Epson R1800 vs 2200..need opinion fast
2005-02-23 by Tim Timmermans
Hi guys,
Happy New Year! I've been away and very busy. Just won a Grammy too!
But now back to my other passion. Photography.
Here's the deal. I bought a 1280 with a replacement warranty awhile
back. When I return it I'll get a credit for $399.
I already have one 2200. Should I get another 2200 or should I get the
R1800?
What is the fundamental difference between the two besides the price
and the speed of the R1800 and its 8 inkset rather than the 7 inks for
the 2200? I there a CFS for the R1800 yet?
Is there still a bronzing issue with the R1800? Should I trade the
2200 in for a R1800 and then have two R1800's, one for BW and one for
color?
Tim
RE: [Digital BW] Epson R1800 vs 2200..need opinion fast
2005-02-23 by Seth
1.5 pico-liter nozzles and "gloss pigment."
Seth
==-----Original Message-----
==From: Tim Timmermans [mailto:zenphoto7@...]
==I already have one 2200. Should I get another 2200 or should
==I get the R1800?
==What is the fundamental difference between the two besides
==the price and the speed of the R1800 and its 8 inkset rather
==than the 7 inks for the 2200? I there a CFS for the R1800 yet?
==Is there still a bronzing issue with the R1800? Should I
==trade the 2200 in for a R1800 and then have two R1800's, one
==for BW and one for color?
Re: Epson R1800 vs 2200..need opinion fast
2005-02-23 by Louis Dina
Tim,
I cannot comment about the R1800 or the R800 for B&W, but I have
built custom COLOR profiles for two different R800's using my Eye One
and Profile Maker 5.
The R800 (same technology as the R1800) has a larger gamut for glossy
and semi gloss papers than the 2200 (which I own).  The red, blue and
gloss cartridges extend the color range and Dmax.  So, for color
printing on glossy type papers, it seems to be a winner.
Strangely, on matte papers the 2200 has a larger gamut, and it seems
to me, higher quality and smoother gradations.  I have seen this on
two different R800's and I have a color management expert friend who
has confirmed these findings in his profiles.  You can see it both in
the print and when comparing profiles using Chromix ColorThink.
I have also been looking for a new color printer, with the intent of
converting my 2200 to quad inks.  At this time, I am biding my time.
Not sure if I will even go that route, since I am getting such superb
B&W results using IJC/OPM for Windows and the Epson UC inkset.
Hope the above adds a little more to your thinking process.
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tim Timmermans"
<zenphoto7@a...> wrote:
> Hi guys,
> R1800?
for
for
> color?
> Thanks,
> Tim
2005-02-23 by Clayton Jones
Hello Tim,
>the R1800?
Here is a good discussion of it
 http://www.inkjetart.com/news/archive/IJN_02-21-05.html
Clayton
Re: [Digital BW] Epson R1800 vs 2200..need opinion fast
2005-02-23 by Mark Carstens
Lou,
I've been contemplating a new color printer that would enable me to
dedicate my 2200 to B&W/quad inks, and appreciate your insight about
IJC/OPM. It'd be nice to avoid the cost of the second printer and buy
the Bowhaus RIP instead. My question to you is whether you'd feel the
same about IJC/OPM even if you didn't write your own profiles? In
short, does using Profile Maker 5 just give you a broader paper
selection above and beyond what Bowhaus already provides or are you
actually improving on established profiles?
Thanks for your input.
Mark
On Feb 22, 2005, at 5:37 PM, Louis Dina wrote:
> Tim,
> Lou
Hi Mark,
For color, I use PM5 to build custom profiles for the Epson driver.
They work great and I see absolutely no need for a RIP for color.  In
fact, I do a lot of press work at my job and use my 2200 with custom
ICC profiles and the Epson driver for proofing.  My proofs are
actually better than when using a number of RIPs.
For B&W, I am using IJC/OPM with the Epson UC inkset.  I started with
the profiles supplied by Bowhaus, but made some changes.  My spectro
just made it easier.  I chose to remove yellow inks from all profiles
(except sepia ones) to reduce metamerism.  Yellow inks are the
biggest offender, and removing them has given me fantastic results.
