Why not HP?
Why not HP?
2005-03-27 by pdcorlis
I asked a similar question before - but didn't get many takers, so if you'll allow me I'll ask
it again.
With Wihlem "numbers" for glossy paper (my preference) framed and glassed at 100+
years, no clogging problems, and a printer price equal to or lower than Epson's - why not
look at HP's new 8750?
I understand this is mostly an Epson/MIS forum and I've been getting great results with my
little C86+MIS EZ - but I'm willing to explore all options before I spend money on a bigger
printer. I've seen prints from a smaller HP printer that uses the same gray scale and color
ink technology found in the 8750 - and they look great - as in GREAT.
So I guess I'm wondering - why don't I see any posts here about HP here? Is it because this
is an Epson centered group - or because there is something fundamentally wrong with the
HP "solution" for black and white? I'd appreciate some advice from you all beore I spend a
big chunk of money. I'm not rich enough to make a mistake here.
Thanks in Advance!
Phil C.
Re: Why not HP?
2005-03-27 by Louis Dina
In a nutshell, there aren't many quad ink options are available for
HP printers.  Due to longevity concerns, most of us want to use
pigment inks for our work (ie, Epson printers), and most other
printers use dye inks.  Putting pigment inks into a printer designed
for dyes can sometimes result in clogging.
So, that leaves most non-Epson printer users with the standard OEM
inkset, which generally requires a RIP or some other 3rd party
solution to get decent monochrome output.  Most of the inexpensive
RIPs don't support HP or Canon printers for archival reasons
mentioned above.  You have to spend a lot more money for a RIP that
offers good monochrome support.
Not a thorough answer, but it seems to be the state of affairs at the
present time.  It will probably change some as the other printer
companies come up with better offerings, which seems to be happening.
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pdcorlis"
> it again.
glassed at 100+
GREAT.
> Thanks in Advance!
> Phil C.
Re: Why not HP?
"Due to longevity concerns, most of us want to use pigment inks for our work (ie, Epson
printers), and most other printers use dye inks."
I'm really not trying to start an arguement here, but if the Wilhelm tests are correct - and
the newer HP ink and paper combination do give 100+ for framed and glassed display,
doesn't that at least call us to question our belief that pigment inks are the only way to go?
Again - I'm really not trying to stir anything up here - but trying to weigh all the options
prior to investing in a solution.
Thanks in advance for any help you can give me
Phil C.
Re: [Digital BW] Re: Why not HP?
2005-03-27 by Carl Schofield
I for one would be more than happy to have an archival, dye based
solution that avoids all of the negatives associated with pigment inks
on both RC and cotton papers (bronzing, metamerism, flaking, low dmax,
etc.).  Perhaps the new HP inks and papers or the much hyped and long
awaited (soon to be available?) "Futures" inks should be considered
seriously.  Assuming Wilhelm's tests are realistic, then the only
negatives I can see at this point with the HP products are ink and
paper costs and lack of 3rd party support.  I also have not seen HP B&W
prints made with the new papers and inks so can't comment on print
quality.
> our work (ie, Epson
> glassed display,
> Phil C.
Re: Why not HP?
Phil,
I'm sure dye inksets will continue to improve and will probably gain
a larger market share down the road.  Dyes certainly have some
advantages.  Many dyesets use swellable polymer type papers to reduce
fading and improve lifespan, so the choice of papers is fairly
limited.  Life usually shortens if using other types of papers.
None of above alters the fact that 3rd party inksets and RIPs are
still extremely limited for HP and Canon printers.  It's just a fact
of life at the present time. So, people use Epson printers mostly.
If the 3rd party manufacturers decide their is a profitable market
for ink and RIP products with these printers, they will begin to
appear.
Lou
our work (ie, Epson
glassed display,
> Phil C.
Re: Why not HP?
2005-03-27 by Bob Michaels
Phil: This seems to be a case where it's just a lot simpler to follow
the crowd, use the existing inksets, use the existing workflows, use
the existing problem solutions, and rely on the existing
infrastructure then to start from scratch with a handful of similar
independent minded folks using something other than Epson printers.
