You'll never get the plug out of the 1280 EZ fill carts unless you
remove them from the printer. But you seem to get perfect nozzle
checks right away if you prime them by pulling just the slightest
amount of ink out of the bottom.
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, toliwel@a... wrote:
> Can the MIS EZ fill carts be refilled while still in the printer?
Or should
> they always be removed for refilling? I wonder if removing the plug
will
> upset the function of the vent or dampers and cause ink to run
through the nozzles
> into the printer. I use the SSC utility to reset the chips on my 1280.
> Tom Wells