I always create a series of 5 profiles for each paper - Cool,
Selenium, Neutral, Warm and Sepia.  OPM (the printing part of the
program) allows you to blend two profiles with a 0-100% slider so you
can obtain an infinite range of subtle tones.  I have posted 2200
profiles (for the Windows Version) on this site in the Files
section.  Papers include Ep Enh Matte, Ep Velvet Fine Art, Boab
Entrada (BW and Natural), Somerset Photo Enhanced Radiant white,
Kirkland Glossy, Ep Prem Glossy, and Lexjet Professional Semi Matte.
They can be downloaded and used directly if you have a 2200 and the
windows version.  Here is the link.
http://tinyurl.com/6fksu
These are linearized for my printer, but I have shared them with
others and they have had great results without making any changes.
Linearization is easy with a densitometer, spectrophotometer or a
scanner, if required.  I'd just print a test target with
linearization and inspect the target to be sure there are no color
crossovers, and that there is good separation between all 26 steps of
the grayscale wedge.  If so, you are ready to roll.
I tend to build my 'neutral' profiles to accomodate the natural bias
of the paper color.  So, my neutral profiles on a warm base paper,
like Moab Entrada Natural, has a very minor amount of warmth to the
grays, mirroring the natural paper white.  I just like the results
better and it keeps the 'neutrals' more consistant from black to
white.  Seems to look better to my eye and you don't get any jumps as
you approach paper white.  A cold paper, like EpPremGlossy, may be
slightly cool to work with the paper.  These are my preferences and
can be adjusted easily by tweaking the profiles or blending.
I don't use ProfileMaker when adjusting profiles (I only use this to
build monitor and color printing profiles).  I do use my Eye One
spectrophotometer and MeasureTool from Gretag to read the data.
MeasureTool is a free download.  A spectro is not absolutely
required, but it does provide some extra accuracy and flexibility.
You can get outstanding results without one.  I hope this provides
the information you wanted.
My prints have awesome Dmax and are very neutral (when I want
neutral).  I see no metamerism at all now that I have removed the
yellow and the tonal gradations are silky smooth.  I may never move
to Quad inks.  If I get a new 24" printer in the future for color
work, I will probably try quads in my 2200.
Contact me if you want additional information.
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mark Carstens
<mathdude5@c...> wrote:
> Lou,
about
buy
> Mark
Re: [Digital BW] Re: Epson R1800 vs 2200..need opinion fast
2005-02-23 by Steve Kale
Lou
With MIS empty cartridges you can get the best of both worlds with your
2200.  Swapping out the inks and flushing is really not a hassle with the
2200.
Steve
> From: Louis Dina <lbdina@...>
> Date: Wed, 23 Feb 2005 01:37:24 -0000
> Subject: [Digital BW] Re: Epson R1800 vs 2200..need opinion fast
> Tim,
> Lou
2005-02-23 by Ernst Dinkla
Louis Dina wrote:
>Tim,
In the past there has been a discussion on the Colorsync list how the
CcMmYK inks create a wider gamut than CMYK printers. You can either
describe it as better subtractive color mixing of the larger LC and LM
dots compared to what small C and M dots deliver or less white paper in
the highlights with a CcMmYK printer so more color. I prefer the first
description. That's the difference between CMYK and CcMmYK gamut.
The bigger gamut of the R800 on gloss will probably be in other hue
regions (full red, orange, blue, violet) than the bigger gamut of the
2200 on matte papers (pastel colors mainly). The gamut shapes will be
different and the total color (in delta E) number doesn't tell that. Dot
formation, smaller droplets with more circumference hence different
bleeding on the edges and into the coating per paper quality influences
the gamut possible, that's less a problem with diluted colors like LC
and LM that already did bleed in a sense than with full colors like red
and blue. So the R800 probably loses its strength in the full colors and
didn't get something in return. To put it in another perspective the
better strong red, orange, blue, violet became equal to the MY, MYY, MC,
MMC mixes of a normal CMYK printer on matte papers.  The 2200 strength
in the pastels didn't suffer as much.
