Dedicating a printer to Black & White
2005-03-30 by paulvtt
Hi
I'd like to hear from somebody who uses or has used the Lyson Quad
Black ink or another manufactures B&W inkset in a Canon I9100 or in an
Epson 2200. Through a unique series of events I have both printers. I
am seriously considering dedicating one of them to Black & White
printing. Thinking about using the Canon for color and the Epson for
Black & White, but that is flexible.
Would like to use a Black & White ink set, perhaps Lyson Quad Black.
Would like to hear from somebody who has recent experience in using a
black & white inkset in either or both printers. Particularly
interested in the quality of the prints, longevity, and any problems
with the setup and use. Not sure if I will use cartridges or their
bulk feed system.
I live in the US near Chicago, so I have excellent supply houses in
easy reach
Thanks
PV
Re: [Digital BW] Dedicating a printer to Black & White
2005-03-30 by Daniel Ridings
Do yourself a favour ... go to http://www.harrington.com , scroll down
to the bottom and follow the link for QuadTone RIP.
Download the software, run the installer and check out the b/w results
you get by using it with the 2200 and standard Ultrachrome inks.
Then pay for it if you use it, a whopping 50 USD. I've only tested it on
a borrowed 2200 and have been able to compare with MIS Carbon inks on
another printer. QTR is very, very nice. No hassle with other inks, you
can print both color and black and white on the same printer with
beautiful results in both cases.
Daniel Ridings
http://www.dlridings.com/paw2005
paulvtt wrote:
> Hi
> bulk feed system.
> easy reach
> Thanks
> PV
2005-03-30 by mastedward
I have used MIS inks (but not Lyson)in an Epson C86.  The results are
neutral b&w prints.  Since that worked out well, I have ordered a set
of black inks and refillable cartridges for the 2200, thinking that 6
variations of black will be even better than 4.  Daniel says save
yourself trouble and download QuadToneRIP.  Worth a try. If you can
understand how to run it you get what sound like wonderful results
for $50.  If you can't run it, you don't have to pay.  I never could
run it, so have gone to the MIS inks. . . Edward --- In
DigitalBlackandWhiteThePrint@yahoogroups.com, Daniel Ridings
down
results
it on
on
you
> Daniel Ridings
> paulvtt wrote:
> > Hi
in an
printers. I
for
Black.
using a
problems
their
> > bulk feed system.
in
> > easy reach
> > Thanks
> > PV
2005-03-30 by Diane Fields
I have considered dedicating my 1280 as a b/w printer for several years--since I bought my 2200.  But--I really felt that it was more difficult to keep 2 printers going with separate inks, papers, etc.  When I found out about QTR I was very excited.  I demoed it for several weeks and decided on buying it.  Not having used a 3rd party inking system for either of these printers, I can't compare, but I am very happy with QTR for the 2200 allowing me to continue printing color with my regular paper profiles and printing monotones with the papers I like with QTR.
Diane
Diane B. Fields
picnic@...
photo site  http://www.pbase.com/picnic.
  Sent: Wednesday, March 30, 2005 1:02 PM
  Subject: Re: [Digital BW] Dedicating a printer to Black & White
2005-03-30 by wharfwalker
When you have spent £1000 on Peizography ink and paper in the last year
and several hundred on Lyson the year before, only to find a sweet
little program like QTR doing a better job than both, and allowing the
printer to continue using the inks it was designed to use, it is
difficult not to recommend this course to anyone who cares to listen. I
am now printing on 1.3mm card, for which there is no profile in QRT,
but getting excellent results using a combination of the profiles that
are included with the program. It is a great solution. The alternative
was a dedicated printer, Studio print for lots of money, and no
gaurantee that is would be noticeably better than $50s worth of QRT.
John
Re: Dedicating a printer to Black & White
2005-03-30 by bwbonkers
Hi
I used QTR/Epson 2100/OEM inks. Great program and as other's have
said produces excellent results. However there is a learning curve. I
then learnt about the Bowhaus RIP OPM/IJC. This program does what QTR
does, is more expensive but for me I found it easier to use. Still
takes some learning !! You could also have a go at Clayton's BO
method of printing. Very simple, cheap and requires no extra
software. I also tried MIS UT inks in a 1160. Again good results.
