EyeOne Usage for IJC linearization
2005-03-25 by Ruhrfoto/Bernd L.
some days ago I purchased IJC/OPM.
Now I want to linearize some profiles using my EyeOne spectrophotometer.
Unfortunately the device provides only Lab data.
Could anybody advise me, how to import these data to IJC.
Do I need a special software to measure density values with my EyeOne ( I don´t have
ProfileMaker, is there any "free/share-ware" available??)
or can I use a L* to density conversion chart (and where do I get one)?
Or is there any hidden import function in IJC which I missed so far.
Thanks for your reply.
Best
Bernd
Re: EyeOne Usage for IJC linearization
2005-03-25 by Louis Dina
Bernd,
I sent you a private email with detailed instructions.
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, " Ruhrfoto/Bernd
L." <ruhrfoto@y...> wrote:
> Hi,
spectrophotometer.
one)?
> Best
> Bernd
2005-03-25 by dfaprinting
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Louis Dina"
<lbdina@c...> wrote:
> Bernd,
> Lou
Alternate, you could buy Xrite's ColorshopX for $99. It has a density
tool that works with the Eye-one, and lots of other good tools.
Lou, would it be possible for you to send the same info to me, or
point me to a link where I can find the info? Thanks, Greg.
Re: [Digital BW] Re: EyeOne Usage for IJC linearization
2005-03-25 by Rainer Taube
Louis Dina wrote:
> Bernd,
> Lou
> > Hi,
> spectrophotometer.
> EyeOne ( I don\ufffdt have
> one)?
> > Best
> > Bernd
Louis,
I would do the same task with my EyeOne for QTR. If i could transfer
your informations to the QTR-Process i would like to get your
informations too if possible. May be i will try IJC/OPM later too.
Best Regards
Rainer Taube
www.tauberlin.de
2005-03-25 by rainertaube
> Bernd,
Louis,
I would try do the same task with my EyeOne for QTR. If i could
transfer your informations to the QTR-Process i would like to get your
Best Regards
Rainer Taube
www.tauberlin.de
> Louis,
your informations too if possible. May be i will try IJC/OPM later
too.
> Best Regards
> Rainer Taube
Rainer,
Here's a copy of the mail I sent to Bernd earlier.
Lou
I use my i1 with Gretag MeasureTool.  If you don't have MeasureTool,
you can download it free from the Gretag MacBeth website.  When you
open MeasureTool, first select Device/Port to configure your i1
(which must be plugged in before you start MT).  Select "Reflective"
and uncheck the box that says "Spectral".  Once the program
recognizes your i1, you can close the window.
Next, select the "Spot" measuring tool.  MT will ask you to place
your i1 on the holder for calibration.  When done, you can measure
your target.  Set the color space to Lab and begin measuring.
IJC/OPM does not yet automate reading the targets, so you have to
write down the values for the 26 steps of the grayscale.  All you
need are the L* readings (lightness values) for linearization.  Once
you have recorded all the values on paper, open the IJC linearization
tab and hit the "clear" button to remove any old data.  Then, enter
the values you wrote down directly into IJC with the lightest values
(eg, 98) near the top, and the darkest values at the bottom.  The
vertical slider in IJC should be set to "0" when using L* values for
linearization.  There is no advantage to converting these values to
density readings.
It is possible to convert L* to density values.  There is a companding
calculator at http://www.brucelindbloom.com/ which does just that.
If you use density data, you will need to move the vertical gamma
slider in IJC so that step 13 has an "aim value" of between 0.63 and
0.70.  This is because density is measure on a logarithmic scale,
unlike L* which is a linear scale.  You will need to input the
density of step 1 and step 26 before you can set the slider
properly.  I see no reason to use density instead of L* values.  With
your i1, it is much easier, and just as accurate, to use L* values.
Joe Berndt (author of IJC.OPM) is working on automating the process
so that future releases of the program can load this data quickly and
easily.  But at present, it is a manual process.  You can try using a
scanner which is automated, but it won't be as accurate as using your
i1.  The instructions are in the IJC/OPM user Manual.
Regards, Lou Dina
p.s. I wrote a tutorial for IJC which is posted in the Files section
of this website and also on the Bowhaus website.  It has a lot of
information on how to do linearization in IJC.
Re: [Digital BW] EyeOne Usage for IJC linearization
2005-03-26 by Scott King
On Mar 24, 2005, at 8:13 PM, Ruhrfoto/Bernd L. wrote:
> <snip>
</snip>
Check out QuickRead from iccTools.
http://www.icctools.com/quickread.html
I use it with my EyeOne to read a 26 step set of patches I created
which can be read in scan mode.  Then I export a .csv file and import
into IJC.  Work like a charm.
