Ben...I was using the Polaroid version of this scanner (now sold)
and had the same problem. Seems to me that Polariod or Silverfast
(I can't remember which) offered a software/firmware upgrade on
their website that fixed the problem. Maybe the Microtek or
SilverFast websites have upgrades that may help.
That said, I stopped using the glass holder, as it was a bear to
keep clean (four surfaces!). I found if I used the regular holder
and didn't tighten the top down snugly the film laid perfectly
flat. This was with roll film. Hope this helps...Best, Val
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ben_zlotkin"
<ben@b...> wrote:
> Im having trouble with the glass carriers for the 120tf.
Silverfast is not recognizing it half
> the time and throws a warning saying that no carrier is inserted.
The only way around this
> is to 'fool' it by loading the standard med format carrier then
swapping it for the glass one
> - this works some of the time.
> Any ideas?
> Thanks, Ben Z.