Comparing rotogravure color mixing with offset color mixing in a sense,
the first excels on cheap matte papers.
Ernst
Thanks, Steve.
Could you point me to the specific cartridges and inks you are
talking about?  I am assuming you are talking about UT7 ink?  I may
give it a try.  I'm not fond of changing cartridges, and all the
posts about clogging, purging and cleaning make me a bit nervous.
That is why I was going to wait until I got a new printer.  The, I'd
have a color printer that I could also use for B&W with OEM inks in
case I have a bad experience with dedicated inks mucking up my 2200.
Right now, I am getting Dmax of 1.7 or greater on matte papers and up
to 2.1 to 2.3 on glossy papers with the UC inkset.  And my prints are
very neutral throughout the tonal range.  Not bad for a color inkset
and no need to change cartridges.  Still, I'd be interested in trying
dedicated B&W inks.  I just don't want to deal with potential
clogging problems.
Regards, Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
<stevekale@b...> wrote:
> Lou
your
with the
> 2200.
> Steve
> > From: Louis Dina <lbdina@c...>
> > Tim,
One
glossy
and
seems
on
who
both in
of
time.
superb
> > Lou
I think many of the clogging/foam issues have been resolved with the new
refillable cartridges with foam interiors (hopefully I have not just jinxed
myself!). Here are the cartridges for the 21/2200:
http://www.inksupply.com/index.cfm?source=html/epsonempty.html
I have a set filled with their Epson UC equivalent inks (I buy the 4oz
bottles and refill my own) which I use for colour - I use Eboni for matt and
Paul's new PKN for RC paper.
I use the following setup for B&W:
# K PKN
# LK glop
# C PK
# LC UT7 Warm Light Grey
# M Eboni
# LM UT7 Cool Light Grey
# Y UT7 Sepia toner
All MIS inks.  Carl Schofield has a similar setup albeit with some of the
inks in different slots.  By putting PKN in the K slot I can leave it there
when I switch to colour.  The UT7 inks are in their UT7 slots (except eboni
of course).
I am getting the following dMax's on Ilford Galerie Smooth Pearl after a 50%
glop application:
Warm 2.43
Cool 2.32
Neutral 2.34
Sepia 2.42
These are measurements from prints that have dried for around 12 hours.  The
dMax's are slightly lower than what can be achieved with the Epson driver
but the difference is not visually significant.
The most difficult ink to flush is of course the glop/LK.  I have to do a
few cleaning cycles and print a couple of A4 sheets with my glop overcoat
curve to purge any and all LK from the glop.
Maybe I was imagining things but when I made the switch to the dual setup in
January I felt there was much greater detail in the dedicated B&W prints.
With the refillable cartridges I will never bother with a CFS again.
Hope this helps
Steve
> Date: Wed, 23 Feb 2005 13:38:44 -0000
> Thanks, Steve.
> clogging problems.
> Regards, Lou
2005-02-23 by David Wroblewski
> # K PKN
> # LK glop
> # C PK
> # M Eboni
> # Y UT7 Sepia toner
Steve,
I'm missing something here. Why do you have PKN, Eboni, *and* PK?
Isn't it enough to have Eboni for matte and PKN for semigloss and
glossy?
-David
PKN is neutral and PK is warm.  So you have a very dark warm and a light
warm for warm prints. For neutral you have PKN and a blend of the two light
greys. For cool prints: PKN and the cool light grey.
> From: David Wroblewski <dawroblewski@...>
> Date: Wed, 23 Feb 2005 20:44:53 -0000
>> # K PKN
>> # LK glop
>> # C PK
>> # M Eboni
>> # Y UT7 Sepia toner
> Steve,
> glossy?
> -David
Great, thanks for the clarification. Is there any visible
difference between using K plus 2 grays rather than 3 grays?