SK
2005-03-26 by rainertaube
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Scott King
<scotty@j...> wrote:
> </snip>
Hallo Scott,
i installed Quickread on my system but didn´t find out, how to start
measuring. Connection to EyeOne and calibration works fine but where
is the button for measuring. Is there a help file anywhere. I didn´t
find one.
Best Regards
Rainer Taube
www.tauberlin.de
2005-03-26 by Louis Dina
Thanks Scott.
Quickread is definitely faster and easier to use than MeasureTool.
Even in "spot measuring mode", it retains the data on the screen, so
you don't have to write down the readings.  For strip readings, I think
it would be necessary to create a new 26 step target with big enough
differences between patches so the i1 is able to see tonal differences.
You must be on a Mac, because the Windows version of IJC/OPM does not
accept CSV data input (unless I am missing something).
I'll have to play around with Quickread to learn its features.
Regards, Lou
> > <snip>
> </snip>
> SK
2005-03-26 by Carl Schofield
I use a "chaotic" or randomized arrangement of patches that works well
for strip reading with Quickread.  Very nice application and as you
say, much better than Measuretool.  Also gives visual and C, M, Y
status T density data when density is selected for export as a text
file.
Carl
On Mar 26, 2005, at 8:16 AM, Louis Dina wrote:
> Thanks Scott.
> Regards, Lou
>>> <snip>
>> </snip>
>> SK
2005-03-26 by Steve Kale
What are the different measures of density (V,C,M,Y) and the various density
status settings?
Thanks
Steve
> From: Carl Schofield <scho@...>
> Date: Sat, 26 Mar 2005 09:09:48 -0500
> Subject: Re: [Digital BW] EyeOne Usage for IJC linearization
> file.
> Carl
V = visual density (what you have been using with QTR), C = cyan
density, M = magenta density, Y= yellow density).  I don't know what
all of the different status classes are, but status T is what I've been
using.  I find that C, M, Y densities are more intuitive for
interpreting hue in my prints than the a, b values from Lab data.
Carl
> density
> status settings?
> Thanks
> Steve
>> file.
>> Carl
Thanks.
> Carl
2005-03-26 by dfaprinting
I just downloaded and tried Quickread, after installing it says beta
expired and closes.
I did also try in Xrite's ColorshopX ($99USD) and that works very
well. The measure portion is located in the scratch pad (I was using
the color scratch pad). After scanning, you can save as with the
selected measurements, or you can directly export to something like a
spread sheet or text editor (front application). Just thought I would
pass this along.
2005-03-27 by Carl Schofield
I think you downloaded an expired beta by mistake from the wrong
folder.  Try downloading either the PC or Mac version from the 1.0GM
folder at the link below  I'm using the Mac version (1.0.0) from that
directory and it works fine.
http://www.icctools.com/~nathan/QuickRead%20&%20OfficeAssistant/
> expired and closes.
2005-03-27 by dfaprinting
Thanks, but I grabbed the one from the beta3 folder:
20OfficeAssistant/1.0B3/ for windows
Luckily, I already own ColorshopX, bought it about a month ago.
2005-03-27 by Scott King
On Mar 26, 2005, at 7:01 AM, rainertaube wrote:
> ... how to start measuring. Connection to EyeOne and calibration works
> fine but where is the button for measuring.
For strip scanning, position the EyeOne before the first patch, press
the button on the side, wait for the 'bonk' sound, then measure.
>  Is there a help file anywhere. I didn´t find one.
Not that I'm aware of.
SK
> For strip readings, I think  it would be necessary to create a new 26
> step target with big enough differences between patches so the i1 is
That's exactly what I did.  If anyone would like the target, just let
me know and I'll e-mail it directly.  Or, if someone has upload
privileges I'll send it and it can be posted to the 'Files'.
Yep, I'm using this on a Mac.
SK
2005-03-28 by Rainer Taube
Hallo Scott,
i would like to have it. Please e-mail to rainer@...
Thanks
Rainer Taube
2005-03-28 by copal01
My too, thaks in advance. copal01@...
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Rainer Taube
<rainer@t...> wrote:
let
> Hallo Scott,
> i would like to have it. Please e-mail to rainer@t...
> Thanks
> Rainer Taube
[Digital BW] Quickread
2005-03-29 by Steve Kale
Pity this app can't export all the data at once rather than 1 set at a
time... Or am I missing something?
Carl, can you email me your random step wedge?  Is it in QTR Grey Lab
(steps)?
> Carl
>> density
>> status settings?
>> Thanks
>> Steve
>>> file.
>>> Carl
Re: [Digital BW] Quickread
Forget that Carl - found the old one and assigned QTR Grey.
> From: Steve Kale <stevekale@...>
> (steps)?
