Head Problem?
2005-02-28 by lovebitn
Hey, I'm the one that posted a week ago about a problem with my 1270 (yeah, like that narrows it down in this group....) Anyhow, I've removed my MIS UT2 ink carts. I've replaced with genuine epson carts. I still get one nozzle check pattern group or one purge group that won't appear when doing a nozzle check or printing the purging paper. I think it's the "cyan", but it doesn't matter which one it is. It boils down to only having 5 out of 6 guns firing. Since I just installed the new carts yesterday (after spending the weekend formatting my hard drive and reinstalling drivers...not a printer problem) then maybe I should try again tonight. But, I'm not optimistic about it. It's just plugged or something. So, for now deciding what continuous flow system (MIS UT2 if possible or the MIS VM) is on the back burner. But, if anybody want's to help me with this too....in case I get my printer working....I'm all ears! What I'd like to know is if I can "clean" my heads myself...with rubbing alcohol or with Mary Kay eye make-up remover (silicone based). Is it possible to do this without causing too much harm? If so, any websites or info. on what to clean? Can I just dab a little alcohol on a q-tip and clean around where the heads poke through the carts? Is it worth sending it in for repair (no warranty)? Or should I just dump the 1270 in the garbage bin and start saving for a new wide format printer? (1280 or 2200) Thanks, Barbara
