Tim,
I first removed the plastic pieces with the mounted pizza wheels completely, and then I
had to put them back in place again because I discovered that the C86 use the pizza
wheels to transport the last inch of a sheet.
So, I still have not solved the pizza wheel problem, but my idea is to place a pair of "MIS
Washers" to lift the pizza wheels a litttle, so that they still helps with transport but enough
so that they dont make the marks.
I will use this method: (intended for the Photo EX printer but may work with the C86)
http://inksupply.info/index.php?
_a=knowledgebase&_j=questiondetails&_i=2&nav=+%26gt%3B+%3Ca+href%3D%27index.
php%3F_a%3Dknowledgebase%26_j%3Dsubcat%26_i%3D1%27%3ETips%2C+Tricks%2C+and
+Terms%3C%2Fa%3E
Let me hear if you find a way to solve this problem...
Bjorn
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "photorag" <timaro@g...> wrote:
> Hi everyone,
> I remember seeing a post not too long ago that one of you was able to
> remove the "pizza wheels" from your epson c86. How did you go about doing this? Did
> you have to go through the inside of the printer?
> Thanks,
> Tim