However I do not have the space for two printers, so when I bought
the 2100, a RIP solution was the only way to go. The only problem I
had with OEM Epson inks is that of bronzing on glossy papers. Now
that was a big problem for me because I really like glossy B&Ws. To
solve the bronzing I switched to a dye ink set. I do not sell prints
so the longevity issue is not a problem for me. I'm currently using
Lyson Fotonic inks (colour inks) with the MIS easyfill carts. The MIS
easyfill carts are really very good. With this ink set I use OPM/IJC
for B&W. QTR would work just as well. However you would have to be
prepared to make your own curves/profiles for either RIP. Another
option that Lyson have just launched with Bowhaus is their Daylight
Darkroom inks. These are a set of B&W tonable inks for the 2100/2200
and use the Bowhaus RIP to control them. They are dye inks and will
print on matte and glossy papers. I have seen no test reports so far
so how good they are is anyone's guess. However I would like to think
they would be an improvement on their Quad Black inks. I'm currently
waiting for a sample print from Lyson.
The choice is your.
Good luck.
Peter.
Re: [Digital BW] Dedicating a printer to Black & White/A tutorial for QRT?
If someone writes a tutorial that would enable me to set up and use
QRT I would gladly pay another $50 to $100 for it.  Until then, I can
only wish . . .and continue using MIS inks.  Edward --- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "wharfwalker"
year
listen. I
QRT,
that
alternative
> John
2005-03-31 by Stephen Veillette
I can speak from experience about the Lyson Quad Black inks-- I don't like them.
Admittedly, I began using them when I first started trying to figure out my whole digital
darkroom workflow (scanning, photoshopping, printing), so I was at the bottom of the
learning curve.  Looking back on the experience, I can say it probably would have been
easier if I knew then what I know now (isn't that always the case?), so my tale of woe is
partly due to my own ignorance.
After a frustrating amount of time spent trying to follow the Lyson instructions and many
cartridges later, I was able to produce satisfactory prints, but they left me wanting more.
Getting a linear grayscale response from the inks using Lyson's canned ICC profiles was
difficult, so I ended up a lot of trial and error to get prints that looked good.  This was all
before their introduction of the Daylight Darkroom system, which appears to provide more
control than just using canned ICC profiles.
Furthermore, the inks exhibit metamerism-- they look fairly neutral under artificial light,
but take on a greenish cast under daylight.  I have even received their Daylight Darkroom
sample prints, and while the printing is very nice, the inks still have that slight greenish
look to them.
I have since discovered MIS inks and QuadToneRIP, and I'm never looking back.  I would
imagine, however, that using QTR with the Lyson Quad Black inks would have given me the
control I lacked using Lyson's canned ICC profiles, but ultimately, the quality of the MIS
inks is far beyond that of the Lyson Quad Black inks.
For what it's worth, I was using an Epson Stylus Photo 870 with the Lyson inks, and now I
use an Epson 1280 with the MIS inks.
-Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "paulvtt" <paulv@w...> wrote:
> Hi
> bulk feed system.
> easy reach
> Thanks
> PV
2005-03-31 by wharfwalker
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mastedward"
> QRT .....
Edward, At which point in the setup do you fail? Some earlier versions
of QTRgui were a bit daunting but the last version is stable and 'easy'
to use. I can't write a tutorial because I don't know enough about it
all, just my own system. It is XP and Epson 4000 so if that is close to
yours let us know what the problems are.
John
2005-03-31 by Daniel Ridings
Hi Edward,
Sorry to hear you had problems. You must have been one of the early ones.
I too had heard about all kinds of problems. So I was pleasantly surprized
when I downloaded it about two weeks ago to test on a printer I
temporarily had access too.
Evidently the installation procedure has changed dramatically. Now all you
do is click on an install program, choose the right printer and the
installation program does the rest.
So the latest package seems to have ironed out all the stumbling blocks of
earlier releases.
I tested on Windows XP machine if that makes any difference.
I too have an Epson C86 with the MIS UT EZ inks (warm, in my case). The
results from both are great. So when I mentioned doing a comparison, I was
comparing to the UT EZW inks. Both are great.