I just want good prints and to make them the easiest way. I don't want
to try to duplicate the several years efforts of a lot of people with
a different printer. HP may make better printers than Epson for all I
know. But it's easier to make good prints with an Epson because of the
infrastructure.
I think we all have our strong streaks of individuality. I just prefer
to exercize mine in the content of my images rather than how I print
them.
Watch a bunch of photojournalists shooting sometime. Notice they are
all shooting Nikon or Canon gear. Is that because they are the best?
No, not at all. It's just because of the support and the fact that if
they need to borrow a lens or body, that's what everyone else has. A
related situation exists with printers.
Bob Michaels
> printer.
Re: Why not HP?
2005-03-27 by Andre
> it again.
glassed at 100+
These are the ink carts that will fit into the 8750 printer. They are
all uneven volume. I wonder why...
HP 97 Tri-color Inkjet Print Cartridge, 14 ml C9363WN
HP 96 Black Inkjet Print Cartridge, 21 ml C8767WN
HP 99 Photo Inkjet Print Cartridge, 13 ml C9369WN;
HP 100 Gray Photo Inkjet Print Cartridge, 15 ml C9368AN
HP 101 Blue Photo Inkjet Print Cartridge, 13 ml C9365AN
HP 102 Gray Photo Inkjet Print Cartridge, 23 ml C9360AN
Andre Moreau
2005-03-27 by Shilesh Jani
I have seen HP b/w prints on their Premium Plus papers.  I must say
the print quality and neutrality is impressive.  No objectionable
metamerism or bronzing on these RC papers.
I used one of these printers at the local CompUsa store, and the HP
rep was kind enough to let me print one of my photographs.  The print
was perfect straight out of the printer.  I have seen cliams that
these inks/paper combination are capable of DMax greater than 2.7!
Using a Heiland PM-Densitometer, I am measuring Dmax ~2.3.  In
comparison,  using Epson UltraChome inks we typically get ~1.6 for
matter papers, and ~2.1 on RC papers.
Pros & Cons (as I see it)
HP:  (1) Out of the box b/w prints, (2) Higher Dmax, (3) Limited to
swellable polymer papers,  including Ilford Classic line, (4) These
papers are not water-proof, and in fact smudge very easily on finger
contact, (5) Less longevity on 100% cotton art papers?
Epson UC with Light Gray:  (1) Wide range of papers, (2) A lot of
workflows, (3) Bronzing on RC papers, (4)Lower DMax.
My own preference is matte papers, and am not overly concerned about
DMax, so I am staying with Epson, for now at least.
So, if you want easy b/w, HP printers are a good choice; you just
need to know the limitations.
Hope this helps.
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield
inks
dmax,
long
B&W
> quality.
for
> > our work (ie, Epson
Wilhelm
and
> > glassed display,
inks
trying to
> > Phil C.
Re: Why not HP?
2005-03-28 by Scott Graham
Also with HP you change print heads with each cartridge which means
they are cheap enough to be replaceable "for free" which is not the same as super high
quality; just can't be no matter how hard they try
and this also means that cartridge to cartridge color (or B&W) calibration must vary more
than if the heads are not changed.
and HP has traditionally focused on speed and "engineering drawing" quality rather than
fine art.
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Louis Dina" <lbdina@c...> wrote:
> Lou
> > it again.
> glassed at 100+
> > Phil C.
RE: [Digital BW] Re: Why not HP?
2005-03-28 by Seth
Excuse me??  Wrong answer!!  One of the major unwritten rules of PJ is you
DON'T borrow gear.  You make do with what you have.
We shoot Canon or Nikon because they are the best.  There are NO OTHER SLRs
that are equal or have the range of lenses available.
Now, if we apply the same scenario, you have Epson.
Seth
==-----Original Message-----
==From: Bob Michaels [mailto:bob@...]
==Watch a bunch of photojournalists shooting sometime. Notice
==they are all shooting Nikon or Canon gear. Is that because
==they are the best?
==No, not at all. It's just because of the support and the fact
==that if they need to borrow a lens or body, that's what
==everyone else has. A related situation exists with printers.
