is you still need a lot more contrast than I've
worked up for this test. The inks I'm using are dyes-you could
probably get better DR just by switching to pigments, those being
more opaque. And at this point, I'm still not sure the neg I've made
will work with LL, turns out what I had in the regrigerator is too
old and has gotten coarse, gritty,& muddy. So I'm on hold until I
get some more, and also some more Super Clear film so I can try some
variations.