Daniel Ridings
> down
> results
> it on
> on
> you
>> Daniel Ridings
>> paulvtt wrote:
>> > Hi
> in an
> printers. I
> for
> Black.
> using a
> problems
> their
>> > bulk feed system.
> in
>> > easy reach
>> > Thanks
>> > PV
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner
> and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND
> \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
Tutorial for Windows XP
1) Download
2) Click on the install program
3) Choose the right printer model (it supports many, choose the one you have)
4) Use the graphic interface to choose a file to print
5) Print
You don't have to pay. This was a freebie.
Daniel
>> When you have spent \ufffd1000 on Peizography ink and paper in the last
> year
> the
> listen. I
> QRT,
> that
> alternative
>> John
> page.
> them short.
> the membership.
> section:
> PRINT YAHOO GROUP.
Re: [Digital BW] A Tutorial for QRT? Thank you, Daniel. . .
2005-04-01 by mastedward
I am stunned!  I followed your 5 or so steps and printed a lovely b&w
print with the 2200 with colored inks! But what about the 17 pages of
Tom Moore's tutorial - none of which I could do other than running
the ink seperation test page - regarding making curves,
linearisation, etc?  Are these optional steps?  I assume the process
is to edit one's photo, save it in a TIFF file, and then bring it
into the graphic interface to print it - Can it be this simple?
Guess I'll find out as I do more printing. Thank you for taking the
time to present your QRT tutorial, Daniel - I am grateful indeed, and
am happy to now have reason to send Mr. Harrington his $50.  Best
Regards,  Edward       -- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "Daniel Ridings"
> 1) Download
you have)
> 5) Print
> Daniel
use
can
last
> > year
sweet
allowing
> > the
> > listen. I
> > QRT,
> > that
> > alternative
QRT.
> >> John
resources as
wish to
this same
> > page.
messages to keep
> > them short.
flames.
digital B&W
removed from
> > the membership.
and
group Owner
> > and Moderators. See "Group Topic, Rules and Guidelines"
in the
Files
> > section:
THE PRINT
"OWNER"
AND
> > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL
NOT BE
LIABLE TO
OR
OF
THE
> > "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
YAHOO GROUP
HAVE BEEN
THE USE
(ii)
DATA; (iii)
PRINT
THE
> > PRINT YAHOO GROUP.
> > Yahoo! Groups Links
Re: A Tutorial for QRT? Thank you, Daniel. . .
2005-04-01 by zonepeter
Yes it is that simple!  Tom Moore's tutorial is about profiling and
linearizing to your printer.  It creates profiles customized to your
printer, ink, paper combination, but is absolutely optional.  You
probably want to start out not using them.  As long as you are
satified with your results, keeep doing what you are doing.
Additionsl to the "tutorial" Daniel wrote would be to use the setting
on the GUI.  Paper settings, etc.  The most satisfying is the curve
settings.  Select 2 curves and blend them as you please.  You can get
warm, cool or neutral prints by blending the curves.   It give
remarkable control over the image tone.  Printing step wedges at
various settings can give you a library of choices on a single page.
Keep playing and have fun.
Peter
b&w
of
process
and
> > 1) Download
one
> you have)
> > 5) Print
> > Daniel
> use
I
> can
> last
> > > year
> sweet
> allowing
> > > the
is
> > > listen. I
> > > QRT,
profiles
> > > that
> > > alternative
of
> QRT.
> > >> John
> resources as
> wish to
visiting
> this same
> > > page.
> messages to keep
> > > them short.
> flames.
> digital B&W
> removed from
> > > the membership.
rules
> and
> group Owner
> in the
> Files
> > > section:
> THE PRINT
> "OWNER"
> AND
> NOT BE
> LIABLE TO
CONSEQUENTIAL
> OR
LOSS
> OF
IF
> THE
> YAHOO GROUP
> HAVE BEEN
(i)
> THE USE
> (ii)
> DATA; (iii)
> PRINT
BW,
> THE
> > > PRINT YAHOO GROUP.
> > > Yahoo! Groups Links
Re: A Tutorial for QRT? Thank you, Daniel & Peter. A question. . .
