Ultratone on Epson 1280: which paper and ink?
2005-03-28 by mleblanc001
I am using UT2 Ultratone (from MIS) with my Epson 1280 with marginal
results.  I never obtain a satisfactory neutral print. It seems too
cool for my taste with a slight magenda cast.  I have been using
Paul Roark workflow and curves with matte paper. I have not been
succesful in modifying the curve to get a warmer result.  I was
trying to go somewhere in between neutral and carbon but it does
become brownish AND magenta at the same time !!  Anyone can propose
a curve that works well ?
Paper: I am using Epson Matte Heavyweight, however the curve is made
for Epson Enhanced Matte.  Does it make a big difference ?  Anyone
has compared result for both paper? Is it the source of my problem ?
I am not interested in warm, sepia or anyting like that.  What I
want is a straight neutral print that would look like a traditional
darkroom print.  Should I switch to monochrome inks (like FSN from
MIS)?  Anyone has experience comparing UT2 with FSN ?
Thanks for your help,
Michel
Re: Ultratone on Epson 1280: which paper and ink?
2005-03-29 by Bob Michaels
Have you tried one of the warmer curves? And, are you sure all the
nozzles are printing? I found UT2 to be a bit on the warm side to my eye.
Also, haven't been able to tell much difference, especially tonality,
between EEM and HWM.
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mleblanc001"
2005-03-29 by zonepeter
When you describe prints turning "magenta" it makes me think of the
older "bad" carts that were going around.  You might check on that.
Using curve blending in QTR (or IJC/OPM) make it easy to have control
the tone.  You can also adjust Paul's curves to your liking, but I
don't find it as easy.
Peter
