Which Printer should I get?
2005-02-21 by Vinicio Morales
I'd like to get a good printer to make at least 11X14 and maybe
16X20 prints.  I am considering an Epson 2200 or 4000.  What say
thee professionals and amateurs?  Are there better alternatives?  Is
the 4000 really cheaper in the long run on ink?  What would give me
the most for my money?  Thanks in advance!
Re: Which Printer should I get?
2005-02-21 by Clayton Jones
Hello Vinicio,
They are both excellent printers and use the same inks, so it really
depends on what size prints you want to make.  If you ever want to
make 16x20 then there's no question a 4000 (or bigger) is needed.  If
you don't, then why spend the extra money?
The 4000 is "expensive" in other ways.  It takes up a lot more space
(minimum 30x30") and weighs about 90 lbs.  The ink carts are bigger
and cost more, plus they are not located on the head.  Someone correct
me if I'm wrong, but I think this means that changing inks to try
other things is a much bigger chore because of having to purge the
lines, and more expensive because of extra ink in the lines.
The 2200 now has the nice top-fill carts, so it's easy, quick, and
relatively inexpensive to swap inks and try different combinations.
Clayton