Yes - I can see that by combining the left and right curves I should
have plenty to keep me busy for some time.  And it is beautifully
simple!  A question about resolutin settings.  When I use the 1440 or
1440 super settings, all is fine.  If I try 2880 dpi I get an error
message saying that QTR has encountered a problem and needs to shut
down.  Is there a way to print with 2880 dpi?  Is it dependent on the
file size of the photo printing?  One other question: before I
learned that I would be able to use QTR I ordered a set of refillable
carts and black inks from MIS for the 2200.  Is there any point in
using these inks with QTR or is that defeating the purpose of the
program?  If so, I guess I could purchase MIS colored inks and at
least save money by refilling rather than replacing. . .Thanks again
for enabling me to use this wonderful program!  Edward  --- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "zonepeter"
your
setting
get
> Peter
> b&w
pages
> of
running
> process
> and
> > > 1) Download
> one
> > you have)
> > > 5) Print
> > > Daniel
and
> > use
then,
> I
> > can
> > last
> > > > year
> > sweet
> > allowing
> > > > the
it
> is
> > > > listen. I
in
> > > > QRT,
> profiles
> > > > that
> > > > alternative
no
> of
> > QRT.
> > > >> John
> > resources as
you
> > wish to
> visiting
> > this same
> > > > page.
> > messages to keep
> > > > them short.
or
> > flames.
from
> the
> > digital B&W
> > removed from
> > > > the membership.
> rules
> > and
> > group Owner
> > in the
> > Files
> > > > section:
BW,
> > THE PRINT
> > "OWNER"
> > AND
> > NOT BE
> > LIABLE TO
> CONSEQUENTIAL
> > OR
> LOSS
> > OF
> IF
> > THE
> > YAHOO GROUP
> > HAVE BEEN
> (i)
> > THE USE
GROUP;
> > (ii)
> > DATA; (iii)
THE
> > PRINT
> BW,
> > THE
> > > > PRINT YAHOO GROUP.
> > > > Yahoo! Groups Links
2005-04-01 by Stephen Alred
... If I try 2880 dpi I get an error
See message # 58813 -- the "2.2b" version now supports 2880dpi,
unless, of course, using using that version now...
-- Steve Alred
2005-05-02 by bard960
I owe some feedback to the group, and I'll take this oportunity.
As previuosly mentioned, I had some initial disappointing results
with my Canon i965 + Lyson's Quad Black inks. The first prints all
looked faint, with an horrible magenta hue on Lyson's 170gsm Matt
InkJet paper. I tried any possible combination of profile, none
yielding the desired results.
The kind guys from Lyson suggested not to use any profile, but just
to print black and white images in RGB mode with minimal histogram
adjustment. They also sent me a sample print done with their inks on
their media, that appeared much better than my digital prints.
Just to rimind you, the Canon i965 is an A4 6 inks channels printer
with maximum resolution of 4800 x 1200 dpi, supposed to produce 2
picoliter ink droplets. Although not being a professional model, it
should give pleasant and acceptable results up to A4 enlargments
using monochrome inks such as Lyson's.
I then had precious suggestions from Howard on this forum: adding +3
to the black, cyan, magenta and cyan sliders in the i965 driver
finally gave richer prints, both on matte (Lyson) and glossy (Lyson,
Canon and Ilford) papers. This solution correlates well with the
fact that when the "photo-cyan" and "photo-magenta" tanks finished,
the other four tanks (black, cyan, magenta and cyan) were almost
full. Needles to say, a noozle check revealed no problem. After
applying Howard's suggestions, the other tanks begun to be used.
I do not know if all this makes any sense. The problem is that I am
still far from a true WYSIWYG working situation. I still have to do
a few mini-prints in order to have an idea about what the final
print will be. How can I know what shade of gray is managed by the
cyan channel or by the photo magenta channel, etc? Is digital black
and white printing still a guesswork job?
One more question I would like to ask the forum: Are there any
alternatives to the Lyson inks (either pigment or dyes) to be used
with my Canon i965?
Antonio
<paulv@w...> wrote:
> Hi
in an
printers. I
for
Black.
using a
problems
> bulk feed system.
in
> easy reach
> Thanks
> PV