I assume not--just curious though. The story I'm making up
for myself here is that quads used to be necessary but the
smaller droplet size on current printers allows us to go
to two grays without a visible difference in the print. Or
maybe it's better software?
In any case, that's a big deal, in my opinion.
-David
two light
> > From: David Wroblewski <dawroblewski@y...>
> >> # K PKN
> >> # LK glop
> >> # C PK
> >> # M Eboni
> >> # Y UT7 Sepia toner
> > Steve,
> > glossy?
> > -David
I think the general view is that 3 greys are not needed with the more modern
printers.  I would still like Mac QTR to be able to print at 2880 on the
21/2200 though...
> Date: Wed, 23 Feb 2005 22:04:12 -0000
> -David
2005-02-24 by Mark Carstens
Hey, Lou,
Thanks, for the information. I would jump at the chance to use the
profiles you've posted but I'm on a Mac. I would have to linearize with
my scanner for the time being, but I'm OK with that. Still, I'm
encouraged by your experience and will look into it further.
I've contemplated moving over to MIS inks (color pigs and quad) as
Steve Kale has suggested, but would be limited by having to pay someone
to create new color profiles for me. Operating on a shoestring budget
is a pain and the costs of experimentation can add up quickly. I would
rather lock into a sure thing than spend a lot of time trying to dial
in solution that requires a lot of tweaking to get right.
I would like additional information. Where should I contact you?
Mark
On Feb 23, 2005, at 3:14 AM, Louis Dina wrote:
> Hi Mark,
> Lou
>> Lou,
> about
> buy
> the
>> Mark
2 or 3 grays/greys? (was Epson R1800 vs 2200..need opinion fast)
2005-03-01 by rikeller
This is an interesting question (to me at least), so I thought I'd
"bump" this thread and see what people with far more knowledge about
this sort of thing than I have to say...
To add to the discussion though, I found the following information
regarding the optical density (O.D.) for the Piezotone and the MIS
Ultra-Tone (UT) ink sets at:
http://www.inkjetmall.com/store/info/1000-hours.html
http://www.inksupply.com/index.cfm?source=html/utfadedata.html
Below, I show the data just for Hahnemuhle Photo Rag paper. For the
purposes of this discussion, I have not looked at the fade data, but
just the given measured starting O.D.'s
The O.D.'s for the Piezotone inks (Warm Neutral though the other ink
sets are similar) are as follows:
Light gray: 0.138
Medium gray: 0.241
Dark gray: 0.711
Black: 1.720/1.780 (Museum/Portfolio)
The O.D.'s for the UT inks are as follows:
UT-Y (25% Black): 0.500
UT-M (cool toner): 0.600
UT-LM (light cool toner): 0.640
UT-LC (50% Black): 1.340
UT-C (75% Black): 1.330
UT-LK (Light Black): 1.270
UT-K (Eboni): 1.750
Based on this data, there are a few conclusions that I draw:
- the lightest UT ink (UT-Y, "25% Black") is far darker than the
lightest two Piezotone inks and is just a little lighter than the
darkest gray Piezotone ink.
- the UT-LC ("50% Black") and UT-C ("75% Black") inks have essentially
the same density, which strangely enough, is lighter than the UT-LK
("Light Black") ink.
- The Ultratones have essentially three densities: 1) around 0.5-0.6;
2) around 1.3; and 3) black.
- The Piezotones have four densities 1) around 0.15; 2) around 0.24;
3) around 0.7; and 4) black.
- The Ultratones' range implies that separation between dark inks is
more important, while the Piezotones' range implies that separation
between light inks is more important.
So the question is: for those who have used/seen both ink sets, what
differences do you see in the final output based on these different
philosophies? Do the Piezotones have better detail or fewer visible
dots in the lighter tones? Do the Ultra-tones have better detail or
fewer visible dots in the darker tones? Other differences? I am more
interested in the differences between "real" images, as opposed to 21-
step wedges...
Rik
more modern
> 21/2200 though...
> > -David
RE: [Digital BW] 2 or 3 grays/greys? (was Epson R1800 vs 2200..need opinion fast)
2005-03-01 by Paul Roark
Rik,
The numbers in these charts do not coincide with what I've measured or with
how the inksets were designed.
