no nozzle check
no nozzle check
2005-01-25 by Mr_Misty_44
I'm having a strange problem. In the past, when I've had a clog on my
7500 which would not go away I've replaced a few dampers which have
solved the problem. I Just had a problem with the Black and Cyan
positions. The black all of a sudden would get brakes in the pattern
which would not go away. I ended up printing a black only Purge which
got lighter and lighter until I could barely see a patern. I put in a
damper and drew some ink into it with a syringe from the port which
goes on the head nib. I then put the damper back on and printed a
nozzle check, NOTHING. I did several cleaning cycles and tried again.
Still nothing. I then went back in and replaced the damper on the
Cyan thinking that I had replaced the wrong damper. I fired up the
printer, did a cleaning cycle and then printed another check. Now the
black did not show up and the cyan shows very little activity. I
replaced the damper on the black and tried again. Still no activity
in the black channel and little in the cyan. I've ordered a couple of
more dampers and plan to start again. How much Ink does the head
itself hold in each channel apart from the damper. what is wrong and
how do I correct it. Please help.
Re: [Digital BW] no nozzle check
2005-01-25 by Carl Anderson
I had a similar problem with my 7600. it required changing the cap
assembly. If you are not getting a good seal around the o-ring then you
won't get enough suction to pull the ink out of the dampers. It can also
cause the ink in the heads to dry out and clog. You can first try to clean
the o-ring with a Q-Tip soaked in distilled water. Also clean the rubber
wiper blade since it can become encrusted with dried ink. If that doesn't
work then there is a good chance you will have to replace the assembly.
