How long to wait for densitometry
2005-02-27 by Stephen P. Veillette
I'm in the process of creating curves in QTR for MIS UT-FSN, and I wait at least an hour for the test patterns to dry/settle before performing densitometry on them, but I've noticed that a day later, the densities have changed slightly (lighter). My question, then, is how long should one ideally wait before performing densitometry to create a QTR curve? -Steve
2005-02-27 by Francis Ford
Could you see this lighter shift to the naked eye? --- "Stephen P. Veillette" <stephen@...> wrote: > > I'm in the process of creating curves in QTR for MIS > UT-FSN, and I wait at least an hour for > the test patterns to dry/settle before performing > densitometry on them, but I've noticed > that a day later, the densities have changed > slightly (lighter). > > My question, then, is how long should one ideally > wait before performing densitometry to > create a QTR curve? > > -Steve > > > > > __________________________________ Do you Yahoo!? Yahoo! Sports - Sign up for Fantasy Baseball. http://baseball.fantasysports.yahoo.com/
I'll have to say no. The change is in the values I'm getting from the densitometer. They are technically within the margin of error for the intstrument, but the difference has made me change my values for ink limit and relative density. Perhaps I'm being too critical of the numbers? I'm aiming for an ideal curve, but if density is too much of a moving target during the first x hours of a print, then it would seem that realizing the ideal would be difficult. -Steve --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Francis Ford <francisford45@y...> wrote:
> Could you see this lighter shift to the naked eye? > --- "Stephen P. Veillette" <stephen@v...> > wrote: > > > > > I'm in the process of creating curves in QTR for MIS > > UT-FSN, and I wait at least an hour for > > the test patterns to dry/settle before performing > > densitometry on them, but I've noticed > > that a day later, the densities have changed > > slightly (lighter). > > > > My question, then, is how long should one ideally > > wait before performing densitometry to > > create a QTR curve? > > > > -Steve
2005-02-27 by Ernst Dinkla
Stephen P. Veillette wrote: >I'm in the process of creating curves in QTR for MIS UT-FSN, and I wait at least an hour for >the test patterns to dry/settle before performing densitometry on them, but I've noticed >that a day later, the densities have changed slightly (lighter). > >My question, then, is how long should one ideally wait before performing densitometry to >create a QTR curve? > >-Steve > > 24 hours for Ultrachrome inks drying is the time color experts like Bruce Fraser use. That's color, a worst case shift of 1.4 Delta E can make a profile differ 3.0 Delta E but that is with CMY hues who shift in different directions. With B&W you can probably get a better prediction of the shift (based on earlier tests) and edit the curve to what can be expected of a truely dried target. Check later on whether that has been done right. Not that they actually wait 24 hours when an offset press has to produce. They make a dirty profile of the target, let production continue and send another profile after 24 hours. Ernst
Thank you, thats very good to know.Francis Ford --- "Stephen P. Veillette" <stephen@...> wrote: > > I'll have to say no. The change is in the values > I'm getting from the densitometer. They > are technically within the margin of error for the > intstrument, but the difference has made > me change my values for ink limit and relative > density. > > Perhaps I'm being too critical of the numbers? I'm > aiming for an ideal curve, but if density > is too much of a moving target during the first x > hours of a print, then it would seem that > realizing the ideal would be difficult. > > -Steve > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, > Francis Ford > <francisford45@y...> wrote: > > Could you see this lighter shift to the naked > eye? > > --- "Stephen P. Veillette" <stephen@v...> > > wrote: > > > > > > > > I'm in the process of creating curves in QTR for > MIS > > > UT-FSN, and I wait at least an hour for > > > the test patterns to dry/settle before > performing > > > densitometry on them, but I've noticed > > > that a day later, the densities have changed > > > slightly (lighter). > > > > > > My question, then, is how long should one > ideally > > > wait before performing densitometry to > > > create a QTR curve? > > > > > > -Steve > > > > __________________________________ Do you Yahoo!? Yahoo! Mail - 250MB free storage. Do more. Manage less. http://info.mail.yahoo.com/mail_250
2005-02-27 by hogarth@snappydsl.net
You can do it immediately after drying with a hair dryer. No shifting after that. -- Bruce Watson Stephen P. Veillette wrote:
> > I'm in the process of creating curves in QTR for MIS UT-FSN, and I > wait at least an hour for > the test patterns to dry/settle before performing densitometry on > them, but I've noticed > that a day later, the densities have changed slightly (lighter). > > My question, then, is how long should one ideally wait before > performing densitometry to > create a QTR curve? > > -Steve >
2005-02-28 by dlruckus
Hi, I've noticed that it does take several days for my prints to " dry down " to stable tone levels.They are generaly brighter after a couple of days. Never checked with densitometer but I avoid rapid judgements because of the observation. Just my personal experience. Duane --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Francis Ford <francisford45@y...> wrote:
> Could you see this lighter shift to the naked eye? > --- "Stephen P. Veillette" <stephen@v...> > wrote: > > > > > I'm in the process of creating curves in QTR for MIS > > UT-FSN, and I wait at least an hour for > > the test patterns to dry/settle before performing > > densitometry on them, but I've noticed > > that a day later, the densities have changed > > slightly (lighter). > > > > My question, then, is how long should one ideally > > wait before performing densitometry to > > create a QTR curve? > > > > -Steve > > > > > > > > > > > > > > __________________________________ > Do you Yahoo!? > Yahoo! Sports - Sign up for Fantasy Baseball. > http://baseball.fantasysports.yahoo.com/