Note that the fade tests here compare the new PiezoTone to the old FS, not
the UT-FS or UT-FSN.  They have no bearing on the UT family of inks.
The chart does, however, show that the FS and PiezoTone densities are about
the same.  They were designed to be the same, and they print with the same
drivers and curves.  So, as a starting point, I'd assume that FS and
PiezoTone ODs are the same.
The explanation of the Piezo test says, "All of the monochromatic inks were
printed in patches of gray or black. The color inks were printed in patches
of their full hue..."
The test patches for the grays were not at full strength.  See the obvious
discrepancy that the UC yellow has a higher OD than the dark gray PT - no
way.  In fact, note that the UC Yellow in the InkJetMall table has a higher
OD than the UltraChrome M or C - no way.  The fade rate of the UC cyan
(which the table spells "cyanine") is said to be the higher than the Y or M.
Again, contrary to my tests and RIT tests of the MIS "Archival" pigments.
See the graph of the RIT fade results here:
http://www.inksupply.com/index.cfm?source=html/rit.html .
Bottom line, I don't put a lot of weight in the InkJetMall chart.
The MIS chart at
is for the UT1 variable-tone inkset.  The numbers are close to what I get
with the X-Rite spectrophotometer (at least where there is not an obvious
mistake in the UT-LC).
>Below, I show the data just for Hahnemuhle Photo Rag paper...
>The O.D.'s for the PiezoTone inks (Warm Neutral though the other ink
>Light gray: 0.138
>Medium gray: 0.241
>Dark gray: 0.711
The grays above are not at 100% density.  It's possible the "Color
Management" in the Epson driver was set to "Color Controls."
>UT-K (Eboni): 1.750
These are close to what one would get if the printer pumped out 100% with
"No Color Adjustment."
>lightest two PiezoTone inks ...
No.  In fact the UT1 Y in a hextone set (which is the M in the quad set) was
the lightest gray a 4-ink printer could have and still have a cold toner.
The lightest gray was set to a value between the Piezo/FS Y and M densities.
On an 1160, which was the printer I then had and designed the inkset for, it
prints dotless.
>the same density,
No, the MIS chart is in error.  The UT1-LC is a 50% dilution of the UT1-C.
The density give for the UT-C is the correct.  The UT-C is the basic density
of the dark grays in the PiezoTone and the UT family of inks.  The dark
grays are all about the same density.
> which strangely enough, is lighter than the UT-LK ("Light Black") ink.
No the LK is lighter than the UT-C (1.24 for LK, 1.32 for UT-C in the MIS
chart).
>1) around 0.5-0.6; 2) around 1.3; and 3) black.
MIS left out the LC & LM for some reason.  They are both 50% dilutions of
the C & M, respectively.
>1) around 0.15; 2) around 0.24; 3) around 0.7; and 4) black.
The PiezoTone/FS densities of the Y & M are slightly below and above the UT1
lightest gray, and they are all very close.  That is one of the things I
finally changed for my 7500UT-FSN setup.  I've moved the M (now LC in the
7500 set) to a position that is closer to half way between the lightest and
darkest Piezo/FS densities.
>... what differences do you see in the final output based on
>these different philosophies?
The Piezo and FS densities are the same and they print the same.
The UT1 is an older variable tone that had a light gray that was slightly
darker than the FS-Y.  The lightest toner in the hextone set (LM) was
extremely light.  The 1280 with the UT1 inkset had the smoothest highlights
I've measured, using a 1600 dpi scanner and the histogram standard deviation
tool.
The UT1 in a quad (4-ink printer) does show more dots in the neutral or cool
prints due to there being only one toner.  Most found it fine in an 1160,
but in my 3000 I preferred the VMS with the old inks and the UT-FSN with the
newer inks.
