R800 help on my learning curve
2005-02-05 by Scott Jones
Greetings, I have been reading the forum now for several weeks and would like some help on my learning curve. I am using the Epson R800 on WindowsXP with Photoshop CS. I love this printer for color work, the fact that the glop works so beautifully with bronzing eleiminated, and that I don't need to switch black carts. I am quite anxious to get the anticipated wide format version probably coming out this year. I also use the OEM high gloss UltraChrome inks. I have started to experiment with B&W printing with this set-up on a calibrated monitor and custom profile for my printer and Epson Semigloss paper using the Epson driver. I have not liked the color casts that I am getting or the metamerism. Not bad under lights, but particularly bad in daylight. So I tried the R800's "monochrom" tone feature which Epson tech support tells me uses primarily black ink, but probably some color too. It is very nice under lighting, but green/tourquoise when daylight is hitting it. So this is out for me too. (By the way the R800 has no "black ink only" setting). So my question is, if I want to stay with the R800 and OEM inks on a WindowXP platform, is there a solution to making neutral prints? My personal preference is to have something that does not take too much fussing or experimentation and that operates smoothly. I would pick ease of use over any cost considerations. I want to have the printer still be able to do the wonderful color printing that I have acheived with the OEM inks and glop on the epson papers. Am I pipe dreaming here? I am a traditional wet darkroom fiber worker, but really want to use the controls of Photoshop. My funny colored first attempts at inkjet printing are way better than what I am getting in the darkroom except for the color cast/metamerism. I have read about all the rips that you discuss and visited their web sites, but find it all quite confusing, so any help you can give me with the above noted desires and parameters would be soooo welcome. Thanks for your help. Scott