The Piezo/FS/UT-FS inks can produce a print that is slightly smoother than
the current UT2 and UT7 inksets unless the optional Y position has a light
ink in it.  In my 7500, for example, I use the FSN-Y in the Y position to
get perfectly dotless highlights (even with a loupe).  Most, however, will
never see the dots in the UT2 and UT7 inksets in actual prints.
The higher densities are in there for several reasons.  First, they allow
the printers to print good B&W with virtually no workflow.  Second, they are
needed to avoid overloading the glossy papers.  Third, they are needed to
achieve the tone range from cold to sepia.   But, I've noted regularly that
for those who do not use sepia, that spot has other uses -- another light
carbon for better lightfastness, glop for bronze-less glossy prints, custom
tone inks, and, as relevant to this question, a very light gray for more
smoothness.
I think modern printers do a great job with fewer and more dense inks.  So,
I use the UT2 and UT7 spots currently for glop in my printers, whereas the
old non-variable-dot 7500 can't quite do the job without the light UT-FSN-Y
ink.
Hope this helps.
Re: [Digital BW] 2 or 3 grays/greys? (was Epson R1800 vs 2200..need opinion fast)
It helps a lot. Thanks for the detailed response. I was basing my
interpretation on the assumption that the numbers in the charts were
real. It's a bit disturbing, to me at least, that the only published
numbers for ink densities for either company are wrong, misleading
out-of-date, or all of the above! And that's before we even start
talking about fade rates.
It would be good to see somebody compile some up-to-date numbers.
Paul: it looks like you have the data on-hand. Would you be willing
to give it a shot?
Thanks again.
Rik
wrote:
> Hope this helps.
Rik,
As a starting point, I measured the print densities of PiezogaphyBW ink from
10 different samples that had been sold to other people.  Using an 1160 and
the older EAM paper, this is what the average densities were when printed
with "No Color Adjustment":
Piezo C = 1.27
      M = .64
      Y = .40
Different printers, papers, etc. can make these vary.  Seeing 1.3 for UT-C
in a 1280 on current EEM is not unusual at all.  That is, the MIS reading
there is close to what most will see for that ink.  The MIS reading that are
off are the LC and LM.  Also, recall that the UT inkset is not the UT2 or
UT7.
_____________________________
Sent: Tuesday, March 01, 2005 9:26 AM
Subject: Re: [Digital BW] 2 or 3 grays/greys? (was Epson R1800 vs 2200..need
opinion fast)
to give it a shot?
Thanks again.
Rik
wrote:
> Hope this helps.
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
2005-03-02 by David Wroblewski
Very helpful message, Paul. One question below:
> ...But, I've noted regularly that for those who do not use sepia,
> that spot has other uses -- another light carbon for better
> lightfastness...
How does another light carbon == better lightfastness? I'm missing
the connection.
David
2005-03-02 by Paul Roark
David,
>> lightfastness...
The sepia ink is the weakest of the MIS UT inks, the pure carbon is the
strongest.  So, by taking out the sepia and putting in carbon, the prints
with the sliders (which use all the inks) will have less of the weak color
pigments in them.  For those who use curves, the cool through medium warm
prints will not be affected.
The neutral MIS inks now use a combination of carbon + cyan & R800 Blue
clone pigs that are very good, but probably still not up to carbon
lightfastness.  All of these inks are also predominantly carbon.
The sepia, however, even though I've removed the troublesome magenta and
substituted the R800 clone red, still has yellow in it.  Yellow is now the
weakest of the bunch.
In general, the more carbon and the less color pigs, the more lightfast the
image will be.
Re: 2 or 3 grays/greys? (was Epson R1800 vs 2200..need opinion fast)
2005-03-26 by Andre
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "rikeller"
Be careful here. Do not jump to any conclusion about the fade test
shown at the above link. The MIS inkset in question is not of the UT
familly inkset but the MIS-FS inkset, the equivalent of the original
PiezographyBW inkset, which Inkjetmall no longer, for several well
documented reasonsthat you can read about on the Piezo list and this
list also.
This is not an apples to apples comparison and is about worthless if
you want info on the MIS-UT familly inkset.
Andre Moreau
Andre Moreau
